    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 578.0k Views 43 Watching
    • I
      ianperrin @MichMich
      @MichMich said in Soccer Standings:
      @ianperrin Absolutely! 🎉
      Version 1 done - see https://forum.magicmirror.builders/topic/463/formula-1-standings
      “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        darkeagl105
        Hello, I jsut installed the soccer module and I have a problem with the size.
        Setup:
        RP1+
        jessi lite
        node serveronly (node.js 4.x.x)
        midori browser kiosk mode
        SCreenshot
        As I understood it is the same build as the olympic which is working perfectly as do the weather modules, which I just disabled to show the false size. Any ideas.
        It is a fresh install, just configured the autostart for midori etc and the mirror. Havent done anything else.
        Thank you
        PS: when I open the website on another pc or somewhere else the layout is fine (browser chrome).
        • strawberry 3.141S
          Propably your Region has not enough Space on this Monitor, Maybe it’s working for you if you exchange the Region with an other Module.
          Solution would be then to exchange flexbox with Standard html table
            darkeagl105
            I even tried to move it arount, for example where the olympic one is and still the same problem :(
            strawberry 3.141S 2 Replies Last reply Reply Quote 0
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @darkeagl105
              @darkeagl105 no worries i will fix it tonight
              • strawberry 3.141S
                @darkeagl105 can you please test the newest version if it fixes you problem?
                Changelog:
                exchanged flexbox with table to support smaller screens
                added i18n for english and german
                replaced icons with font-awesome
                D 1 Reply Last reply Reply Quote 2
                  darkeagl105 @strawberry 3.141
                  @strawberry-3.141 thank you just updated and it working now. How did you do the graduation? All 5 teams are for me on position 1 because the season hasn started yet and all in the same focus. Will this change?
                  • strawberry 3.141S
                    @darkeagl105 it’s done from the api after the first matchday this should be fixed automatically
                      plumcraft
                      Very nice module :)
                      thanks
                        McSorley
                        If I were to find an API for the Scottish football league could I use it with this?
                        • strawberry 3.141S
                          I looked into this api and scotland is not supported
                          I think that you will get your data in a different structure, so you can’t use this module for it as it is, but you can adjust this module for your needs :)
                            McSorley
                            I see that the API supports champions league. Ive added Champions to the league list with id 440 but it seems that it gets stuck in a loading screen.
                            Perhaps cause there has been no games yet?
                            Was looking to isolate a certain group in the champions league, group C, any advise on making amendments?
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @McSorley
                              @McSorley there is no cup support yet, the data for cups look different than for leagues
                                Mitchfarino Module Developer
                                When I attempt to use focus_on in the config, no data is displayed in the table
                                Is this correct or does the readme need updating?
                                module: ‘MMM-soccer’,
                                position: ‘bottom_left’,
                                api_key: ‘’,
                                show: ‘ENGLAND’,
                                focus_on: {‘ENGLAND’:‘LIVERPOOL’},
                                max_teams: 10,
                                leagues: {‘ENGLAND’: 426}
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
                                  @Mitchfarino you provided a wrong teamname, it should be in your case 'Liverpool FC' and I suggest to remove the api_key and leagues line from config, because that are the default values anyways and therefore are not needed in the config
                                      module: 'MMM-soccer',
                                      position: 'bottom_left',
                                          show: 'ENGLAND',
                                          focus_on: {
                                              'ENGLAND': 'Liverpool FC'
                                          max_teams: 10
                                    Mitchfarino Module Developer @strawberry 3.141
                                    @strawberry-3.141 I do have an API key, don’t I need it? I just blanked it out for my post
                                    Thanks for your reply and module
                                    • strawberry 3.141S
                                      @Mitchfarino well when you have one, you can insert it again, this will force the module to refresh more often ;)
                                        Just been looking at your NFL module, it’s incredible!
                                        Is there anyway you could implement something similar for fixtures/live games in the soccer module?
                                        strawberry 3.141S 1 Reply Last reply Reply Quote 1
                                        • strawberry 3.141S
                                          @Mitchfarino when i get my voice recognition in a stable version I want to upgrade a couple of my modules like fixtures for this one, but currently there is a big issue, so it can take a while
                                          • strawberry 3.141S
                                            [card:fewieden/MMM-soccer]
                                            Changelog:
                                            Implemented voice commands to switch the leagues on the fly
                                            alt text
                                            • 10
                                            • 11
                                            • 2 / 11
