    MMM-WeatherBackground
    54 Posts 14 Posters 37.4k Views 14 Watching
    • cowboysdudeC
      Well hello all…no NOAA wasn’t made to support ‘currentweather’ notifications in MM.
      It’s a stand alone module and I am SUPER busy so as of right now I have no plan to do anything with it. I do this for a hobby…I must pay attention to my real job as I’ve grown accustomed to things like food and shelter… ;) Perhaps in the next few weeks I could look at it but that is if I have time.
      • T
        texdetex
        @sean in trying to install module but im ask for User/Password
          A Former User @texdetex
          @texdetex ??? It will not ask any kind of user or password. ???
          • V
            Vauxdvihl
            @Sean
            I am using NOAA3 and i simply add the the following lines the my config:
              module: "MMM-WeatherBackground",
              // don't assign position.
              config: {}
            Unfortunately the background is still black.
            Is ther something else to consider?
            Thanks a lot
            Regards
              A Former User @Vauxdvihl
              @vauxdvihl NOAA isn’t supported.
              • V
                Vauxdvihl @Guest
                @sean
                r u sure.
                https://forum.magicmirror.builders/topic/4585/mmm-noaa-another-weather-module/520?page=52
                Greetz
                  @vauxdvihl ah, he made it.
                    @vauxdvihl
                    I think his version https://github.com/cowboysdude/MMM-WeatherBackground will be work. I don’t know it is completed or not, but you can try it.
                    • cowboysdudeC
                      This a fork of @Sean great work but remade to work with NOAA3.
                      [card:cowboysdude/MMM-WeatherBackground]
                      • V
                        Vauxdvihl
                        @cowboysdude
                        Does not work
                        Mirror stays black
                        Here is the error message
                        /home/pi/.pm2/logs/start-error.log last 15 lines:
                        0|start    |     at Module.load (module.js:561:32)
                        0|start    | { Error: Cannot find module 'dayjs'
                        0|start    |     at Module._resolveFilename (module.js:543:15)
                        0|start    |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                        0|start    |     at Function.Module._load (module.js:473:25)
                        0|start    |     at Module.require (module.js:586:17)
                        0|start    |     at require (internal/module.js:11:18)
                        0|start    |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-WeatherBackground/node_helper.js:7:15)
                        0|start    |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-WeatherBackground/node_helper.js:49:3)
                        0|start    |     at Module._compile (module.js:642:30)
                        0|start    |     at Object.Module._extensions..js (module.js:653:10)
                        0|start    |     at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
                        0|start    | libGL error: MESA-LOADER: failed to retrieve device information
                        0|start    | MESA-LOADER: failed to retrieve device information
                        Any Idea?
                        Thanks a lot
                          @vauxdvihl
                          I think it wasn’t installed properly. (@cowboysdude might have forgotten npm install in his description.)
                          cd ~/MagicMirror/modules/MMM-WeatherBackground
                          npm install
                          try again.
                          V cowboysdudeC 2 Replies Last reply Reply Quote 1
                          • V
                            Vauxdvihl @Guest
                            @sean
                            That was it
                            Works
                            Thanks a lot
                            • cowboysdudeC
                              cowboysdude Module Developer @Guest
                              @sean said in MMM-WeatherBackground:
                              @vauxdvihl
                              npm install
                              try again.
                              Thank you @Sean that’s exactly what I did LOL the Readme is corrected, Thank you!!
                                buzzman
                                @cowboysdude
                                i get this error when i do npm install
                                i@Magicmirror:~/MagicMirror/modules/MMM-WeatherBackground $ npm install
                                npm WARN mmm-weatherbackground@3.0.1 No repository field.
                                audited 63 packages in 3.748s
                                found 0 vulnerabilities
                                i get this error also
                                No helper found for module: MMM-WeatherBackground
                                i am using NOAA3 also
                                B Mykle1M 2 Replies Last reply Reply Quote 0
                                  buzzman @buzzman
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @buzzman
                                    @buzzman
                                    My advice. Delete your current MMM-WeatherBackground folder/directory. Clone the repo again
                                    git clone https://github.com/cowboysdude/MMM-WeatherBackground.git into your modules folder. cd into your new MMM-WeatherBackground directory. Run npm install. You should be golden.
                                    P.S. No helper is not an error.
                                      buzzman @Mykle1
                                      @mykle1
                                      pm notice created a lockfile as package-lock.json. You should commit this file.
                                        A Former User @buzzman
                                        @buzzman
                                        You can ignore any WARN message.
                                          buzzman
                                          @mykle1 @Sean
                                          I dont know whats going on . i don’t get any weather picture. i have tried it with MMM-NOAA3 with 2 different weather api . the weather info from noaa3 is right .
                                          • cowboysdudeC
                                            cowboysdude Module Developer @buzzman
                                            @buzzman said in MMM-WeatherBackground:
                                            @mykle1 @Sean
                                            Well there may be another issue. This is the fun of the mirror…no two are alike and sometimes different problems arise.
                                            Hang in there, it’ll be working :)
