Black screen after some hours
@fidst Try to execute
pm2 log mm. This will give you the log of the MacigMirror Instance. Post the log here if the black screen occures. (You may check for any sensible information from other modules) -
Hi all,
I’m facing exactly the same problem on my RPi3. The screen is all black and shows only the mouse arrow. I can access the MMM-RemoteControl from a separate notebook or mobile and it is possible to remotely restart the MM software to bring everything back to normal.
With a connect mouse you can move the mouse pointer but still there is a black screen. below please find the result after typingpm2 log mm/home/pi/.pm2/logs/mm-error-0.log last 15 lines: 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12) 0|mm | TypeError: Cannot read property 'hash' of null 0|mm | at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31 0|mm | at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10) 0|mm | at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21) 0|mm | at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16) 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12) 0|mm | fatal: unable to access 'https://github.com/jclarke0000/MMM-MyWeather.git/': Operation timed out after 300010 milliseconds with 0 out of 0 bytes received 0|mm | 0|mm | fatal: unable to access 'https://github.com/raywo/MMM-PublicTransportHafas.git/': Operation timed out after 300039 milliseconds with 0 out of 0 bytes received 0|mm | 0|mm | Whoops! There was an uncaught exception... 0|mm | TypeError: Cannot read property 'hash' of null 0|mm | at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31 0|mm | at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10) 0|mm | at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21) 0|mm | at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16) 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12) 0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | Whoops! There was an uncaught exception... 0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | TypeError: Cannot read property 'hash' of null 0|mm | at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31 0|mm | at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10) 0|mm | at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21) 0|mm | at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16) 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12) 0|mm | Whoops! There was an uncaught exception... 0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | TypeError: Cannot read property 'hash' of null 0|mm | at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31 0|mm | at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10) 0|mm | at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21) 0|mm | at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16) 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12) 0|mm | Whoops! There was an uncaught exception... 0|mm | TypeError: Cannot read property 'hash' of null 0|mm | at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31 0|mm | at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10) 0|mm | at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21) 0|mm | at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16) 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12) 0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | Whoops! There was an uncaught exception... 0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | TypeError: Cannot read property 'hash' of null 0|mm | at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31 0|mm | at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10) 0|mm | at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21) 0|mm | at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16) 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12) 0|mm | Whoops! There was an uncaught exception... 0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | TypeError: Cannot read property 'hash' of null 0|mm | at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31 0|mm | at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10) 0|mm | at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21) 0|mm | at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16) 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12) 0|mm | Whoops! There was an uncaught exception... 0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | TypeError: Cannot read property 'hash' of null 0|mm | at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31 0|mm | at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10) 0|mm | at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21) 0|mm | at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16) 0|mm | at emitTwo (events.js:106:13) 0|mm | at ChildProcess.emit (events.js:191:7) 0|mm | at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)in the log is written… Maybe no Internet connection? but this is definitely not true…
Anybody an idea why this happens?
Same Problem here. New MagicMirror Setup with a Raspberry Pi 2 and USB-Wifi.
The Error Message is similar. It seems to lost the Internet Connection and the screen goes blank/black.
No Solution so far. -
Same behavior on RPI3, black screen after few hours, I’ve tried almost all version of electron described on the linked thread, no workaround found.
Same here. I turned down the updatenotification module. See if this helps. Will keep you posted.
3rd day. No black screen anymore. I think we identified the root cause.
@rak
I’ll give it a try and remove the update module. But it will take some more days since I’m traveling over the weekend… -
I’ve already disabled the update notification module, nothing has changed.
For me it runs stable since removing the update module.
I updated our mirror to 2.4.1 about 2 weeks ago… since the new software is running we don’t see black screen anymore…
