    MMM-Jnews
    Scheduled Pinned Locked Moved Education
    33 Posts 10 Posters 23.4k Views 8 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @cowboysdude
      @cowboysdude
      You know I just had to give you some sh** a little bit.
      It is a nice module, as I suspected, no way to get local news without making some changes to your code.
      I really like the set up though.
      Great job! (as usual!) :grinning_face: :grinning_face: :grinning_face:
      Jim Hallock - 1995
      • cowboysdudeC Offline
        cowboysdude Module Developer @justjim1220
        @justjim1220 said in MMM-Jnews:
        @cowboysdude
        Yes it’s news from a bunch of different sources all brought together…
          @cowboysdude said in MMM-Jnews:
          I’m getting just a little bit tired of all your success. ;-)
            bjoern
            Great module. I like it. Question: Some lines of text consist of 3 lines and the next message is 4. As a result, the modules above will always jump “up and down”. Can you set the module to 4 lines and these automatically fill depending on the content? Do you understand what I want to express?
              bhepler Module Developer @jeffreyking
              @jeffreyking -
              Just in case nobody else mentions it, you should delete the advice in the square brackets from your config.js file. The part that looks like this: [default is false, Raspberry Pi's don't like the images]
              Delete in the part in the square brackets from the next line as well. They are commentary from the developer.
                cowboysdude Module Developer @bjoern
                @bjoern I do and I will look at it :)
                  cowboysdude Module Developer @bhepler
                  @bhepler Changed the README.md as this has happened more than once LOL
                    jeffreyking
                    All working now just had to place a position line in thanks you so much.
                      jeffreyking
                      How can I make the module larger thank you
                        cowboysdude Module Developer @jeffreyking
                        @jeffreyking add this to your custom.css file
                               .MMM-Jnews .flex-item {
                                font-size: 22px;
                        Make the font-size whatever you want :)
                          jeffreyking
                          Thank you what about the picture
                            @jeffreyking
                            custom.css
                              .MMM-Jnews .image {
                            width:  90%;
                            height:  90%;
                            border-style: solid;
                            border-color: #92a8d1;
                            Be careful with that as the space provided will over write your text…so just trial and error.
                              darbos
                              This is nice! Thank you!
                              Quick question regarding your note on your github page. Ive only had a mirror for maybe 2 weeks, its running on a pi 3b+. I have a good amount of moduiles, but not all showing all the time and my pi sits around 55-60c .
                              Would it be better to run the magic mirror software on an ubuntu vm and just use fullpageos or something similar on the pi? Im not sure if that would take most the processing away from the pi or not?
                                cowboysdude Module Developer @darbos
                                @darbos mine runs on a mini itx board so I can pretty much do what I want.
                                If you want the basic MM then the PI is fine but if you want more you have to think bigger. ;)
                                  darbos
                                  I am just curious how much load is actually taken away from the pi if MM is actually running on a vm elsewhere(dell r720). I would think the pi is still gotta do some video processing correct?
                                  I am looking to add some “pages” specifically going to make it so I can tell google to show me my security cams and have all my normal modules fade away and bring the cameras up(12 outdoor). I would actually like to make a couple pages with different information to be able to do that. I love this thing, thank you for sharing your hard work! I see your a hard workin guy out here.
                                  I was lookin at those intel sticks possibly, I have never messed with one yet though. Ill take a look at the board you mentioned. Thanks
                                  btw, its really easy to integrate voice if you use homeassistant, just using the apis / mqtt / remote module. I was looking for a module for a while that would let me create pages instead of having to call each module out with remote, i just happened to stumble on to it today
                                    darbos
                                    those look nice, thanks! i had to write back so quick cause that got me really curious. Ive seen quite a bit of your posts scrollin through here, but I havent seen your mirror, would you mind sharing a peek?
                                      @darbos https://forum.magicmirror.builders/topic/1489/the-32-inch-mirror
                                      I’ll post some updated ones for you :) I have 2 actually…one in the bathroom and my 32" I put on the wall in the kitchen…
                                      Here are some videos
                                      https://www.youtube.com/user/TheCowboysdude/videos
                                        darbos @cowboysdude
                                        @cowboysdude Dang, thats sweet!! Im gonna have to try that voice out
                                        • O Offline
                                          Ob018
                                          Hi, thanks for your module.
                                          It works perfectly.
                                          • I was wondering if you could add a way to “force” a specific language ?
                                            ( my mirror language is English and i would love to read the French news )
                                          • Is there a way to display more than 1 article at a time ?
                                          Thanks.
                                          G.
                                          Y cowboysdudeC 2 Replies Last reply Reply Quote 0
                                          • Y Offline
                                            yawns Moderator @Ob018
                                            @ob018 said in MMM-Jnews:
                                            mh, you could try to use this:
                                            	module: 'MMM-Jnews',
                                            		lang: "fr",
                                            		apiKey: "YOUR API KEY",
                                            		image : true,
                                            		rotateInterval: 25 * 1000
