    MagicMirror sleep in 5 minutes
    9 Posts 4 Posters 4.1k Views 4 Watching
    • matimilkoM
      matimilko
      Re: Power/Sleep Settings?
      Hi!
      I’m finishing my MagicMirror and have one problem. Raspberry is going to sleep after 10-15 minutes. Monitor is connected to electricity over moving sensor, so Monitor is after 12 min off power. When (moving sensor) turn on monitor, Raspberry is on idle so I have to move the mouse or keyboard to wake it.
      Is any possibility to set MagisMirror to be on all the time?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @matimilko
        @matimilko
        Have you disabled the screensaver? May I suggest installing xscreensaver? In the options of xscreensaver you can disable the screensaver altogether. When your monitor comes on, MM will be visible.
        matimilkoM 1 Reply Last reply
        Reply Quote 2
        • matimilkoM
          matimilko @Mykle1
          @mykle1 I’ll try that today :)
          • matimilkoM
            matimilko
            Great!
            I’ve done it with xscreensaver. Perfect.
            Thanks!!!
            Mykle1M A 2 Replies Last reply
            • Mykle1M
              @matimilko
              Fantastic! Now if you would mark the post that solved your issue. :-)
              yawnsY 1 Reply Last reply
              • yawnsY
                yawns Moderator @Mykle1
                @mykle1 said in MagicMirror sleep in 5 minutes:
                @matimilko
                I did that on behalf of @matimilko
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @yawns
                  @yawns said in MagicMirror sleep in 5 minutes:
                  That’s because you’re awesome! :-)
                  • A
                    asaxena11 @matimilko
                    @matimilko
                    Cold you please post the command you use after installing xscreensaver
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @asaxena11
                      @asaxena11
                      Simply type xscreensaver in your terminal and Enter. Click Settings and you choose your options here.
