    MMM-Jnews
    Scheduled Pinned Locked Moved Education
    33 Posts 10 Posters 20.5k Views 8 Watching
    • cowboysdudeC Offline
      Description:
      A new way to see the news…with title and description in a neat little package!
      Please follow Readme on Github!
      Screenshots:
      Version 2.0.0
      Download:
      [card:cowboysdude/MMM-Jnews]
      justjim1220J 2 Replies Last reply Reply Quote 2
      • justjim1220J Offline
        justjim1220 Module Developer @cowboysdude
        @cowboysdude
        TOTALLY AWESOME!!!
        Hoping it works with my little podunk towns newspaper! BWAHAHAHAHA! :face_with_stuck-out_tongue_winking_eye: :face_with_stuck-out_tongue_winking_eye: :face_with_stuck-out_tongue_winking_eye:
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          @cowboysdude
          This might be a dumb question…
          Why am I needing the API for wunderground???
          Jim Hallock - 1995
            barnosch
            Guess its a classical Copy&paste error.
            One line above:
            Get your free API key here
            [https://newsapi.org/)
            Wunderground would make no sense here, you are right.
            I will give it a try. Looks nice.
              barnosch
              Do you plan to add more sources manually?
              Currently there are only the top-headlines implemented. Which is good enough.
              But, i would like to add some more (from the newsapi page) like wired or TechCrunch.
              edit:
              ok after testing i really would like to add the sources in an array maually if possible, since there are the very unuseful BILD news in the top-headlines.
              And some cosmetics stuff: the date stuff “1hour ago” and so on i static and not translated.
              No problem for me, just for the notes ;)
              Thanks for the module.
                cowboysdude Module Developer @barnosch
                @barnosch Feel free then do a pull request :) That would be pretty awesome!!
                  cowboysdude Module Developer @justjim1220
                  @justjim1220 Well because the wunderground key isn’t good for anything else so may as well try it here LOL
                  justjim1220J 1 Reply Last reply Reply Quote 2
                    jeffreyking
                    Hi I am new to this and I did so I think all that is to be done and it still do not work tell me to config.js file
                                             module: 'MMM-Jnews'
                    	                             apiKey: "my api",
                                                         image : true, [default is false, Raspberry Pi's don't like the images]
                                                         rotateInterval: 25 * 1000 [This is default set to 25 seconds, you can change this if you'd like]
                                             module: 'MMM-MovieListings',
                                                    position: 'top_center',   // This can be any of the regions. Best results in left or$
                    					apiKey: 'de1d0b92bb87bncbbbbbbbbbbbbbbbbbbbbbb9f7a57b',
                    					region: 'US',
                    					language: 'EN',
                    					interface: 'poster', //'list', 'poster', 'detailed'
                    					includeMoviePlot: false,
                    					maxPlotLength: 198,
                    					header: 'Movie Listings',
                    					moviesPerPage: 0,
                    					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                    					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                    					animationSpeed: 2.5 * 1000,
                    					pageChangeInterval: 35 * 1000
                    cowboysdudeC bheplerB 2 Replies Last reply Reply Quote 0
                      bjoern
                        cowboysdude Module Developer @jeffreyking
                        @jeffreyking said in MMM-Jnews:
                        module: ‘MMM-Jnews’
                        apiKey: “my api”,
                        image : true
                        OK first off you have to go to https://newsapi.org/ and get your api key…the key they give you has to go in between the quotes like this [for example]
                        apiKey : “aabjadjfadfas9adfajsdlfja”
                        The rest of the config should work for you as I’ve rewritten it… use the above example only go get the api and replace “my apikey” with “YOUR KEY” put in quotes that you get from the newsapi.org link :)
                          @cowboysdude
                          You know I just had to give you some sh** a little bit.
                          It is a nice module, as I suspected, no way to get local news without making some changes to your code.
                          I really like the set up though.
                          Great job! (as usual!) :grinning_face: :grinning_face: :grinning_face:
                          Jim Hallock - 1995
                            @justjim1220 said in MMM-Jnews:
                            @cowboysdude
                            Yes it’s news from a bunch of different sources all brought together…
                              @cowboysdude said in MMM-Jnews:
                              I’m getting just a little bit tired of all your success. ;-)
                                bjoern
                                Great module. I like it. Question: Some lines of text consist of 3 lines and the next message is 4. As a result, the modules above will always jump “up and down”. Can you set the module to 4 lines and these automatically fill depending on the content? Do you understand what I want to express?
                                • bheplerB Offline
                                  bhepler Module Developer @jeffreyking
                                  @jeffreyking -
                                  Just in case nobody else mentions it, you should delete the advice in the square brackets from your config.js file. The part that looks like this: [default is false, Raspberry Pi's don't like the images]
                                  Delete in the part in the square brackets from the next line as well. They are commentary from the developer.
                                    cowboysdude Module Developer @bjoern
                                    @bjoern I do and I will look at it :)
                                      cowboysdude Module Developer @bhepler
                                      @bhepler Changed the README.md as this has happened more than once LOL
                                        jeffreyking
                                        All working now just had to place a position line in thanks you so much.
                                          jeffreyking
                                          How can I make the module larger thank you
                                            @jeffreyking add this to your custom.css file
                                                   .MMM-Jnews .flex-item {
                                                    font-size: 22px;
                                            Make the font-size whatever you want :)
