    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
    • evroomE
      evroom
      Yes, the README tricked you a bit.
      Remove this:
      var config = {
      and the last 2 lines:
      Verify with:
      cd ~/MagicMirror; npm run config:check
      MagicMirror version: 2.37.0
      • T
        tbs86 @evroom
        @evroom
        did what you said and did the config check and this is what i got
        Line 134 col 5 Unexpected ‘]’.
        Line 134 col 5 Expected an identifier and instead saw ‘]’.
        Line 134 col 6 Missing semicolon.
        Line 134 col 5 Unrecoverable syntax error. (95% scanned).
        pi@raspberrypi:~/MagicMirror $
        • T
          tbs86
          it says line 134 but the only thing on line 134 is a ]
          here is my code leading up to 134
              module: "MMM-EARTH",
              position: "bottom_center",
                  mode: "Natural",
                  rotateInterval: 15000,
                  MaxWidth: "50%",
                  MaxHeight: "50%",
          That is line 116 to 136 the end of my config
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @tbs86
            @tbs86
            This is your current config entry
            var config = {
                    module: 'MMM-GoogleMapsTraffic',
                    position: 'bottom_left',
                        key: 'YOUR_KEY',
                        lat: 37.8262306,
                        lng: -122.2920096,
                        height: '300px',
                        width: '300px'
                        styledMapType: "transparent",
                        disableDefaultUI: true,
                        backgroundColor: 'hsla(0, 0%, 0%, 0)',
                        markers: [
                                lat: 37.8262316,
                                lng: -122.2920196,
                                fillColor: '#9966ff'
            Make it look like this or copy and paste
                        key: 'YOUR_KEY',
                        lat: 37.8262306,
                        lng: -122.2920096,
                        height: '300px',
                        width: '300px'
                        markers: [
                                lat: 37.8262316,
                                lng: -122.2920196,
            Props to @evroom
            • T
              tbs86 @Mykle1
              @mykle1 said in MMM-GoogleMapsTraffic:
                      key: 'YOUR_KEY',
                      lat: 37.8262306,
                      lng: -122.2920096,
                      height: '300px',
                      width: '300px'
                      markers: [
                              lat: 37.8262316,
                              lng: -122.2920196,
              still getting a error
              • Mykle1M
                @tbs86
                Sorry about that. I just checked it. Try this please. There was a comma missing after width: '300px', and no comma after the closing } Not your fault. The example in the readme is incorrect
                        key: 'YOUR_KEY',
                        lat: 37.8262306,
                        lng: -122.2920096,
                        height: '300px',
                        width: '300px',
                        markers: [
                                lat: 37.8262316,
                                lng: -122.2920196,
                • T
                  tbs86 @Mykle1
                  @mykle1
                  this worked thank you!!
                  • Mykle1M
                    @tbs86
                    You’re welcome, mate. :thumbsup:
                      rvanuden
                      it all seems to be working but googlemaps can not be loaded, i used a new key though
                      any ideas?
                        rvanuden @rvanuden
                        @rvanuden anyone?
                          mcneilp @rvanuden
                          @rvanuden I have the same problem. Did you find a solution?
                            there is a problem with the original module… I have a fixed version
                            here https://github.com/sdetweil/MMM-GoogleMapsTraffic
                            Do this
                            cd ~/MagicMirror/modules
                            mv  MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic.original
                            git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
                            cd MMM-GoogleMapsTraffic
                            npm install
                            then restart the mirror app
                            ChrisC 1 Reply Last reply Reply Quote 3
                            • ChrisC
                              Chris @sdetweil
                              @sdetweil said in MMM-GoogleMapsTraffic:
                              Do this
                              npm install
                              Thank you so much,
                              Regards,
                                mcneilp
                                I got it working. I did the above…plus I was using the wrong bit of text for my API key…and had to “setup billing” on my api account apparently to allow it to work.
                                  sdetweil @mcneilp
                                  @mcneilp thanks for the feedback… sad how many of the apis want to charge…
                                  • E
                                    Egnos
                                    Hello to all.
                                    Many thanks to the developer for the brilliant idea!
                                    I describe my environment:
                                    I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
                                    For now all modules work perfectly except MMM-GoogleMapsTraffic.
                                    Description of the problem:
                                    I successfully installed the module but when I launch MM I only see the classic purple Google Maps pointer and nothing else…
                                    The configuration of the .JSON seems ok, and the API has been entered correctly.
                                    Can you help me…?
                                    Thank you all!
                                      sdetweil @Egnos
                                      @Egnos see back a couple posts to get my updated version.
                                      • E
                                        Egnos @sdetweil
                                        I installed the module this afternoon, I believe it is already the updated version.
                                        I have used this
                                        guide
                                          sdetweil @Egnos
                                          @Egnos from here, right?
                                          E 3 Replies Last reply Reply Quote 0
                                          • E
                                            Egnos @sdetweil
                                            Yes, of course.
                                            • 3 / 5
