    Dealing with 404 url error in module.
    10 Posts 4 Posters 3.3k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @justjim1220
      @justjim1220
      I appreciate you trying to help but I could have kept googling myself. I’m looking for an explanation, too, and not just a random “try this!”. Thanks
        sdetweil @Mykle1
        @mykle1 sorry, you are using some words that don’t describe well what the problem is…
        i THINK you said
        when I try to load image files (local to the MM system), I use a URL string.
        that URL string is 'relative' to the base of my server, defined by '??????' (you didn't supply that)
        when a URL fails to load, I get error 404. (not found).
        but how do I handle this?
        you would add an onerror() handler for the img object
        this will get called ONLY when there is an error
        img.onerror = funtion(event_object){
        var img_with_error = event_object.currentTarget
        img_with_error.src=??? the url of the failing image
        see https://www.w3schools.com/jsref/obj_event.asp
        for more info in decoding the event object
          @sdetweil said in Dealing with 404 url error in module.:
          Yes, I’m sorry about the description but you understood my meaning, so thank you for that. :thumbsup:
          Your onerror() handler suggestion is/was exactly what I needed/wanted and works beautifully. Again, thank you. I do appreciate that you took the time to give me advice/assistance. Here is the finished, working tag:
            // picture
                      var img = document.createElement("img");
                      img.classList.add("photo");
                      img.src = EOL.eolMediaURL;
                      img.onerror = function(event_object) { //  This function replaces broken image
                      var img_with_error = event_object.currentTarget //  This function replaces broken image
                      img_with_error.src= "modules/MMM-EOL/images/darwin.jpg" // This is the path to the replacement image
                      wrapper.appendChild(img);
          I would be remiss if I did not thank @cowboysdude, as well, for his help on this module.
          S cowboysdudeC 2 Replies Last reply Reply Quote 1
            sdetweil @Mykle1
            @mykle1 note that your onerror handler could get stuck in a loop IF the forced replacement url also fails
              That’s good to know. Thanks to you again. If you were in NYC I would buy you a beer (or many). :-)
              • cowboysdudeC Offline
                @mykle1 @sdetweil came up with a beautiful answer…I didn’t do a thing LOL
