    how to pull new element added to an array?
    57 Posts 4 Posters 28.7k Views 4 Watching
    • justjim1220J
      justjim1220 Module Developer @sdetweil
      this is how I was able to modify the code to show a single icon and to get it to scroll across the screen
      https://forum.magicmirror.builders/assets/uploads/files/1539381868184-screenshot-146.png
      Jim Hallock - 1995
        right… you hard coded it…
        • justjim1220J
          So, is what I am wanting to do even possible?
          Jim Hallock - 1995
            sdetweil @justjim1220
            @justjim1220 sure… just have to figure out how to find the feeds entry from the newsItem entry… you MAY/PROBABLY have to add something to the newsItem entries (every one) when they are placed in the newsItem array…
            i can’t look at any of the rss code til thursday sometime…
            • justjim1220J
              Is this what I am looking for?
              Jim Hallock - 1995
                Note that that data is not part of the item. What code moves the xml to the Json object you are accessing?
                  looking at the code on my phone, the fetcher.js needs another method to parse out the source icon.
                  parser.on("image", function(image){})
                  To set a variable with the icon url,
                  That u can use in the
                  parser.on("item", function(item)
                  To add the icon url to each item to be able to use it during the display process
                    A Former User @justjim1220
                    @justjim1220
                    But not all RSS would have that channel.image. that is optional.
                    justjim1220J 1 Reply Last reply Reply Quote 1
                    • justjim1220J
                      justjim1220 Module Developer @Guest
                      @sdetweil @sean
                      SO, I changed this part of the fetcher, but, after reading your posts, I am not sure if this is what you are talking about…
                      parser.on("item", function(item) {
                      			var title = item.title;
                      			var image = item.image || item.logo || item.img || item.svg || "";
                      			var description = item.description || item.summary || item.content || "";
                      			var pubdate = item.pubdate || item.published || item.updated || item["dc:date"];
                      			var url = item.url || item.link || "";
                      			if (title && pubdate) {
                      				var regex = /(<([^>]+)>)/ig;
                      				description = description.toString().replace(regex, "");
                      				items.push({
                      					title: title,
                      					image: image,
                      					description: description,
                      					pubdate: pubdate,
                      					url: url,
                      			} else if (logFeedWarnings) {
                      				console.log("Can't parse feed item:");
                      				console.log(item);
                      				console.log("Title: " + title);
                      				console.log("Image: " + image);
                      				console.log("Description: " + description);
                      				console.log("Pubdate: " + pubdate);
                      It is looking like you are telling me I need to add a new section to the fetcher similar to this, but starting with
                      			var title = image.title;
                      			var image = image.image || image.logo || image.img || image.svg || "";
                      			var url = image.url || image.link || "";
                      and would I also need this part?
                                              if (image&& url) {
                      				images.push({
                      					title: title,
                      					image: image,
                      					url: url,
                      				console.log(item);
                      And, would this be the way to add the image url in the config…
                                                      imageUrl: "https://static01.nyt.com/images/misc/NYT_logo_rss_250x40.png",
                                                      title: "New York Times",
                                                      imageUrl: "http://online.wsj.com/img/wsj_sm_logo.gif",
                      				title: "Wall St. Journal",
                      				url: "http://www.wsj.com/xml/rss/3_7085.xml"
                                                      imageUrl: "http://www.gannett-cdn.com/sites/usatnetwork/images/RSS_Syndication_Logo-USATN.png",
                      				title: "USA Today",
                      				url: "http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories"
                                                      imageUrl: "https://news.bbcimg.co.uk/nol/shared/img/bbc_news_120x60.gif",
                      				title: "BBC World News",
                      				url: "http://feeds.bbci.co.uk/news/world/rss.xml#"
                      Sorry, for all the questions, just really trying to learn all this…
                      AND, thanks for all your help!!! :smiling_face_with_sunglasses:
                      Jim Hallock - 1995
                        ok, then to use the definition in the feed entry
                        modify the node helper
                        			fetcher = new Fetcher(url, reloadInterval, encoding, config.logFeedWarnings);
                        			fetcher.onReceive(function(fetcher) {
                                                        // add code here to run thru the array of feed response items and add the icon url to each entry..
                                                        // the feed definition was passed in as parm to the containing method..   because this is a callback, you will probably have to bind the feed definition to this function
                                                        for( var item in fetcher.items())
                                                             item.icon=this.feed_def.icon;
                        				self.broadcastFeeds();
                        			}.bind({feed_def:feed}))
                        • justjim1220J
                          well, sort of lost me there, but also getting a headache.
                          Gotta run some errands, I’ll look at it some more after a while.
                          AGAIN, THANK YOU for all the help!!!
                          Jim Hallock - 1995
                            @justjim1220 said in how to pull new element added to an array?:
                            var image = item.image || item.logo || item.img || item.svg || “”;
                            that looks good, except as you note, these are optional in the response (item) data.
                            do you want to use the configured url for the feed if not present?
                            var image = item.image || item.logo || item.img || item.svg || xxxx.yyy.icon || "";
                            the feed definition is passed into the fetcher function. except that routine could have ended seconds ago, when the parser.on(item) method is called (by the callback)…
                            so, what should xxxx.yyy be? can’t use the parm feed directly, as the routine could have exited already…
                            so, javascript gives you the ability to bind (connect) a variable with a routine when it is called asyncronously…
                            when u bind the variable, it will be accessible in the context of the function, context = this,
                            so, on the close brace of the function defined on the .on(), add the .bind() clause.
                            inside the bind clause, you specify the name of the variable INSIDE the function, and connect it to the variable at the time the .on() definition is called… (ie ‘feed’)…
                            so,
                            }.bind({feed_var_in_function:feed})
                            then when the function is called, you can get access to the variable using ‘this’…
                            this.feed_var_in_function.icon, would be the icon defined for THIS feed
                            therefore the stmt above would be
                            var image = item.image || item.logo || item.img || item.svg || this.feed_var_in_function.icon || "";
                            this says, use any of the optional images in the feed item, if present,
                            else use the user defined feed icon,
                            else nothing if not defined…
                            • justjim1220J
                              ok, so do I need to add it like this:
                              			var image = image.image || image.logo || image.img || image.svg || this.feed_var_in_function.icon || "";
                              Or, like this:
                              Jim Hallock - 1995
                              • cowboysdudeC
                                Why are making this so hard?
                                • justjim1220J
                                  justjim1220 Module Developer @cowboysdude
                                  @cowboysdude
                                  GOD, I WISH I KNEW!!!
                                  Jim Hallock - 1995
                                  • justjim1220J
                                    @sdetweil, @cowboysdude, @Sean
                                    I created a repository, hopefully it will make it easier for you to help.
                                    https://github.com/justjim1220/MMM-NewsFeedTicker
                                    ALL help is MUCH APPRECIATED!!!
                                    I gotta learn this stuff one way or another!
                                    Jim Hallock - 1995
                                      @justjim1220 I am trying to test my changes, but the module getDom() method is never called…
                                      changed the module name in module.js to match the file name and config module name.
                                      loads with no errors, shows loading the module js and registering the module…
                                      • justjim1220J
                                        What is the possibility of using and array of sorts?
                                        place the logos in a pics folder, call them according to the newsItem[activeItem].title, Ive seen some examples, and tried it a few different ways, but not sure if I am missing something as I can’t get it to work.
                                        recent example tried:
                                        feeds…
                                                        title: "New York Times: ",
                                                        title: "Wall St. Journal: ",
                                                        title: "USA Today: ",
                                                        title: "BBC World News: ",
                                        Array…
                                        iconArray: {
                                                    "USAToday": "USA Today: ",
                                                    "NewYorkTimes": "New York Times: ",
                                                    "WallStJournal": "Wall St. Journal: ",
                                                    "BBCWorldNews": "BBC World News: "
                                        Added this to start function…
                                         this.logo = {};
                                        sample code…
                                        var logo = this.logo;
                                                    if (this.config.showDescription) {
                                                        var description = document.createElement("div");
                                                        //description.setAttribute("style", "padding-top: 25px");
                                                        description.className = "bright xlarge bold" + (!this.config.wrapDescription ? " no-wrap" : "");
                                                        var txtDesc = this.newsItems[this.activeItem].description;
                                                        description.innerHTML = "<img class = image src=./modules/default/newsfeed/pics/" + logo.icon + ".png height=150px valign=middle>" + "<marquee scrollamount=20 scrolldelay=0 left=500px>" + "<font color=yellow>" + moment(new Date(this.newsItems[this.activeItem].pubdate)).fromNow() + "&nbsp; : &nbsp;" + "</font>" + this.newsItems[this.activeItem].title + "&nbsp; || &nbsp;" + txtDesc + "</marquee>";
                                                        wrapper.appendChild(description);
                                        Any chance this could work easier if I had it coded correctly?
                                        Seems Like I should be declaring the
                                        to equal the icon/logo in some fashion…
                                        Jim Hallock - 1995
                                          @justjim1220 no, not really…
                                          • justjim1220J
                                            ok, just a thought, seen it with a few other modules. Thanks!
                                            Jim Hallock - 1995
                                            • 2 / 3
