    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 93.2k Views 28 Watching
    • cruunnerrC Offline
      cruunnerr
      @sheddingmyskin said in MMM-GoogleMapsTraffic:
                                  lat: '30.00000',
                                  lng: '-90.000000',
      This is wrong. Must look like this:
      lat: 30.00000,
      lng: -90.000000,
      Without the ’
        sheddingmyskin @cruunnerr
        @cruunnerr
        Thanks! That was it. I had it like that to begin with, but using a different fork, that did not allow the module to appear at all. I changed at some point and thought I was making progress.
          alkank
          Hi guys,
          Is there anyway to change the Style of the map automaticaly according to sun like navigations systems?
            rak @Aurelsam
            @aurelsam asked for markers. I built this in a very generic way. Will create a pull request soon.
              rak @rak
              I added a pull request to the original module which adds markers and an option for transparent maps.
              Have fun.
              Regards
              Ralf
                Smotx
                  Smotx
                  when I don’t activate this module, all my other modules work and display’s, when I activate this module, some modules are no longer displayed, such as: MMM-TPlink, MMM-CalendarExt, MMM-FreefoxMonitor.
                  Anyone have an idea why?
                  Thanks for help.
                  • T Offline
                    tbs86
                    Every time i add this module and try to start the MM it tells me i have a syntax error and wont start any modules on my mirror.
                    • evroomE Offline
                      evroom
                      Read this for learning purposes:
                      https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
                      If you post the config:check output and your MMM-GoogleMapsTraffic part inside config.js, I am sure someone can help you.
                      Good luck.
                      MagicMirror version: 2.37.0
                      T 2 Replies Last reply Reply Quote 1
                      • T Offline
                        tbs86 @evroom
                        @evroom thank you i will give this a shot when i get home and post my results
                        • T Offline
                          tbs86 @evroom
                          @evroom ```here is my code
                          		header: "US Holidays",
                          					symbol: "calendar-check-o ",
                          		module: "compliments",
                          		position: "lower_third"
                          	var config = {
                                  module: 'MMM-GoogleMapsTraffic',
                                  position: 'bottom_left',
                                      key: 'YOUR_KEY',
                                      lat: 37.8262306,
                                      lng: -122.2920096,
                                      height: '300px',
                                      width: '300px'
                                      styledMapType: "transparent",
                                      disableDefaultUI: true,
                                      backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                      markers: [
                                              lat: 37.8262316,
                                              lng: -122.2920196,
                                              fillColor: '#9966ff'
                          • evroomE Offline
                            evroom
                            Yes, the README tricked you a bit.
                            Remove this:
                            var config = {
                            and the last 2 lines:
                            Verify with:
                            cd ~/MagicMirror; npm run config:check
                            • T Offline
                              tbs86 @evroom
                              @evroom
                              did what you said and did the config check and this is what i got
                              Line 134 col 5 Unexpected ‘]’.
                              Line 134 col 5 Expected an identifier and instead saw ‘]’.
                              Line 134 col 6 Missing semicolon.
                              Line 134 col 5 Unrecoverable syntax error. (95% scanned).
                              pi@raspberrypi:~/MagicMirror $
                              • T Offline
                                tbs86
                                it says line 134 but the only thing on line 134 is a ]
                                here is my code leading up to 134
                                    module: "MMM-EARTH",
                                    position: "bottom_center",
                                        mode: "Natural",
                                        rotateInterval: 15000,
                                        MaxWidth: "50%",
                                        MaxHeight: "50%",
                                That is line 116 to 136 the end of my config
                                  Mykle1 Project Sponsor Module Developer @tbs86
                                  @tbs86
                                  This is your current config entry
                                  var config = {
                                              key: 'YOUR_KEY',
                                              lat: 37.8262306,
                                              lng: -122.2920096,
                                              height: '300px',
                                              width: '300px'
                                              markers: [
                                                      lat: 37.8262316,
                                                      lng: -122.2920196,
                                  Make it look like this or copy and paste
                                              key: 'YOUR_KEY',
                                              lat: 37.8262306,
                                              lng: -122.2920096,
                                              height: '300px',
                                              width: '300px'
                                              markers: [
                                                      lat: 37.8262316,
                                                      lng: -122.2920196,
                                  Props to @evroom
                                  • T Offline
                                    tbs86 @Mykle1
                                    @mykle1 said in MMM-GoogleMapsTraffic:
                                            key: 'YOUR_KEY',
                                            lat: 37.8262306,
                                            lng: -122.2920096,
                                            height: '300px',
                                            width: '300px'
                                            markers: [
                                                    lat: 37.8262316,
                                                    lng: -122.2920196,
                                    still getting a error
                                      @tbs86
                                      Sorry about that. I just checked it. Try this please. There was a comma missing after width: '300px', and no comma after the closing } Not your fault. The example in the readme is incorrect
                                              key: 'YOUR_KEY',
                                              lat: 37.8262306,
                                              lng: -122.2920096,
                                              height: '300px',
                                              width: '300px',
                                              markers: [
                                                      lat: 37.8262316,
                                                      lng: -122.2920196,
                                      • T Offline
                                        tbs86 @Mykle1
                                        @mykle1
                                        this worked thank you!!
                                          @tbs86
                                          You’re welcome, mate. :thumbsup:
                                            rvanuden
                                            it all seems to be working but googlemaps can not be loaded, i used a new key though
                                            any ideas?
                                            • 3 / 5
