    MMM-NewsFeedTicker
    94 Posts 15 Posters 76.5k Views 14 Watching
    • Cr4z33C Offline
      Cr4z33
      @justjim1220 what should i put into
      defaultLogo : ""
      if I would like i.e to use a different logo?
      Also what is the max. image size accepted (in MegaBytes and pixels) please? :)
      Can we load various RSS into rotation into the same line?
      • E Offline
        electros Project Sponsor @justjim1220
        @justjim1220
        Hi, this is what I add to custom.css
        MMM-NewsFeedTicker {
            height: 40px;
            background-color: black;
            margin-left: 20%;
        .MMM-NewsFeedTicker .tickerbody {
            position: absolute;
            bottom: 7px;
        .MMM-NewsFeedTicker .image {
          position: absolute;
          margin-left: 20%;
          bottom: 7px;
          height: 40px;
        but i find what the problem is:
        When i change the color of background to black just i hide background but that is not in same line like writing, is upper for that reason the writing is not hidden when go over the buttons. i change back the background to maroon and you can see the difference0_1540574544136_4.png
        • justjim1220J Offline
          justjim1220 Module Developer @electros
          @electros
          ok,
          change background-color to background: none;
          and,
          change position back to relative under the image section
          should work for you…
          "Life's Too Short To Dance With Ugly People"
          Jim Hallock - 1995
          E Cr4z33C 2 Replies Last reply Reply Quote 0
          • E Offline
            @justjim1220
            I tried but it does not work. Now in custom.css it looks like this:
            .MMM-NewsFeedTicker {
                height: 40px;
                background-color: none;
                margin-left: 20%;
                position: absolute;
                bottom: 7px;
              position: relative;
              margin-left: 20%;
              bottom: 7px;
              height: 40px;
            And the screen is like that:
            • E Offline
              The problem is just to move that red line to bottom under the writing line and after that everything it’s fine. Thanks
              justjim1220J 2 Replies Last reply Reply Quote 0
                @electros
                Apologies!
                Looks like I did tell you wrong about the position…
                Here is the css that makes it work for me, try them and let me know…
                @keyframes marquee {
                    0% {left: 100%;}
                    100% {left: -100%;}
                    width: 100%;
                    height: 100px;
                    line-height: 100%;
                    overflow: hidden;
                    background: none;
                    margin-left: 20%;
                    position: relative;
                    bottom: 0;
                    left: 0;
                    vertical-align: middle;
                    white-space: nowrap;
                    text-align: left;
                    animation: marquee 31s linear;
                .MMM-NewsFeedTicker .headline {
                    padding-top: 15px;
                    margin: 0 auto;
                  position: absolute;
                  display: inline-block;
                  bottom: 10;
                  margin-left: 0;
                  height: 100px;
                  z-index: 10;
                  background-color: #FFF;
                Jim Hallock - 1995
                  @electros
                  what is the name of the module for the buttons?
                  Jim Hallock - 1995
                  • E Offline
                    @justjim1220
                    Sorry but it’s not working. I copied the css you put above in MMM-NewsFeedTicker.css but it still does not work. Now it looks like that
                    Buttons are created with the module “MMM-TouchNavigation”
                      @electros
                      do you still have the entries you put into the custom.css?
                      Jim Hallock - 1995
                        @electros
                        OK, you need to add the following to your custom.css file:
                        .navigation-menu {
                            display: flex;
                            align-items: stretch;
                            position: absolute;
                        With the code I posted and this addition to the custom.css file, I was able to get this…
                        If you added any NewsFeedTicker code to your custom.css file, you need to remove it.
                        If you want the background color back to maroon, change the background: none; to background-color: maroon;
                        Jim Hallock - 1995
                        • 10
                        • 1 / 10
