    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 92.6k Views 28 Watching
    • K Offline
      knubbl @cruunnerr
      @cruunnerr
      try mmm-scheduler . this is a modul which gives u the opportunity to schedule all modules to show and hide to a spedific time.
      nice if u have not enough space on ur screen and want to switch between modules by time
        Aurelsam
        Hi everybody,
        Do you think it would be possible to include a marker on the map to see my house on the map I display?
          sheddingmyskin
          Anyone else having issues with the map rendering streets / traffic /actual data rather than a blank frame? I have tried several of the forks, and they all end the same way. I have confirmed by use of MMM-Traffic that my API key is valid.
          config.js:
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
           // added Modules
                                  module: 'MMM-GoogleMapsTraffic',
                                  position: 'bottom_right',
                                          key: '************************',
                                          lat: '30.00000',
                                          lng: '-90.000000',
                                          height: '300px',
                                          width: '300px'
          			module: 'MMM-Traffic',
          			position: 'top_right',
          			classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
          				api_key: '*******',
          				mode: 'driving',
          				origin: '**********',
          				destination: '*********',
          			//	mon_destination: '116th St & Broadway, New York, NY 10027',
          			//	fri_destination: '1 E 161st St, Bronx, NY 10451',
          				arrival_time: '0755', //optional, but needs to be in 24 hour time if used.
          				route_name: 'Home to Work',
          				changeColor: true,
          				showGreen: false,
          				limitYellow: 5, //Greater than 5% of journey time due to traffic
          				limitRed: 20, //Greater than 20% of journey time due to traffic
          				traffic_model: 'pessimistic',
          				interval: 60000, //1 minutes
          				showWeekend: false,
          				allTime: false,
          				startHr: 5,
          				endHr:   10,
          				hideOffHours: true
            //end of Module adds
          			module: "compliments",
          			position: "lower_third"
          • cruunnerrC Offline
            cruunnerr
            @sheddingmyskin said in MMM-GoogleMapsTraffic:
                                        lat: '30.00000',
                                        lng: '-90.000000',
            This is wrong. Must look like this:
            lat: 30.00000,
            lng: -90.000000,
            Without the ’
              sheddingmyskin @cruunnerr
              @cruunnerr
              Thanks! That was it. I had it like that to begin with, but using a different fork, that did not allow the module to appear at all. I changed at some point and thought I was making progress.
                alkank
                Hi guys,
                Is there anyway to change the Style of the map automaticaly according to sun like navigations systems?
                  rak @Aurelsam
                  @aurelsam asked for markers. I built this in a very generic way. Will create a pull request soon.
                    rak @rak
                    I added a pull request to the original module which adds markers and an option for transparent maps.
                    Have fun.
                    Regards
                    Ralf
                      Smotx
                        Smotx
                        when I don’t activate this module, all my other modules work and display’s, when I activate this module, some modules are no longer displayed, such as: MMM-TPlink, MMM-CalendarExt, MMM-FreefoxMonitor.
                        Anyone have an idea why?
                        Thanks for help.
                        • T Offline
                          tbs86
                          Every time i add this module and try to start the MM it tells me i have a syntax error and wont start any modules on my mirror.
                          • evroomE Offline
                            evroom
                            Read this for learning purposes:
                            https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
                            If you post the config:check output and your MMM-GoogleMapsTraffic part inside config.js, I am sure someone can help you.
                            Good luck.
                            MagicMirror version: 2.37.0
                            T 2 Replies Last reply Reply Quote 1
                            • T Offline
                              tbs86 @evroom
                              @evroom thank you i will give this a shot when i get home and post my results
                              • T Offline
                                tbs86 @evroom
                                @evroom ```here is my code
                                		header: "US Holidays",
                                					symbol: "calendar-check-o ",
                                	var config = {
                                        position: 'bottom_left',
                                            key: 'YOUR_KEY',
                                            lat: 37.8262306,
                                            lng: -122.2920096,
                                            height: '300px',
                                            width: '300px'
                                            styledMapType: "transparent",
                                            disableDefaultUI: true,
                                            backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                            markers: [
                                                    lat: 37.8262316,
                                                    lng: -122.2920196,
                                                    fillColor: '#9966ff'
                                • evroomE Offline
                                  evroom
                                  Yes, the README tricked you a bit.
                                  Remove this:
                                  var config = {
                                  and the last 2 lines:
                                  Verify with:
                                  cd ~/MagicMirror; npm run config:check
                                  • T Offline
                                    tbs86 @evroom
                                    @evroom
                                    did what you said and did the config check and this is what i got
                                    Line 134 col 5 Unexpected ‘]’.
                                    Line 134 col 5 Expected an identifier and instead saw ‘]’.
                                    Line 134 col 6 Missing semicolon.
                                    Line 134 col 5 Unrecoverable syntax error. (95% scanned).
                                    pi@raspberrypi:~/MagicMirror $
                                    • T Offline
                                      tbs86
                                      it says line 134 but the only thing on line 134 is a ]
                                      here is my code leading up to 134
                                          module: "MMM-EARTH",
                                          position: "bottom_center",
                                              mode: "Natural",
                                              rotateInterval: 15000,
                                              MaxWidth: "50%",
                                              MaxHeight: "50%",
                                      That is line 116 to 136 the end of my config
                                        Mykle1 Project Sponsor Module Developer @tbs86
                                        @tbs86
                                        This is your current config entry
                                        var config = {
                                                    key: 'YOUR_KEY',
                                                    lat: 37.8262306,
                                                    lng: -122.2920096,
                                                    height: '300px',
                                                    width: '300px'
                                                    markers: [
                                                            lat: 37.8262316,
                                                            lng: -122.2920196,
                                        Make it look like this or copy and paste
                                                    key: 'YOUR_KEY',
                                                    lat: 37.8262306,
                                                    lng: -122.2920096,
                                                    height: '300px',
                                                    width: '300px'
                                                    markers: [
                                                            lat: 37.8262316,
                                                            lng: -122.2920196,
                                        Props to @evroom
                                        • T Offline
                                          tbs86 @Mykle1
                                          @mykle1 said in MMM-GoogleMapsTraffic:
                                                  key: 'YOUR_KEY',
                                                  lat: 37.8262306,
                                                  lng: -122.2920096,
                                                  height: '300px',
                                                  width: '300px'
                                                  markers: [
                                                          lat: 37.8262316,
                                                          lng: -122.2920196,
                                          still getting a error
                                            @tbs86
                                            Sorry about that. I just checked it. Try this please. There was a comma missing after width: '300px', and no comma after the closing } Not your fault. The example in the readme is incorrect
                                                    key: 'YOUR_KEY',
                                                    lat: 37.8262306,
                                                    lng: -122.2920096,
                                                    height: '300px',
                                                    width: '300px',
                                                    markers: [
                                                            lat: 37.8262316,
                                                            lng: -122.2920196,
                                            • 3 / 5
