    EyeCandy and out-of-memory
    12 Posts 6 Posters 7.7k Views 5 Watching
      chef
      I also used eye candy! it’s great! but unfortunately, yeah, it runs up the memory, and in my case crashes the display… I have since commented out the plugin in my config, but that plugin is top shelf man! love it!!
      • N
        njw @Mykle1
        @Mykle1 I realize it’s not the most … informative… of modules, but I was playing around with the idea of combining it with face recognition, to show the freakish eye when it’s someone it doesn’t recognize :).
        This was with the new electron version and the GL drivers. I had some of the other eye candy URLs on the screen for a day or so, playing around and no issue. However, just that particular selection it would crash in about 10 minutes. Weird. Possibly the memory usage was high on the others - I didn’t do any debug until it broke, of course.
        I’m happy to play around with more debugging.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @njw
          @njw
          By all means, do what you will with it, and most of all, have fun! :-)
          • cowboysdudeC
            Also have to remember that the pi is limited in just about every way…
              maxbachmann
              Especially remember that electron and gifs are really a bad combination especially on the raspeberry pi since it does not use hardware acelleration :unamused_face:
                chef
                I had thought about using an intervalTimer which showed a list of images in succession, but I think that would be worse than a GIF for the Raspi. :zipper-mouth_face:
                  sdetweil @chef
                  @chef i have been using MMM-ImagesPhotos or MMM-ImageSlideshow and don’t see the out of memory issue… don’t have any gifs in the image list tho
                    maxbachmann
                    When you directly display MM2 on your raspberrypi you could do an overlay with omxplayer. it supports hardware acceleration which makes it run really smooth with gifs
                    C 1 Reply Last reply
                      chef @maxbachmann
                      @maxbachmann that’s a really great idea. I noticed that is how some of the Security Camera MM2 modules work.
                        maxbachmann
                        np had the same problem and figured I could solve it that way ;)
