    Black screen after some hours
    19 Posts 11 Posters 12.5k Views 13 Watching
      rak @rak
      3rd day. No black screen anymore. I think we identified the root cause.
      • O
        onkelbobby @rak
        @rak
        I’ll give it a try and remove the update module. But it will take some more days since I’m traveling over the weekend…
          prysme01
          I’ve already disabled the update notification module, nothing has changed.
            rak
            For me it runs stable since removing the update module.
            • O
              onkelbobby @rak
              I updated our mirror to 2.4.1 about 2 weeks ago… since the new software is running we don’t see black screen anymore…
                CarstenD
                Running 2.4.1 and getting the black screen after some time. Pi is still accessible and PM2 restart mm makes it work again.
                How do you disable the update notification module?
                  bhepler Module Developer @CarstenD
                  @carstend - Just remove it from your config.js. Take out everything between the {...} that surrounds the notification module and save the file. Restart the MagicMirror process and you should be good to go.
                  • T
                    thejoaovitor
                    I have exactly the same problem with my Pi 3, similar error log. After removing the notification module from my config.js and it seems to be workinkg correctly now.
                      CarstenD
                      Disabling the notification module did not change the problem. I solved it finally by going through (1) removing and (2) reinstalling screensaver and then (3) disabling screensaver again. Even though for me there is no logical explanation doing it that way, the problem has gone away.
                      • MarosM
                        Maros
                        how do you remove and reinstall screen saver ? can you give me commands ?
                        i’ve tried
                        sudo apt-get remove xscreensaver
                        but it just gives me that no xscreensaver isn’t installed.
                        • T
                          thejoaovitor
                          A solution, (not perfect) is to use MMM-WatchDog, it keeps an eye on your UI and quits app in case the UI crashes, combined with the PM2 process manager, MM2 will automaticly restart after a UI failure.
                          https://github.com/MichMich/MMM-WatchDog
