    MMM-EARTH - config options
    11 Posts 3 Posters 5.7k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @evroom
      @evroom
      Let me guess. You’re using a Pi. Those settings won’t work on a Pi. It simply cannot handle the animation. I don’t use Pi’s anymore, preferring laptop boards.
      • evroomE Offline
        evroom
        You are not allowed to guess anymore :-)
        Yes, I use a PI, I think most people use a PI to start with and then things get out of control (MagicModuleVirus).
        What starts with 4 MM modules, ends up with juggling a whole bunch of modules on a ‘tiny’ monitor (for me a 900x1600 resolution).
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
          @evroom
          Exactly. However, in my case, with a laptop board i can have just about as many modules as I like loaded, using pages of modules to display via voice command. Those not displayed at the moment are suspended and I never run out of room. I just set up new pages.
          • justjim1220J Offline
            justjim1220 Module Developer @Mykle1
            @mykle1
            I am needing some assistance with setting up pages… cant seem to figure out what I’m doing wrong, keeps showing all the modules on the main page and it doesn’t change when I change the pages… maybe you could point me in the right direction???
            "Life's Too Short To Dance With Ugly People"
            Jim Hallock - 1995
              Mykle1 Project Sponsor Module Developer @justjim1220
              @justjim1220
              Are you referring to Hello-Lucy pages? If so, then this comes directly from the Hello_Lucy README.
              How to add Pages of modules
              At about line 443 in the new node helper of MMM-voice you’ll see this:
              /////////  Pages commands @ Mykle ///////////////////////////
              		else if (/(SHOW)/g.test(data) && /(PAGE)/g.test(data) && /(ONE)/g.test(data)) {
                          this.sendSocketNotification('SHOW_PAGE_ONE');
                      } else if (/(HIDE)/g.test(data) && /(PAGE)/g.test(data) && /(ONE)/g.test(data)) {
                          this.sendSocketNotification('HIDE_PAGE_ONE');
              You have to add one of these for every page your create. Change the page numbers!
              At about line 116 in the new MMM-voice.js file you’ll need to add your sentence. In this case:
              'HIDE PAGE ONE',
              'SHOW PAGE ONE',
              Still in the new MMM-voice.js file at about line 370 you’ll need to add your set of modules for the page you just created. In this case, it looks like this:
              		 else if (notification === 'SHOW_PAGE_ONE') {
              			 this.sendNotification('HIDE_LUCY');
              			 this.sendNotification('SHOW_LOTTERY');
              			 this.sendNotification('SHOW_CLOCK');
              			 this.sendNotification('SHOW_EARTH');
              			 this.sendNotification('SHOW_LICE');
              			 this.sendNotification('SHOW_COWBOY');
              			 this.sendNotification('SHOW_TIDES');
              			 this.sendNotification('SHOW_VOICE');
              		 } else if (notification === 'HIDE_PAGE_ONE') {
              			 this.sendNotification('HIDE_LOTTERY');
              			 this.sendNotification('HIDE_CLOCK');
              			 this.sendNotification('HIDE_EARTH');
              			 this.sendNotification('HIDE_LICE');
              			 this.sendNotification('HIDE_COWBOY');
              			 this.sendNotification('HIDE_TIDES');
              			 this.sendNotification('HIDE_VOICE');
                @mykle1
                Actually, no, not for Lucy, That is well explained! :winking_face:
                I’m referring to the MMM-page-selector
                But I switched to MMM-pages which is way better explained and much easier to use!
                (Thanks @edward-shen for making it so easy and well explained!!! :winking_face: )
                Jim Hallock - 1995
