    Updating MagicMirror from v2.1.3 to v2.5.0
    14 Posts 4 Posters 6.9k Views 4 Watching
    • el97E Offline
      el97 @Mykle1
      @mykle1 Yeah but the only thing he says is that it wont work :P
        Mykle1 Project Sponsor Module Developer @el97
        @el97
        Oy! Ok, then perhaps he’ll see your comment and have some success
        • justjim1220J Offline
          justjim1220 Module Developer @el97
          @el97
          If you made any changes to the original MM2, you will need to move them, or delete them.
          If you could post a screen shot of the terminal errors, might be able to help you.
          "Life's Too Short To Dance With Ugly People"
          Jim Hallock - 1995
          el97E 1 Reply Last reply Reply Quote 0
          • el97E Offline
            el97 @justjim1220
            @justjim1220 Uum… Im not the one that needs help :P @chetnaik is the one that made the post ;)
              chetnaik
              Here what I did
              1. sudo apt-get update
              2. sudo apt-get full-upgrade
              3. sudo rpi-update
              4. sudo reboot
                pi@raspi:~ $ node -v
                v10.11.0
                pi@raspi:~ $ apt list nodejs
                Listing… Done
                nodejs/unknown,now 10.11.0-1nodesource1 armhf [installed]
                N: There are 2 additional versions. Please use the ‘-a’ switch to see them.
                pi@raspi:~ $ sudo apt update
                Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                Hit:3 https://deb.nodesource.com/node_10.x stretch InRelease
                Reading package lists… Done
                Building dependency tree
                Reading state information… Done
                All packages are up to date.
                pi@raspi:~ $ sudo apt install nodejs
                nodejs is already the newest version (10.11.0-1nodesource1).
                lxkeymap python-cairo python-gobject python-gobject-2 python-gtk2 python-xklavier
                Use ‘sudo apt autoremove’ to remove them.
                v10.11.0
              pi@raspi:~/MagicMirror $ npm run config:check
              magicmirror@2.1.3 config:check /home/pi/MagicMirror
              node tests/configs/check_config.js
              Checking file… /home/pi/MagicMirror/config/config.js
              Your configuration file don’t containt syntax error :)
              pi@raspi:~/MagicMirror $ ls -a
              . core .github js package.json splashscreen
              … css .gitignore jsconfig.json package-lock.json tests
              CHANGELOG.md .eslintignore Gruntfile.js LICENSE.md README.md translations
              clientonly .eslintrc.json index.html modules run-start.sh .travis.yml
              config fonts installers node_modules serveronly vendor
              pi@raspi:~/MagicMirror $ sudo git pull && npm install
              fatal: Not a git repository (or any of the parent directories): .git
              pi@raspi:~/MagicMirror $ git stash
              pi@raspi:~/MagicMirror $ fatal: Not a git repository (or any of the parent directories): .git
              -bash: syntax error near unexpected token `(’
              pi@raspi:~/MagicMirror $ ^C
              pi@raspi:~/MagicMirror $ git init
              Initialized empty Git repository in /home/pi/MagicMirror/.git/
              fatal: bad revision ‘HEAD’
              fatal: Needed a single revision
              You do not have the initial commit yet
              fatal: No remote repository specified. Please, specify either a URL or a
              remote name from which new revisions should be fetched.
              Reinitialized existing Git repository in /home/pi/MagicMirror/.git/
              pi@raspi:~/MagicMirror $ git remote add origin https://github.com/MichMich/MagicMirror.git
              remote: Enumerating objects: 25, done.
              remote: Counting objects: 100% (25/25), done.
              remote: Compressing objects: 100% (20/20), done.
              remote: Total 10389 (delta 7), reused 16 (delta 5), pack-reused 10364
              Receiving objects: 100% (10389/10389), 12.11 MiB | 5.68 MiB/s, done.
              Resolving deltas: 100% (5930/5930), done.
              From https://github.com/MichMich/MagicMirror
              • [new branch] develop -> origin/develop
              • [new branch] master -> origin/master
              • [new branch] snyk-fix-zrd9ko -> origin/snyk-fix-zrd9ko
              • [new branch] v1.0.0 -> origin/v1.0.0
              • [new branch] weather-refactor -> origin/weather-refactor
              • [new tag] v2.5.0 -> v2.5.0
              • [new tag] V2.2.1 -> V2.2.1
              • [new tag] v.2.1.3 -> v.2.1.3
              • [new tag] v2.0.0 -> v2.0.0
              • [new tag] v2.0.1 -> v2.0.1
              • [new tag] v2.0.2 -> v2.0.2
              • [new tag] v2.0.3 -> v2.0.3
              • [new tag] v2.0.4 -> v2.0.4
              • [new tag] v2.0.5 -> v2.0.5
              • [new tag] v2.1.0 -> v2.1.0
              • [new tag] v2.1.1 -> v2.1.1
              • [new tag] v2.1.2 -> v2.1.2
              • [new tag] v2.2.0 -> v2.2.0
              • [new tag] v2.2.2 -> v2.2.2
              • [new tag] v2.3.0 -> v2.3.0
              • [new tag] v2.3.1 -> v2.3.1
              • [new tag] v2.4.0 -> v2.4.0
              • [new tag] v2.4.1 -> v2.4.1
                There is no tracking information for the current branch.
                Please specify which branch you want to merge with.
                See git-pull(1) for details.
                git pull
              If you wish to set tracking information for this branch you can do so with:
              git branch --set-upstream-to=origin/<branch> master
              pi@raspi:~/MagicMirror $ npm install
              magicmirror@2.1.3 install /home/pi/MagicMirror
              cd vendor && npm install
              audited 5 packages in 2.014s
              found 2 low severity vulnerabilities
              run npm audit fix to fix them, or npm audit for details
              magicmirror@2.1.3 postinstall /home/pi/MagicMirror
              sh installers/postinstall/postinstall.sh && npm run install-fonts
              MagicMirror installation successful!
              magicmirror@2.1.3 install-fonts /home/pi/MagicMirror
              cd fonts && npm install
              audited 1 package in 1.909s
              found 0 vulnerabilities
              audited 2152 packages in 35.461s
              found 65 vulnerabilities (27 low, 27 moderate, 8 high, 3 critical)
              pi@raspi:~/MagicMirror $ npm audit
                                 === npm audit security report ===
              				   found 65 vulnerabilities (27 low, 27 moderate, 8 high, 3 critical) in 2152 scanned packages
              run npm audit fix to fix 23 of them.
              41 vulnerabilities require semver-major dependency updates.
              1 vulnerability requires manual review. See the full report for details.
              pi@raspi:~/MagicMirror $ npm audit fix
              phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/phantomjs-prebuilt
              node install.js
              PhantomJS not found on PATH
              Unexpected platform or architecture: linux/arm
              It seems there is no binary available for your platform/architecture
              Try to install PhantomJS globally
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 (node_modules/phantomjs-prebuilt):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 install: node install.js
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              • grunt@1.0.3
              • request@2.88.0
              • jshint@2.9.6
              • mocha-logger@1.0.6
              • socket.io@2.1.1
              • moment@2.22.2
                added 55 packages from 547 contributors, removed 16 packages and updated 36 packages in 126.138s
                fixed 23 of 65 vulnerabilities in 2152 scanned packages
                1 vulnerability required manual review and could not be updated
                4 package updates for 41 vulns involved breaking changes
                (use npm audit fix --force to install breaking changes; or refer to npm audit for steps to fix these manually)
                pi@raspi:~/MagicMirror $ npm audit fix --force
                npm WARN using --force I sure hope you know what you are doing.
              node install.js
              electron-chromedriver@2.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
              node ./download-chromedriver.js
              successfully downloaded and extracted!
              electron@3.0.2 postinstall /home/pi/MagicMirror/node_modules/electron
              node install.js
              Downloading tmp-1923-1-SHASUMS256.txt-3.0.2
              [============================================>] 100.0% of 4.74 kB (4.74 kB/s)
              npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
              • mocha@5.2.0
              • spectron@4.0.0
              • electron@3.0.2
              • stylelint@9.6.0
                added 674 packages from 887 contributors, removed 60 packages, updated 125 packages and moved 4 packages in 214.794s
                fixed 37 of 38 vulnerabilities in 2324 scanned packages
                4 package updates for 29 vulns involved breaking changes
                (installed due to --force option)
                pi@raspi:~/MagicMirror $ git status
                On branch master
              Initial commit
              Untracked files:
              (use “git add …” to include in what will be committed)
                  .eslintignore
                  .eslintrc.json
                  .github/
                  .gitignore
                  .travis.yml
                  CHANGELOG.md
                  Gruntfile.js
                  LICENSE.md
                  README.md
                  clientonly/
                  config/
                  core
                  css/
                  fonts/
                  index.html
                  installers/
                  js/
                  jsconfig.json
                  modules/
                  package-lock.json
                  package.json
                  run-start.sh
                  serveronly/
                  splashscreen/
                  tests/
                  translations/
                  vendor/
              nothing added to commit but untracked files present (use “git add” to track)
                chetnaik
                after performing above steps still package.json says version": “2.1.3”
                so my question is did above process upgraded my magicmirror to v2.5.0? ??
                here are more info from package.json file.
                “name”: “magicmirror”,
                “version”: “2.1.3”,
                “description”: “The open source modular smart mirror platform.”,
                “main”: “js/electron.js”,
                “scripts”: {
                “start”: “sh run-start.sh”,
                “install”: “cd vendor && npm install”,
                “install-fonts”: “cd fonts && npm install”,
                “postinstall”: “sh installers/postinstall/postinstall.sh && npm run install-fonts”,
                “test”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests --recursive”,
                “test:unit”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests/unit --recursive”,
                “test:e2e”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive”,
                “config:check”: “node tests/configs/check_config.js”
                “repository”: {
                “type”: “git”,
                “url”: “git+https://github.com/MichMich/MagicMirror.git”
                “keywords”: [
                “magic mirror”,
                “smart mirror”,
                “mirror UI”,
                “modular”
                “author”: “Michael Teeuw”,
                “contributors”: [
                “https://github.com/MichMich/MagicMirror/graphs/contributors”
                “license”: “MIT”,
                “bugs”: {
                “url”: “https://github.com/MichMich/MagicMirror/issues”
                “homepage”: “https://magicmirror.builders”,
                “devDependencies”: {
                “chai”: “^3.5.0”,
                “chai-as-promised”: “^6.0.0”,
                “current-week-number”: “^1.0.7”,
                “grunt”: “^1.0.3”,
                “grunt-eslint”: “latest”,
                “grunt-jsonlint”: “latest”,
                “grunt-markdownlint”: “^1.0.39”,
                “grunt-stylelint”: “latest”,
                “grunt-yamllint”: “latest”,
                “http-auth”: “^3.1.3”,
                “jshint”: “^2.9.6”,
                “mocha”: “^5.2.0”,
                “mocha-each”: “^1.1.0”,
                “spectron”: “^4.0.0”,
                “stylelint”: “^9.6.0”,
                “stylelint-config-standard”: “latest”,
                “time-grunt”: “latest”
                “dependencies”: {
                “body-parser”: “^1.17.2”,
                “colors”: “^1.1.2”,
                “electron”: “^3.0.2”,
                “express”: “^4.15.3”,
                “express-ipfilter”: “0.3.1”,
                “feedme”: “latest”,
                “helmet”: “^3.6.1”,
                “iconv-lite”: “latest”,
                “mocha-logger”: “^1.0.6”,
                “moment”: “^2.22.2”,
                “request”: “^2.88.0”,
                “rrule-alt”: “^2.2.5”,
                “simple-git”: “^1.73.0”,
                “socket.io”: “^2.1.1”,
                “valid-url”: “latest”,
                “walk”: “latest”
                  @el97 Apologies!
                  Jim Hallock - 1995
                  • el97E Offline
                    el97 @justjim1220
                    @justjim1220 Np. We all can read stuff wrong sometimes :P
                      justjim1220 Module Developer @chetnaik
                      @chetnaik
                      delete the package.json and the package lock.json
                      then retry git pull && npm install
                      Jim Hallock - 1995
                        chetnaik @justjim1220
                        @justjim1220 … still not working :(… I’m going to rename or move Current MM and install new version … thank you…;)
