    Magic Mirror runs twice on boot
    8 Posts 4 Posters 4.2k Views 4 Watching
    • A
      AyeKaye
      I followed this guide to set up my MagicMirror on a Raspberry Pi 3B+
      https://howchoo.com/g/ntcymzbimjv/how-to-install-magic-mirror-on-your-raspberry-pi
      I get 2 instances of magic mirror that run every time. any way to remove one of them?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @AyeKaye
        @ayekaye
        Are your instances mm, and the other, MagicMirror ?
        Here is how to delete one, but the choice is yours.
        pm2 stop mm
        pm2 delete mm
        pm2 save
        rm ~/mm.sh
        Then check your instances again
        • A
          AyeKaye
          They are both labeled MagicMIrror2 and they both will automatically re-start if I quit them with CTRL+Q.
          • A
            AyeKaye
            I think I fixed this. There was a file called mm.sh in the home directory, I moved it to the trash and I only see one instance now. I’m guessing there is something already starting Magic Mirror someplace else?
            • Mykle1M
              @ayekaye
              Uhhh
              • A
                AyeKaye
                Not sure. I am new to all this, but that is what I did and it works now. Thanks for the help.
                  ByronJames
                  I had the situation where whenever I turned off the monitor and later turned it back on. MM would load a second instance of the server. Took me a while to figure out that it was the HDMI port that was the culprit. I was using a 32 inch Vizio TV and HDMI2. In trying to figure out why this was happening I tried another monitor and it worked correctly when turned on and off. So FYI it may be that the HDMI port that you are using is sending a signal to the MM software to reload the server when it is turned on again.
                  For clarification I am NOT turning off/on the server just the display.
                  Hope this helps someone else
                    sdetweil @ByronJames
                    @ByronJames never seen this happen
                    What OS is this??
                    Technically a second instance should fail as the port is in use by the first instance.
