Unsolved MMM-PC-Stats
Can you open the threads array?
jim@jim-Aspire-4520:~$ sensors Command 'sensors' not found, but can be installed with: sudo apt install lm-sensors
YOu installed the dependencie?
Yeppers.
How do I open the threads array?
I can reinstall the dependencies if you want me to
Comment out
console.log(this.Stats)
so you only get the sensors output -
@mykle1 ok
Take a screenshot of just the output, not the whole screen. I might be able to see it then
pop@HPEu:~/MagicMirror$ sensors nouveau-pci-0100 Adapter: PCI adapter fan1: 1110 RPM temp1: +39.0°C (high = +95.0°C, hyst = +3.0°C) (crit = +105.0°C, hyst = +5.0°C) (emerg = +135.0°C, hyst = +5.0°C) coretemp-isa-0000 Adapter: ISA adapter Core 0: +29.0°C (high = +83.0°C, crit = +99.0°C) Core 1: +30.0°C (high = +83.0°C, crit = +99.0°C) Core 2: +29.0°C (high = +83.0°C, crit = +99.0°C) Core 3: +28.0°C (high = +83.0°C, crit = +99.0°C) f71858fg-isa-0a00 Adapter: ISA adapter +3.3V: +3.31 V 3VSB: +3.31 V Vbat: +3.20 V fan1: 1910 RPM fan2: 998 RPM fan3: 0 RPM ALARM temp1: +29.2°C (high = +70.0°C, hyst = +60.0°C) temp2: +15.4°C (high = +100.0°C, hyst = +85.0°C) temp3: +32.5°C (high = +100.0°C, hyst = +85.0°C) pop@HPEu:~/MagicMirror$ ^C pop@HPEu:~/MagicMirror$
Objectacpitz-virtual-0: {Virtual device: {…}}k8temp-pci-00c3: {PCI adapter: {…}}nouveau-pci-0090: {PCI adapter: {…}}__proto__: Object moment-timezone-with-data.js:481 Moment Timezone has no data for American/Chicago. See http://momentjs.com/timezone/docs/#/data-loading/. logError @ moment-timezone-with-data.js:481 MMM-PC-Stats.js:126 Uncaught (in promise) TypeError: Cannot read property 'ISA adapter' of undefined at Class.getDom (MMM-PC-Stats.js:126) at main.js:110 at new Promise (<anonymous>) at updateDom (main.js:109) at Object.updateDom (main.js:514) at Class.updateDom (module.js:358) at Class.socketNotificationReceived (MMM-PC-Stats.js:262) at module.js:246 at r.<anonymous> (socketclient.js:25) at r.emit (index.js:83) MMM-PC-Stats.js:126 Uncaught (in promise) TypeError: Cannot read property 'ISA adapter' of undefined at Class.getDom (MMM-PC-Stats.js:126) at main.js:110 at new Promise (<anonymous>) at updateDom (main.js:109) at Object.updateDom (main.js:514) at Class.updateDom (module.js:358) at Class.socketNotificationReceived (MMM-PC-Stats.js:268) at module.js:246 at r.<anonymous> (socketclient.js:25) at r.emit (index.js:83)
jim@jim-Aspire-4520:~/MagicMirror$ sensors k8temp-pci-00c3 Adapter: PCI adapter Core0 Temp: +69.0°C Core0 Temp: +67.0°C Core1 Temp: +69.0°C Core1 Temp: +68.0°C acpitz-virtual-0 Adapter: Virtual device temp1: +71.0°C (crit = +100.0°C) nouveau-pci-0090 Adapter: PCI adapter GPU core: +1.20 V (min = +1.00 V, max = +1.20 V) temp1: +64.0°C (high = +95.0°C, hyst = +3.0°C) (crit = +105.0°C, hyst = +2.0°C) (emerg = +135.0°C, hyst = +5.0°C)
