    Black screen after MM v2.4.0 update.
    32 Posts 17 Posters 21.6k Views 17 Watching
    • KimzerK Offline
      Kimzer @Kimzer
      @kimzer replying to myself. I just had to chmod the new pir script i made to make it work duhhh. :p
        bwente @joela85
        @joela85
        Are you using MMM-PIR-Sensor?
        https://github.com/paviro/MMM-PIR-Sensor/issues/49
        I needed to delete the node_modules directory first. Then I ran npm install and the issue was gone.
        joela85J 1 Reply Last reply Reply Quote 0
        • joela85J Offline
          joela85 @bwente
          @bwente
          I’m not currently using MMM-PIR-Sensor.
          My problem was Enabling the Open GL driver. Using “dtoverlay=vc4-kms-v3d” or “dtoverlay=vc4-fkms-v3d” did not work. Remove the line and it was fine. (Temps seem reasonable 62deg)
          "Enable the Open GL driver to decrease Electron’s CPU usage.
          The latest versions of electron use an extreme amount of CPU power when no Open GL driver is loaded. This will result in an overheating Raspberry Pi. To solve this issue, use the experimental desktop Open GL driver by adding the following line to /boot/config.txt:
          sudo nano /boot/config.txt
          Add the following line:
          ℹ️ Activating the Open GL drive can also be accomplished by using the raspi-config tool by running sudo raspi-config. Go to the Advanced Options menu and select A7 GL Driver. Next, select the G1 GL (Full KMS) OpenGL desktop driver with full KMS. Note that this option will be selected in the menu even when the GL drive is not yet configured."
          Not sure what the issue is. But at least it works.
            shane1234
            Ok, I cheated a little bit and completly wiped my SD card. Reinstalled Raspian, Magic Mirror and everything else from scratch, working great now!
            • T Offline
              thenameiwantedwastaken
              I got mine working by following the advice in the second post on this thread:
              https://github.com/paviro/MMM-PIR-Sensor/issues/39
              Hope that helps others too.
              • bheplerB Offline
                bhepler Module Developer @joela85
                @joela85 - I found that if you pull the SD card and plug it into a windows box, you can access the /boot path. That will allow you to edit the /boot/config.txt file and comment out the dtoverlay line. Edit in WordPad. Do not edit in Notepad.
                Save the file, eject the SD card, put it back into your Pi. You should be able to SSH into your Pi once it boots.
                I haven’t tried this procedure using an Ubuntu box, but it most likely will work.
                • joela85J Offline
                  joela85 @bhepler
                  @bhepler Ye, I had a play around last week and managed to do just this. All back up and running now.
                  Thank you for the reply though.
                  Regards,
                  Joel
                  • 3 / 4
