    MagicMirror sleep in 5 minutes
    9 Posts 4 Posters 3.6k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @matimilko
      @matimilko
      Have you disabled the screensaver? May I suggest installing xscreensaver? In the options of xscreensaver you can disable the screensaver altogether. When your monitor comes on, MM will be visible.
      matimilkoM 1 Reply Last reply Reply Quote 2
      • matimilkoM Offline
        matimilko @Mykle1
        @mykle1 I’ll try that today :)
          matimilko
          Great!
          I’ve done it with xscreensaver. Perfect.
          Thanks!!!
          Mykle1M A 2 Replies Last reply Reply Quote 0
            @matimilko
            Fantastic! Now if you would mark the post that solved your issue. :-)
            yawnsY 1 Reply Last reply Reply Quote 1
            • yawnsY Offline
              yawns Moderator @Mykle1
              @mykle1 said in MagicMirror sleep in 5 minutes:
              @matimilko
              I did that on behalf of @matimilko
                Mykle1 Project Sponsor Module Developer @yawns
                @yawns said in MagicMirror sleep in 5 minutes:
                That’s because you’re awesome! :-)
                  asaxena11 @matimilko
                  @matimilko
                  Cold you please post the command you use after installing xscreensaver
                    Mykle1 Project Sponsor Module Developer @asaxena11
                    @asaxena11
                    Simply type xscreensaver in your terminal and Enter. Click Settings and you choose your options here.
