    PIR sensor behind glass?
    65 Posts 16 Posters 117.1k Views 19 Watching
      RedNax Module Developer @yo-less
      @yo-less Thanks!
      The mirror is from a dutch webshop… At night, when there’s no other illumination you do see the backlight of the screen shining through… In the daytime it looks like the picture.
      I’ve been pondering altering the backlight/brightness of the screen according to ambiant lightlevels… unfortunately this is only controllable by navigating the screens menu as opposed to discrete buttons…
      Oh, and yes… there is: https://github.com/RedNax67/DailyXKCD
      It’s forked from the original author… Ive added the random comic on non comic days…
      Y 1 Reply Last reply
      • Y
        yo-less Module Developer @RedNax
        @RedNax Alright, is that the case with all types of glasses? I guess it would be?
        R 1 Reply Last reply
          @yo-less It think all mirrors suffer from this… You need enough brightness to show things in the day… Which will be overkill at night…
          • Y
            @RedNax Apparently some monitors seem to allow for external commands to change the light levels:
            http://lifehacker.com/5985364/change-your-monitors-brightness-without-fiddling-with-its-buttons
            They seem to have to support DDC/CI and if there is a tool for Windows PCs there should be some way to get the same thing done on a Pi?
            • cowboysdudeC
              cowboysdude Module Developer @yo-less
              @yo-less said in PIR sensor behind glass?:
              Can a PIR sensor be covered by anything at all or does any kind of material automatically block motion detection?
              You really can’t cover a PIR it just won’t work… BUT you can remove the ‘dome’ and incorporate into the frame a little better OR you can just put it into the frame with the ‘dome’ on it and make it decorative…
              • cowboysdudeC
                @yo-less changing the brightness would be really nice… having it automatic would be better… you know at a certain time of night it dims automatically… but there is this…
                https://github.com/xflux-gui/xflux-gui
                • Y
                  yo-less Module Developer @cowboysdude
                  @cowboysdude Thanks for the link. Does f.lux have access to the monitor’s brightness settings? As this has nothing to do with my original question I will start a new topic concerning the brightness issue at night.
                  • Y
                    @cowboysdude We might just drill a tiny hole into the frame of the mirror and put the PIR behind it without its Fresnel cover. Will experiment with that idea some more.
                    • Y
                      yawns Moderator @yo-less
                      That’s the approach I was thinking of. Which PIR will you use?
                      • Y
                        yo-less Module Developer @yawns
                        @yawns I’ve got the HC-SR501 / D-SUN RCW-0506 and it’s working as it should.
                        I paid €8 for two sensors and shipping to Germany. The one in use even survived my failed attempts at connecting it to the correct pins :).
                        • cowboysdudeC
                          I just like the camera… it’s a personal choice :) But drilling a hole will work too!! I don’t see a thing wrong with that!
                          • Y
                            @cowboysdude I’m just not comfortable with the idea of a camera in my bathroom (or any other room, for that matter). Raspbian is a pretty open platform and I don’t want others to take control of any cameras I might have installed in my home. And it’s not like all sorts of people wouldn’t be interested in spying on other people.
                            Have started experimenting with the PIR sensor, it’s looking good so far, will let you guys know about my progress.
                            Reply Quote 2
                              dmcinnes Module Developer
                              Another possibility: I ordered a couple of these $2 microwave radar motion detectors to see if they will work behind my glass. Still waiting to receive them though:
                              http://m.ebay.com/itm/1pc-5-8GHZ-Microwave-Radar-Sensor-6-9M-Smart-Switch-for-Home-Control-/131864712562?txnId=1245760396003
                              More details:
                              http://www.cnx-software.com/2016/04/04/tiny-microwave-radar-module-detects-movements-up-to-9-meters-away-for-2/amp/
                              • Y
                                yawns Moderator
                                Wow, the microwave approach sounds good. Will this work behind the mirror?
                                D 1 Reply Last reply
                                • Y
                                  @dmcinnes Thanks for your link, I’m using a radar module in a Pi-independent LED lighting control unit that a friend of mine put together (So I have no clue how his circuits actually work, but they do and that’s great :D), which is why my first impulse was to use a radar motion detector as well.
                                  I couldn’t find any that operated within the voltage specifications of the PI’s pins. Your link lists a working voltage range of 5.5 - 18 V DC, but the Pi only offers 5 V DC, doesn’t it?
                                  So are you planning on using an external power source for your module?
                                    Hmm I’ve seen othe specs that say working voltage is 3.3-20VDC… hopefully that’s more accurate. In any case I’ll try it with the 5V from the PI and go from there.
                                    Y K 2 Replies Last reply
                                      dmcinnes Module Developer @yawns
                                      @yawns I’ve read that microwave sensors will work behind glass, but I’m not sure if it will work behind the semi-mirrored surfaces we’re using.
                                      • Y
                                        yo-less Module Developer @dmcinnes
                                        @dmcinnes It’s great that you’re experimenting with this in any case. Please let us know the outcome once the sensor has arrived.
                                        • K
                                          KirAsh4 Moderator @dmcinnes
                                          To anyone asking: ‘working voltage’ just means it will work with voltages within that range, so from as low as 3v3 up to 20v.
                                          • Y
                                            Alright, everyone. I said I would start experimenting with the PIR sensor and experiment I did.
                                            So first of all we started drilling a hole of diameter 8mm into one side of a piece of wood
                                            (we went 5mm deep as this corresponds with the height of the cylindrical sensor):
                                            This is not all we did, as you can see, we also drilled a hole of diameter 3mm on the other side,
                                            but this time we made sure it went all the way through:
                                            Next, we removed the Fresnel lens from the sensor:
                                            After that, we put the sensor in the bigger hole which perfectly houses the whole cylinder:
                                            Then we waited to see whether the mirror would turn itself on if we moved past the piece of wood.
                                            And, hooray, it did!
                                            Emboldened by this discovery, we started all over again, but this time with smaller holes on the other side,
                                            so we ended up with this setup:
                                            Simply ignore the rubber band, it’s there to hold the circuit board in place :)
                                            Anyway, here’s the good news: The mirror recognizes somebody walking by if the hole is as small as 2 millimeters in diameter.
                                            It did not work with a 1mm hole, but hey, are we living in a perfect world? :D
                                            Anyway, this solution is good enough for me, we will drill a 2mm hole in the bottom center area of the mirror frame and hide the sensor behind it.
                                            I’m thinking we might even be able to make the hole less apparent by choosing a piece of wood similar to the one above
                                            with some nice-looking wood grain and / or knots.
                                            Reply Quote 7
                                            • 2 / 4
