    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
      sheddingmyskin
      Anyone else having issues with the map rendering streets / traffic /actual data rather than a blank frame? I have tried several of the forks, and they all end the same way. I have confirmed by use of MMM-Traffic that my API key is valid.
      config.js:
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
       // added Modules
                              module: 'MMM-GoogleMapsTraffic',
                              position: 'bottom_right',
                                      key: '************************',
                                      lat: '30.00000',
                                      lng: '-90.000000',
                                      height: '300px',
                                      width: '300px'
      			module: 'MMM-Traffic',
      			position: 'top_right',
      			classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
      				api_key: '*******',
      				mode: 'driving',
      				origin: '**********',
      				destination: '*********',
      			//	mon_destination: '116th St & Broadway, New York, NY 10027',
      			//	fri_destination: '1 E 161st St, Bronx, NY 10451',
      				arrival_time: '0755', //optional, but needs to be in 24 hour time if used.
      				route_name: 'Home to Work',
      				changeColor: true,
      				showGreen: false,
      				limitYellow: 5, //Greater than 5% of journey time due to traffic
      				limitRed: 20, //Greater than 20% of journey time due to traffic
      				traffic_model: 'pessimistic',
      				interval: 60000, //1 minutes
      				showWeekend: false,
      				allTime: false,
      				startHr: 5,
      				endHr:   10,
      				hideOffHours: true
        //end of Module adds
      			module: "compliments",
      			position: "lower_third"
      • cruunnerrC
        cruunnerr
        @sheddingmyskin said in MMM-GoogleMapsTraffic:
                                    lat: '30.00000',
                                    lng: '-90.000000',
        This is wrong. Must look like this:
        lat: 30.00000,
        lng: -90.000000,
        Without the ’
          sheddingmyskin @cruunnerr
          @cruunnerr
          Thanks! That was it. I had it like that to begin with, but using a different fork, that did not allow the module to appear at all. I changed at some point and thought I was making progress.
          • A
            alkank
            Hi guys,
            Is there anyway to change the Style of the map automaticaly according to sun like navigations systems?
              rak @Aurelsam
              @aurelsam asked for markers. I built this in a very generic way. Will create a pull request soon.
              R 1 Reply Last reply
                rak @rak
                I added a pull request to the original module which adds markers and an option for transparent maps.
                Have fun.
                Regards
                Ralf
                  Smotx
                    Smotx
                    when I don’t activate this module, all my other modules work and display’s, when I activate this module, some modules are no longer displayed, such as: MMM-TPlink, MMM-CalendarExt, MMM-FreefoxMonitor.
                    Anyone have an idea why?
                    Thanks for help.
                    • T
                      tbs86
                      Every time i add this module and try to start the MM it tells me i have a syntax error and wont start any modules on my mirror.
                      • evroomE
                        evroom
                        Read this for learning purposes:
                        https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
                        If you post the config:check output and your MMM-GoogleMapsTraffic part inside config.js, I am sure someone can help you.
                        Good luck.
                        MagicMirror version: 2.37.0
                        T 2 Replies Last reply
                        • T
                          tbs86 @evroom
                          @evroom thank you i will give this a shot when i get home and post my results
                          • T
                            tbs86 @evroom
                            @evroom ```here is my code
                            		header: "US Holidays",
                            					symbol: "calendar-check-o ",
                            	var config = {
                                    position: 'bottom_left',
                                        key: 'YOUR_KEY',
                                        lat: 37.8262306,
                                        lng: -122.2920096,
                                        height: '300px',
                                        width: '300px'
                                        styledMapType: "transparent",
                                        disableDefaultUI: true,
                                        backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                        markers: [
                                                lat: 37.8262316,
                                                lng: -122.2920196,
                                                fillColor: '#9966ff'
                            • evroomE
                              evroom
                              Yes, the README tricked you a bit.
                              Remove this:
                              var config = {
                              and the last 2 lines:
                              Verify with:
                              cd ~/MagicMirror; npm run config:check
                              T 1 Reply Last reply
                              • T
                                tbs86 @evroom
                                @evroom
                                did what you said and did the config check and this is what i got
                                Line 134 col 5 Unexpected ‘]’.
                                Line 134 col 5 Expected an identifier and instead saw ‘]’.
                                Line 134 col 6 Missing semicolon.
                                Line 134 col 5 Unrecoverable syntax error. (95% scanned).
                                pi@raspberrypi:~/MagicMirror $
                                • T
                                  tbs86
                                  it says line 134 but the only thing on line 134 is a ]
                                  here is my code leading up to 134
                                      module: "MMM-EARTH",
                                      position: "bottom_center",
                                          mode: "Natural",
                                          rotateInterval: 15000,
                                          MaxWidth: "50%",
                                          MaxHeight: "50%",
                                  That is line 116 to 136 the end of my config
                                  Mykle1M 1 Reply Last reply
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @tbs86
                                    @tbs86
                                    This is your current config entry
                                    var config = {
                                                key: 'YOUR_KEY',
                                                lat: 37.8262306,
                                                lng: -122.2920096,
                                                height: '300px',
                                                width: '300px'
                                                markers: [
                                                        lat: 37.8262316,
                                                        lng: -122.2920196,
                                    Make it look like this or copy and paste
                                                key: 'YOUR_KEY',
                                                lat: 37.8262306,
                                                lng: -122.2920096,
                                                height: '300px',
                                                width: '300px'
                                                markers: [
                                                        lat: 37.8262316,
                                                        lng: -122.2920196,
                                    Props to @evroom
                                    • T
                                      tbs86 @Mykle1
                                      @mykle1 said in MMM-GoogleMapsTraffic:
                                              key: 'YOUR_KEY',
                                              lat: 37.8262306,
                                              lng: -122.2920096,
                                              height: '300px',
                                              width: '300px'
                                              markers: [
                                                      lat: 37.8262316,
                                                      lng: -122.2920196,
                                      still getting a error
                                      • Mykle1M
                                        @tbs86
                                        Sorry about that. I just checked it. Try this please. There was a comma missing after width: '300px', and no comma after the closing } Not your fault. The example in the readme is incorrect
                                                key: 'YOUR_KEY',
                                                lat: 37.8262306,
                                                lng: -122.2920096,
                                                height: '300px',
                                                width: '300px',
                                                markers: [
                                                        lat: 37.8262316,
                                                        lng: -122.2920196,
                                        • T
                                          tbs86 @Mykle1
                                          @mykle1
                                          this worked thank you!!
                                          • Mykle1M
                                            @tbs86
                                            You’re welcome, mate. :thumbsup:
                                            • 3 / 5
