    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 92.6k Views 28 Watching
    • T Offline
      tbs86 @evroom
      @evroom thank you i will give this a shot when i get home and post my results
      • T Offline
        tbs86 @evroom
        @evroom ```here is my code
        		header: "US Holidays",
        					symbol: "calendar-check-o ",
        		module: "compliments",
        		position: "lower_third"
        	var config = {
                module: 'MMM-GoogleMapsTraffic',
                position: 'bottom_left',
                    key: 'YOUR_KEY',
                    lat: 37.8262306,
                    lng: -122.2920096,
                    height: '300px',
                    width: '300px'
                    styledMapType: "transparent",
                    disableDefaultUI: true,
                    backgroundColor: 'hsla(0, 0%, 0%, 0)',
                    markers: [
                            lat: 37.8262316,
                            lng: -122.2920196,
                            fillColor: '#9966ff'
        • evroomE Offline
          evroom
          Yes, the README tricked you a bit.
          Remove this:
          var config = {
          and the last 2 lines:
          Verify with:
          cd ~/MagicMirror; npm run config:check
          MagicMirror version: 2.37.0
          • T Offline
            tbs86 @evroom
            @evroom
            did what you said and did the config check and this is what i got
            Line 134 col 5 Unexpected ‘]’.
            Line 134 col 5 Expected an identifier and instead saw ‘]’.
            Line 134 col 6 Missing semicolon.
            Line 134 col 5 Unrecoverable syntax error. (95% scanned).
            pi@raspberrypi:~/MagicMirror $
            • T Offline
              tbs86
              it says line 134 but the only thing on line 134 is a ]
              here is my code leading up to 134
                  module: "MMM-EARTH",
                  position: "bottom_center",
                      mode: "Natural",
                      rotateInterval: 15000,
                      MaxWidth: "50%",
                      MaxHeight: "50%",
              That is line 116 to 136 the end of my config
                Mykle1 Project Sponsor Module Developer @tbs86
                @tbs86
                This is your current config entry
                var config = {
                            key: 'YOUR_KEY',
                            lat: 37.8262306,
                            lng: -122.2920096,
                            height: '300px',
                            width: '300px'
                            markers: [
                                    lat: 37.8262316,
                                    lng: -122.2920196,
                Make it look like this or copy and paste
                            key: 'YOUR_KEY',
                            lat: 37.8262306,
                            lng: -122.2920096,
                            height: '300px',
                            width: '300px'
                            markers: [
                                    lat: 37.8262316,
                                    lng: -122.2920196,
                Props to @evroom
                • T Offline
                  tbs86 @Mykle1
                  @mykle1 said in MMM-GoogleMapsTraffic:
                          key: 'YOUR_KEY',
                          lat: 37.8262306,
                          lng: -122.2920096,
                          height: '300px',
                          width: '300px'
                          markers: [
                                  lat: 37.8262316,
                                  lng: -122.2920196,
                  still getting a error
                    @tbs86
                    Sorry about that. I just checked it. Try this please. There was a comma missing after width: '300px', and no comma after the closing } Not your fault. The example in the readme is incorrect
                            key: 'YOUR_KEY',
                            lat: 37.8262306,
                            lng: -122.2920096,
                            height: '300px',
                            width: '300px',
                            markers: [
                                    lat: 37.8262316,
                                    lng: -122.2920196,
                    • T Offline
                      tbs86 @Mykle1
                      @mykle1
                      this worked thank you!!
                        @tbs86
                        You’re welcome, mate. :thumbsup:
                          rvanuden
                          it all seems to be working but googlemaps can not be loaded, i used a new key though
                          any ideas?
                            rvanuden @rvanuden
                            @rvanuden anyone?
                              mcneilp @rvanuden
                              @rvanuden I have the same problem. Did you find a solution?
                                there is a problem with the original module… I have a fixed version
                                here https://github.com/sdetweil/MMM-GoogleMapsTraffic
                                Do this
                                cd ~/MagicMirror/modules
                                mv  MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic.original
                                git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
                                cd MMM-GoogleMapsTraffic
                                npm install
                                then restart the mirror app
                                ChrisC 1 Reply Last reply Reply Quote 3
                                • ChrisC Offline
                                  Chris @sdetweil
                                  @sdetweil said in MMM-GoogleMapsTraffic:
                                  Do this
                                  npm install
                                  Thank you so much,
                                  Regards,
                                    mcneilp
                                    I got it working. I did the above…plus I was using the wrong bit of text for my API key…and had to “setup billing” on my api account apparently to allow it to work.
                                      sdetweil @mcneilp
                                      @mcneilp thanks for the feedback… sad how many of the apis want to charge…
                                      • E Offline
                                        Egnos
                                        Hello to all.
                                        Many thanks to the developer for the brilliant idea!
                                        I describe my environment:
                                        I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
                                        For now all modules work perfectly except MMM-GoogleMapsTraffic.
                                        Description of the problem:
                                        I successfully installed the module but when I launch MM I only see the classic purple Google Maps pointer and nothing else…
                                        The configuration of the .JSON seems ok, and the API has been entered correctly.
                                        Can you help me…?
                                        Thank you all!
                                          sdetweil @Egnos
                                          @Egnos see back a couple posts to get my updated version.
                                          • E Offline
                                            Egnos @sdetweil
                                            I installed the module this afternoon, I believe it is already the updated version.
                                            I have used this
                                            guide
                                            • 3 / 5
