    Black screen after some hours
    19 Posts 11 Posters 12.4k Views 13 Watching
    • idoodlerI Offline
      idoodler Module Developer @fidst
      @fidst Try to execute pm2 log mm. This will give you the log of the MacigMirror Instance. Post the log here if the black screen occures. (You may check for any sensible information from other modules)
      • O Offline
        onkelbobby
        Hi all,
        I’m facing exactly the same problem on my RPi3. The screen is all black and shows only the mouse arrow. I can access the MMM-RemoteControl from a separate notebook or mobile and it is possible to remotely restart the MM software to bring everything back to normal.
        With a connect mouse you can move the mouse pointer but still there is a black screen. below please find the result after typing pm2 log mm
        /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
        0|mm       |     at emitTwo (events.js:106:13)
        0|mm       |     at ChildProcess.emit (events.js:191:7)
        0|mm       |     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
        0|mm       | TypeError: Cannot read property 'hash' of null
        0|mm       |     at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31
        0|mm       |     at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10)
        0|mm       |     at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21)
        0|mm       |     at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16)
        0|mm       | fatal: unable to access 'https://github.com/jclarke0000/MMM-MyWeather.git/': Operation timed out after 300010 milliseconds with 0 out of 0 bytes received
        0|mm       |
        0|mm       | fatal: unable to access 'https://github.com/raywo/MMM-PublicTransportHafas.git/': Operation timed out after 300039 milliseconds with 0 out of 0 bytes received
        0|mm       |
        0|mm       | Whoops! There was an uncaught exception...
        0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        in the log is written… Maybe no Internet connection? but this is definitely not true…
        Anybody an idea why this happens?
        • V Offline
          Voteax
          Same Problem here. New MagicMirror Setup with a Raspberry Pi 2 and USB-Wifi.
          The Error Message is similar. It seems to lost the Internet Connection and the screen goes blank/black.
          No Solution so far.
            prysme01
            Same behavior on RPI3, black screen after few hours, I’ve tried almost all version of electron described on the linked thread, no workaround found.
              rak
              Same here. I turned down the updatenotification module. See if this helps. Will keep you posted.
                rak @rak
                3rd day. No black screen anymore. I think we identified the root cause.
                • O Offline
                  onkelbobby @rak
                  @rak
                  I’ll give it a try and remove the update module. But it will take some more days since I’m traveling over the weekend…
                    prysme01
                    I’ve already disabled the update notification module, nothing has changed.
                      rak
                      For me it runs stable since removing the update module.
                      • O Offline
                        onkelbobby @rak
                        I updated our mirror to 2.4.1 about 2 weeks ago… since the new software is running we don’t see black screen anymore…
                          CarstenD
                          Running 2.4.1 and getting the black screen after some time. Pi is still accessible and PM2 restart mm makes it work again.
                          How do you disable the update notification module?
                            bhepler Module Developer @CarstenD
                            @carstend - Just remove it from your config.js. Take out everything between the {...} that surrounds the notification module and save the file. Restart the MagicMirror process and you should be good to go.
                            • T Offline
                              thejoaovitor
                              I have exactly the same problem with my Pi 3, similar error log. After removing the notification module from my config.js and it seems to be workinkg correctly now.
                                CarstenD
                                Disabling the notification module did not change the problem. I solved it finally by going through (1) removing and (2) reinstalling screensaver and then (3) disabling screensaver again. Even though for me there is no logical explanation doing it that way, the problem has gone away.
                                • MarosM Offline
                                  Maros
                                  how do you remove and reinstall screen saver ? can you give me commands ?
                                  i’ve tried
                                  sudo apt-get remove xscreensaver
                                  but it just gives me that no xscreensaver isn’t installed.
                                  • T Offline
                                    thejoaovitor
                                    A solution, (not perfect) is to use MMM-WatchDog, it keeps an eye on your UI and quits app in case the UI crashes, combined with the PM2 process manager, MM2 will automaticly restart after a UI failure.
                                    https://github.com/MichMich/MMM-WatchDog
