MMM-Jnews
@jeffreyking -
Just in case nobody else mentions it, you should delete the advice in the square brackets from yourconfig.js
file. The part that looks like this:[default is false, Raspberry Pi's don't like the images]
Delete in the part in the square brackets from the next line as well. They are commentary from the developer.
@bjoern I do and I will look at it :)
All working now just had to place a position line in thanks you so much.
How can I make the module larger thank you
@jeffreyking add this to your custom.css file
.MMM-Jnews .flex-item { font-size: 22px; }
Make the font-size whatever you want :)
Thank you what about the picture
custom.css
.MMM-Jnews .image { width: 90%; height: 90%; border-style: solid; border-color: #92a8d1; }
Be careful with that as the space provided will over write your text…so just trial and error.
This is nice! Thank you!
Quick question regarding your note on your github page. Ive only had a mirror for maybe 2 weeks, its running on a pi 3b+. I have a good amount of moduiles, but not all showing all the time and my pi sits around 55-60c .
Would it be better to run the magic mirror software on an ubuntu vm and just use fullpageos or something similar on the pi? Im not sure if that would take most the processing away from the pi or not?
@darbos mine runs on a mini itx board so I can pretty much do what I want.
If you want the basic MM then the PI is fine but if you want more you have to think bigger. ;)
