    [MMM-MyRadio] Web Radio Player
    34 Posts 13 Posters 25.6k Views 12 Watching
      deder2
      Hello, I have a problem with your module.
      the module is not displayed? the script files are well executable.
      mpg123 is well installed.
      MagicMirror is up to date.
      I use your config by default
      module: ‘MMM-MyRadio’,
      position: ‘top_right’,
      stations: [
      “Bayern1 Bayern1”,
      “Bayern3 Bayern3”,
      “Charivari Charivari”,
      Kos Kos,
      “AB AB”
      an idea ?
      • tbbearT
        tbbear Module Developer
        did u set a , after the last brackets? Did u follow the install from readme?
        Robert the Bear
        Cr4z33C 1 Reply Last reply
        • yawnsY
          yawns Moderator
          Kos Kos is missing " ", isn’t it?
          tbbearT 1 Reply Last reply
          • tbbearT
            tbbear Module Developer @yawns
            @yawns good catch i think
            Robert the Bear
              deder2
              I progress, the module is displayed but no image of chain and no sound.
                  module :  "MMM-MyRadio" ,
                          position :  "top_left",
                          config : {
                                  stations : [
                                           " Bayern1 Bayern1 " ,
                                           " Bayern3 Bayern3 " ,
                                           " Charivari Charivari " ,
                                           " Kos Kos " ,
                                           " AB AB "
              • tbbearT
                tbbear Module Developer @deder2
                @deder2 please remove the blanks before and after a station it should look like
                “Bayern1 Bayern1“
                Robert the Bear
                  deder2
                  great, no space it works for pictures.
                  however, I created two radios (two script files and two image files)
                  but I still have the names of the old radio Bayern1 AB …
                  And still no sound.
                              config : {
                                      stations : [
                                               "rtl rtl" ,
                                               "latina latina" ,
                  script :
                  #!/bin/bash
                  killall mpg123
                  sleep 0.1
                  mpg123 -@ http://streaming.radio.rtl.fr/rtl-1-44-128.m3u 1>~/MagicMirror/modules/MMM-MyRadio/RDS.log
                  thank you
                  • tbbearT
                    @deder2 Are u sure that ur audio configuration is working? U can play sound? I had the most problems
                    with setting up the audio config on the diff. systems so please check if this works.
                    After changing to ur stations (by the the way i checked ur mpg123 -@ http://streaming.radio.rtl.fr/rtl-1-44-128.m3u
                    and its working fine on my system. Try on ur own call from terminal: mpg123 -@ http://streaming.radio.rtl.fr/rtl-1-44-128.m3u
                    if u hear nothing than its a problem of ur audio config.
                    Robert the Bear
                      deder2
                      thank you for your help and sorry for my english.
                      in the console the sound works with this command
                      I planned to use MMM-voice to control your module.
                      The sound of the radio must launch directly at the start of the magicmirror?
                        deder2
                          deder2
                          • Cr4z33C
                            Cr4z33 @tbbear
                            Hi @tbbear, is there any chance you can get m3u8 streams working with your module by ie. using cvlc instead? :)
                            mpg123 can’t handle this format right now.
                            • Cr4z33C
                              Cr4z33 @tbbear
                              @tbbear you there mate?
                              • E
                                electros Project Sponsor
                                Hi, I’m trying to use this player with wireless speakers. But without success. Maybe somebody did this and it can help me?
