    MMM-BMW-DS (A different kind of weather module)
    65 Posts 13 Posters 66.1k Views 11 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @jorgeb1502
      @jorgeb1502
      Please post your config.js entry for this module in a code block so I can have a look at it. xxxxxx out your apiKey before posting
        jorgeb1502
        Never mind. Found a typo in the config. Working now. Is it possible to use this with a different language?
        Mykle1M 2 Replies Last reply
        • Mykle1M
          @jorgeb1502 said in MMM-BMW-DS (A different kind of weather module):
          I think the API does offer the data in different languages. I will take a look at that, and when time permits, I’ll update the module.
          EDIT:
          I’ll post the update tomorrow. I’m done for the night.
          • Mykle1M
            @jorgeb1502
            I’ve completed the update. The module now has language translations straight from the API itself. Please do a git pull in your MMM-BMW-DS directory or install as per the readme. There is an amended config entry in the readme so please take note of that.
            Let me know how that works for you.
            • Mykle1M
              Update
              Now with full language support from the Darksky API.
              Download:
              [card:mykle1/MMM-BMW-DS]
              Version 1.0.3
                jorgeb1502
                Works perfectly! Thanks!
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  @jorgeb1502
                  You’re welcome, mate. Have fun! :-)
                  • cirdanC
                    cirdan
                    Like it mykle, even an lord of the rings theme
                    Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @cirdan
                      @cirdan
                      Thank you, my friend. :-)
                      • Mykle1M
                        Fixed an issue that was brought to my attention by github user 73cirdan. I don’t know if he is the same as @cirdan but I would guess they are one and the same person. My thanks!
                        Do a git pull for the updated file or install as per the readme
                        J 1 Reply Last reply
                        • cirdanC
                          cirdan
                          Yep, that’s me, thanks for the fix mate
                            jorgeb1502 @Mykle1
                            @mykle1
                            I have another request for this module. Is it possible to show the time in 24h instead of am/pm?
                            • Mykle1M
                              Let me take a look at it. That should not be a problem. :-)
                              • Mykle1M
                                @jorgeb1502
                                Feature
                                This really should have been included from the beginning. I guess it just didn’t cross my mind. Anyway, . . .
                                The module will now read the timeFormat: 12, (or 24) of your config and display the correct time format.
                                Do a git pull or install as per the readme
                                EDIT: Thanks CBD!
                                Reply Quote 2
                                • Mykle1M
                                  Minor Update
                                  **Now with sound support for rain, thunder and wind
                                  Download:
                                  Version 1.0.4
                                  You can use your own mp3 sound files as long as you name them rain.mp3, thunder.mp3 and wind.mp3 and place them in the sounds folder of the module itself.
                                    i just installed this module, and the default CSS causes the display to take over the entire screen…
                                    css:1, fixes it… I ‘assume’ the default should be 1?
                                    • Mykle1M
                                      @sdetweil said in MMM-BMW-DS (A different kind of weather module):
                                      Sorry the module is giving you trouble. You should not have a “default.css” file at all. In the css folder of the module there should only be 6 css files, named:
                                      MMM-BMW-DS1.css
                                      MMM-BMW-DS2.css
                                      MMM-BMW-DS3.css
                                      MMM-BMW-DS4.css
                                      MMM-BMW-DS5.css
                                      MMM-BMW-DS6.css
                                      Maybe the way I implemented this, or documented this, is not very clear. I do apologize for that. If you have a suggestion for cleaning this up I would appreciate that, or if the problem is something else then please assist me in understanding and correcting.
                                        your readme
                                          css: "1",                         // 1-6 (default, Clean, Lord of the Rings, Handwriting, etc)
                                        ok, what is ‘default’?
                                        ie, the setting if one doesn’t chose anything?
                                        if I do not supply the line above, what value will be used
                                        the screen shots show a line at the bottom of the page, so I ASSUME this must be the ‘default’ behavior…
                                        • Mykle1M
                                          Ok, I see. I’m off to dinner right now but I will correct that when I return. I’m sorry for the trouble and thank you for pointing that out to me.
                                          • Mykle1M
                                            Ok, this is what I’ve done. I don’t know if this is the proper way of doing it but it does work.
                                            // Gets correct css file from config.js
                                                getStyles: function() {
                                                  if(this.config.css != ""){
                                                    return ["modules/MMM-BMW-DS/css/MMM-BMW-DS" + this.config.css + ".css"];
                                                  } else {
                                                    return ["modules/MMM-BMW-DS/css/MMM-BMW-DS1.css"]; // default.css
                                            • 2 / 4
