    Updating MagicMirror from v2.1.3 to v2.5.0
    14 Posts 4 Posters 8.0k Views 4 Watching
      chetnaik
      Hi , Is it possible to update MagicMirror from v2.1.3 to v2.5.0 ?
      if yes then how
      because below method is not working on my MM version 2.1.3… please advise
      Updating
      If you want to update your MagicMirror² to the latest version, use your terminal to go to your Magic Mirror folder and type the following command:
      git pull && npm install
      If you changed nothing more than the config or the modules, this should work without any problems. Type git status to see your changes, if there are any, you can reset them with git reset --hard. After that, git pull should be possible.
      • el97E
        el97
        Are you in the MagicMirror directory when you type the command git pull && npm install?
        Mykle1M justjim1220J 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @el97
          @el97
          He should be. It wouldn’t work otherwise.
          el97E 1 Reply Last reply
          • el97E
            el97 @Mykle1
            @mykle1 Yeah but the only thing he says is that it wont work :P
            Mykle1M 1 Reply Last reply
            • Mykle1M
              @el97
              Oy! Ok, then perhaps he’ll see your comment and have some success
              • justjim1220J
                justjim1220 Module Developer @el97
                @el97
                If you made any changes to the original MM2, you will need to move them, or delete them.
                If you could post a screen shot of the terminal errors, might be able to help you.
                Jim Hallock - 1995
                • el97E
                  el97 @justjim1220
                  @justjim1220 Uum… Im not the one that needs help :P @chetnaik is the one that made the post ;)
                  justjim1220J 1 Reply Last reply
                    chetnaik
                    Here what I did
                    1. sudo apt-get update
                    2. sudo apt-get full-upgrade
                    3. sudo rpi-update
                    4. sudo reboot
                      pi@raspi:~ $ node -v
                      v10.11.0
                      pi@raspi:~ $ apt list nodejs
                      Listing… Done
                      nodejs/unknown,now 10.11.0-1nodesource1 armhf [installed]
                      N: There are 2 additional versions. Please use the ‘-a’ switch to see them.
                      pi@raspi:~ $ sudo apt update
                      Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                      Hit:3 https://deb.nodesource.com/node_10.x stretch InRelease
                      Reading package lists… Done
                      Building dependency tree
                      Reading state information… Done
                      All packages are up to date.
                      pi@raspi:~ $ sudo apt install nodejs
                      nodejs is already the newest version (10.11.0-1nodesource1).
                      lxkeymap python-cairo python-gobject python-gobject-2 python-gtk2 python-xklavier
                      Use ‘sudo apt autoremove’ to remove them.
                      v10.11.0
                    pi@raspi:~/MagicMirror $ npm run config:check
                    magicmirror@2.1.3 config:check /home/pi/MagicMirror
                    node tests/configs/check_config.js
                    Checking file… /home/pi/MagicMirror/config/config.js
                    Your configuration file don’t containt syntax error :)
                    pi@raspi:~/MagicMirror $ ls -a
                    . core .github js package.json splashscreen
                    … css .gitignore jsconfig.json package-lock.json tests
                    CHANGELOG.md .eslintignore Gruntfile.js LICENSE.md README.md translations
                    clientonly .eslintrc.json index.html modules run-start.sh .travis.yml
                    config fonts installers node_modules serveronly vendor
                    pi@raspi:~/MagicMirror $ sudo git pull && npm install
                    fatal: Not a git repository (or any of the parent directories): .git
                    pi@raspi:~/MagicMirror $ git stash
                    pi@raspi:~/MagicMirror $ fatal: Not a git repository (or any of the parent directories): .git
                    -bash: syntax error near unexpected token `(’
                    pi@raspi:~/MagicMirror $ ^C
                    pi@raspi:~/MagicMirror $ git init
                    Initialized empty Git repository in /home/pi/MagicMirror/.git/
                    fatal: bad revision ‘HEAD’
                    fatal: Needed a single revision
                    You do not have the initial commit yet
                    fatal: No remote repository specified. Please, specify either a URL or a
                    remote name from which new revisions should be fetched.
                    Reinitialized existing Git repository in /home/pi/MagicMirror/.git/
                    pi@raspi:~/MagicMirror $ git remote add origin https://github.com/MichMich/MagicMirror.git
                    remote: Enumerating objects: 25, done.
                    remote: Counting objects: 100% (25/25), done.
                    remote: Compressing objects: 100% (20/20), done.
                    remote: Total 10389 (delta 7), reused 16 (delta 5), pack-reused 10364
                    Receiving objects: 100% (10389/10389), 12.11 MiB | 5.68 MiB/s, done.
                    Resolving deltas: 100% (5930/5930), done.
                    From https://github.com/MichMich/MagicMirror
                    • [new branch] develop -> origin/develop
                    • [new branch] master -> origin/master
                    • [new branch] snyk-fix-zrd9ko -> origin/snyk-fix-zrd9ko
                    • [new branch] v1.0.0 -> origin/v1.0.0
                    • [new branch] weather-refactor -> origin/weather-refactor
                    • [new tag] v2.5.0 -> v2.5.0
                    • [new tag] V2.2.1 -> V2.2.1
                    • [new tag] v.2.1.3 -> v.2.1.3
                    • [new tag] v2.0.0 -> v2.0.0
                    • [new tag] v2.0.1 -> v2.0.1
                    • [new tag] v2.0.2 -> v2.0.2
                    • [new tag] v2.0.3 -> v2.0.3
                    • [new tag] v2.0.4 -> v2.0.4
                    • [new tag] v2.0.5 -> v2.0.5
                    • [new tag] v2.1.0 -> v2.1.0
                    • [new tag] v2.1.1 -> v2.1.1
                    • [new tag] v2.1.2 -> v2.1.2
                    • [new tag] v2.2.0 -> v2.2.0
                    • [new tag] v2.2.2 -> v2.2.2
                    • [new tag] v2.3.0 -> v2.3.0
                    • [new tag] v2.3.1 -> v2.3.1
                    • [new tag] v2.4.0 -> v2.4.0
                    • [new tag] v2.4.1 -> v2.4.1
                      There is no tracking information for the current branch.
                      Please specify which branch you want to merge with.
                      See git-pull(1) for details.
                      git pull
                    If you wish to set tracking information for this branch you can do so with:
                    git branch --set-upstream-to=origin/<branch> master
                    pi@raspi:~/MagicMirror $ npm install
                    magicmirror@2.1.3 install /home/pi/MagicMirror
                    cd vendor && npm install
                    audited 5 packages in 2.014s
                    found 2 low severity vulnerabilities
                    run npm audit fix to fix them, or npm audit for details
                    magicmirror@2.1.3 postinstall /home/pi/MagicMirror
                    sh installers/postinstall/postinstall.sh && npm run install-fonts
                    MagicMirror installation successful!
                    magicmirror@2.1.3 install-fonts /home/pi/MagicMirror
                    cd fonts && npm install
                    audited 1 package in 1.909s
                    found 0 vulnerabilities
                    audited 2152 packages in 35.461s
                    found 65 vulnerabilities (27 low, 27 moderate, 8 high, 3 critical)
                    pi@raspi:~/MagicMirror $ npm audit
                                       === npm audit security report ===
                    				   found 65 vulnerabilities (27 low, 27 moderate, 8 high, 3 critical) in 2152 scanned packages
                    run npm audit fix to fix 23 of them.
                    41 vulnerabilities require semver-major dependency updates.
                    1 vulnerability requires manual review. See the full report for details.
                    pi@raspi:~/MagicMirror $ npm audit fix
                    phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/phantomjs-prebuilt
                    node install.js
                    PhantomJS not found on PATH
                    Unexpected platform or architecture: linux/arm
                    It seems there is no binary available for your platform/architecture
                    Try to install PhantomJS globally
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 (node_modules/phantomjs-prebuilt):
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 install: node install.js
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                    • grunt@1.0.3
                    • request@2.88.0
                    • jshint@2.9.6
                    • mocha-logger@1.0.6
                    • socket.io@2.1.1
                    • moment@2.22.2
                      added 55 packages from 547 contributors, removed 16 packages and updated 36 packages in 126.138s
                      fixed 23 of 65 vulnerabilities in 2152 scanned packages
                      1 vulnerability required manual review and could not be updated
                      4 package updates for 41 vulns involved breaking changes
                      (use npm audit fix --force to install breaking changes; or refer to npm audit for steps to fix these manually)
                      pi@raspi:~/MagicMirror $ npm audit fix --force
                      npm WARN using --force I sure hope you know what you are doing.
                    node install.js
                    electron-chromedriver@2.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                    node ./download-chromedriver.js
                    successfully downloaded and extracted!
                    electron@3.0.2 postinstall /home/pi/MagicMirror/node_modules/electron
                    node install.js
                    Downloading tmp-1923-1-SHASUMS256.txt-3.0.2
                    [============================================>] 100.0% of 4.74 kB (4.74 kB/s)
                    npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
                    • mocha@5.2.0
                    • spectron@4.0.0
                    • electron@3.0.2
                    • stylelint@9.6.0
                      added 674 packages from 887 contributors, removed 60 packages, updated 125 packages and moved 4 packages in 214.794s
                      fixed 37 of 38 vulnerabilities in 2324 scanned packages
                      4 package updates for 29 vulns involved breaking changes
                      (installed due to --force option)
                      pi@raspi:~/MagicMirror $ git status
                      On branch master
                    Initial commit
                    Untracked files:
                    (use “git add …” to include in what will be committed)
                        .eslintignore
                        .eslintrc.json
                        .github/
                        .gitignore
                        .travis.yml
                        CHANGELOG.md
                        Gruntfile.js
                        LICENSE.md
                        README.md
                        clientonly/
                        config/
                        core
                        css/
                        fonts/
                        index.html
                        installers/
                        js/
                        jsconfig.json
                        modules/
                        package-lock.json
                        package.json
                        run-start.sh
                        serveronly/
                        splashscreen/
                        tests/
                        translations/
                        vendor/
                    nothing added to commit but untracked files present (use “git add” to track)
                      chetnaik
                      after performing above steps still package.json says version": “2.1.3”
                      so my question is did above process upgraded my magicmirror to v2.5.0? ??
                      here are more info from package.json file.
                      “name”: “magicmirror”,
                      “version”: “2.1.3”,
                      “description”: “The open source modular smart mirror platform.”,
                      “main”: “js/electron.js”,
                      “scripts”: {
                      “start”: “sh run-start.sh”,
                      “install”: “cd vendor && npm install”,
                      “install-fonts”: “cd fonts && npm install”,
                      “postinstall”: “sh installers/postinstall/postinstall.sh && npm run install-fonts”,
                      “test”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests --recursive”,
                      “test:unit”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests/unit --recursive”,
                      “test:e2e”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive”,
                      “config:check”: “node tests/configs/check_config.js”
                      “repository”: {
                      “type”: “git”,
                      “url”: “git+https://github.com/MichMich/MagicMirror.git”
                      “keywords”: [
                      “magic mirror”,
                      “smart mirror”,
                      “mirror UI”,
                      “modular”
                      “author”: “Michael Teeuw”,
                      “contributors”: [
                      “https://github.com/MichMich/MagicMirror/graphs/contributors”
                      “license”: “MIT”,
                      “bugs”: {
                      “url”: “https://github.com/MichMich/MagicMirror/issues”
                      “homepage”: “https://magicmirror.builders”,
                      “devDependencies”: {
                      “chai”: “^3.5.0”,
                      “chai-as-promised”: “^6.0.0”,
                      “current-week-number”: “^1.0.7”,
                      “grunt”: “^1.0.3”,
                      “grunt-eslint”: “latest”,
                      “grunt-jsonlint”: “latest”,
                      “grunt-markdownlint”: “^1.0.39”,
                      “grunt-stylelint”: “latest”,
                      “grunt-yamllint”: “latest”,
                      “http-auth”: “^3.1.3”,
                      “jshint”: “^2.9.6”,
                      “mocha”: “^5.2.0”,
                      “mocha-each”: “^1.1.0”,
                      “spectron”: “^4.0.0”,
                      “stylelint”: “^9.6.0”,
                      “stylelint-config-standard”: “latest”,
                      “time-grunt”: “latest”
                      “dependencies”: {
                      “body-parser”: “^1.17.2”,
                      “colors”: “^1.1.2”,
                      “electron”: “^3.0.2”,
                      “express”: “^4.15.3”,
                      “express-ipfilter”: “0.3.1”,
                      “feedme”: “latest”,
                      “helmet”: “^3.6.1”,
                      “iconv-lite”: “latest”,
                      “mocha-logger”: “^1.0.6”,
                      “moment”: “^2.22.2”,
                      “request”: “^2.88.0”,
                      “rrule-alt”: “^2.2.5”,
                      “simple-git”: “^1.73.0”,
                      “socket.io”: “^2.1.1”,
                      “valid-url”: “latest”,
                      “walk”: “latest”
                      • justjim1220J
                        @el97 Apologies!
                        Jim Hallock - 1995
                        • el97E
                          el97 @justjim1220
                          @justjim1220 Np. We all can read stuff wrong sometimes :P
                          • justjim1220J
                            justjim1220 Module Developer @chetnaik
                            @chetnaik
                            delete the package.json and the package lock.json
                            then retry git pull && npm install
                            Jim Hallock - 1995
                            C 1 Reply Last reply
                              chetnaik @justjim1220
                              @justjim1220 … still not working :(… I’m going to rename or move Current MM and install new version … thank you…;)
                              • justjim1220J
                                @chetnaik
                                that may be your best option
                                Jim Hallock - 1995
