    MMM-WeatherChart
    42 Posts 16 Posters 36.3k Views 15 Watching
    • G Offline
      gshimself
      Yea, as I thought. The chart just piles up and doesn’t update. The script however does update.
        paphko @gshimself
        @gshimself I added a dummy parameter (timestamp) to the image which should prevent caching. I’ll check that later today when I find some time.
          paphko
          The module appends ‘#’ to the image so that the browser does not cache the image. This works on my old version of the mirror but not on the new version 2. Quite strange…
          Fixed by replacing this part with ‘?’, at least for Chrome browser, the image is not cached any longer. @gshimself please pull changes and report wether it is also fixed for you.
          G 2 Replies Last reply Reply Quote 0
          • G Offline
            gshimself @paphko
            @paphko ¨Perfect! Will pull the latest version when I get home. I’ll get back to you during the evening.
              amanzimdwini
              I like it!
              Request: can you add a SCALE factor? Right now the image is considerably larger than I can accommodate… (yes, minor problem, I know). Maybe I have to mess with the custom.css?
              Anyway, apart from that small inconvenience, I like it.
              • G Offline
                gshimself @paphko
                @paphko Seems to be working fine now. Thank you for your help!
                I guess that if I want 30min refreshrate it should be 60 * 30 * 1000,?
                  paphko
                  @gshimself glad to hear that it’s fixed for you. Yes, because update interval must be specified in ms.
                  @amanzimdwini you could try to add a scale option, but I’m not sure how to properly implement it for both cases, with and without border. If you found a proper solution for it, tell me or create a pull request :-)
                    racampbellky
                    Great module! Is there anyway to present in Fahrenheit?
                      paphko @racampbellky
                      @racampbellky I don’t think so. But you may check the website of yr.no, maybe you find a setting to use Fahrenheit in that diagram: http://www.yr.no/place/United_States/New_York/New_York/hour_by_hour.html
                      If so, it should be possible.
                        AxLed Module Developer
                        i wanted to try the module today, but i dont work i get some error “del missing” or similar.
                        Could it be that there is the file package.json missing on the github link, as there are some depencies in node_helper.js
                        var http = require('http');
                        var fs = require('fs');
                        var del = require('del');
                        var request = require('request');
                        var NodeHelper = require("node_helper");
                        Greets AxLED
                          found a solution myself, there is a fork of this module: https://github.com/szech/mmm-weatherchart
                          Installation:
                          cd ~/MagicMirror/modules
                          git clone https://github.com/szech/mmm-weatherchart.git
                          cd mmm-weatherchart
                          npm install
                          Greets
                          AxLED
                            Stellanova
                            If you replace grayscale with hue-rotate(190deg) in the mmm-weatherchart.js. You get the colors partially back and still have whitelines.
                            if (this.config.negativeImage) {
                            img.style[“-webkit-filter”] = “invert(100%) hue-rotate(190deg)”;
                            • V Offline
                              Vauxdvihl
                              @Stellanova said in MMM-WeatherChart:
                              is there a possibility to increase the size?
                              Thanks a lot
                              Regards
                                broberg Project Sponsor
                                @Vauxdvihl
                                Yes, But it will get fuzzy since the original image is only 828 × 272 pixels in size.
                                increase by 25%
                                .MMM-WeaterChart img{
                                width: 1035px !important;
                                height: 340px !important;
                                (To be clear, this go in to the custom.css file, not changing the module files)
                                • V Offline
                                  Vauxdvihl
                                  @broberg
                                  hmm
                                  seems to me not working
                                  Strange is also that the editor does not “hightlight” the functions
                                  .mmm-weatherchart img{
                                  width: 1035px;
                                  height: 340px;
                                    broberg Project Sponsor @Vauxdvihl
                                    @Vauxdvihl the module name is case sensitive
                                    So .mmm-weathermodule is not the same as .MMM-WeatherModule
                                    And you might have to add !important after the height and width for it to override the height specified in the module.
                                    • V Offline
                                      Vauxdvihl
                                      @broberg
                                      Yes i know ;-)
                                      Look …i though it would be the correct way
                                        @Vauxdvihl
                                        It is, nevermind the above post then.
                                        but do try the !important addition, it is sometimes needed when the size is defined in the document and not in the css files.
                                          prototype0815
                                          I need help with mmm-weatherchart:
                                          https://forum.magicmirror.builders/topic/12204/black-screen-when-insert-https-github-com-paphko-mmm-weatherchart/3
                                            sdetweil @prototype0815
                                            @prototype0815 I reqplied in your other topic with instructions to download my fixed repo that resolves both problems… black screen and no image shown
