    MMM-NewsFeedTicker
    94 Posts 15 Posters 86.4k Views 14 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @electros
      @electros
      Apologies!
      Looks like I did tell you wrong about the position…
      Here is the css that makes it work for me, try them and let me know…
      @keyframes marquee {
          0% {left: 100%;}
          100% {left: -100%;}
      .MMM-NewsFeedTicker {
          width: 100%;
          height: 100px;
          line-height: 100%;
          overflow: hidden;
          background: none;
          margin-left: 20%;
      .MMM-NewsFeedTicker .tickerbody {
          position: relative;
          bottom: 0;
          left: 0;
          vertical-align: middle;
          white-space: nowrap;
          text-align: left;
          animation: marquee 31s linear;
      .MMM-NewsFeedTicker .headline {
          padding-top: 15px;
          margin: 0 auto;
      .MMM-NewsFeedTicker .image {
        position: absolute;
        display: inline-block;
        bottom: 10;
        margin-left: 0;
        height: 100px;
        z-index: 10;
        background-color: #FFF;
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
        @electros
        what is the name of the module for the buttons?
        Jim Hallock - 1995
        • E Offline
          electros Project Sponsor @justjim1220
          @justjim1220
          Sorry but it’s not working. I copied the css you put above in MMM-NewsFeedTicker.css but it still does not work. Now it looks like that
          Buttons are created with the module “MMM-TouchNavigation”
          justjim1220J 2 Replies Last reply Reply Quote 0
            @electros
            do you still have the entries you put into the custom.css?
            Jim Hallock - 1995
              @electros
              OK, you need to add the following to your custom.css file:
              .navigation-menu {
                  display: flex;
                  align-items: stretch;
                  position: absolute;
              With the code I posted and this addition to the custom.css file, I was able to get this…
              If you added any NewsFeedTicker code to your custom.css file, you need to remove it.
              If you want the background color back to maroon, change the background: none; to background-color: maroon;
              Jim Hallock - 1995
              • E Offline
                @justjim1220
                Finally it’s working now. Thank you very much:thumbs_up:
                • E Offline
                  Thank you very much for the help, but still I do not understand how you moved that red line down. I would be curious, can not get any position you want on the vertical for this module?
                    @electros
                    you should be able to place it in any of the regions,
                    it works best in the top_bar, middle_center, and bottom_bar for the 100% width
                    Jim Hallock - 1995
                    • Cr4z33C Offline
                      Cr4z33
                      • Cr4z33C Offline
                        Cr4z33
                        @justjim1220 can you please help me setting a custom logo into
                        defaultLogo : ""
                        I’ve tried so far with several image formats and I’ve used both HTTP and HTTPS, but it still doesn’t load the logo… :thinking_face:
                          justjim1220 Module Developer @Cr4z33
                          @cr4z33
                          what news site is it?
                          Jim Hallock - 1995
                          • Cr4z33C Offline
                            Cr4z33 @justjim1220
                            @justjim1220 said in MMM-NewsFeedTicker:
                            @cr4z33
                            It’s
                            http://feeds.feedburner.com/SkyitTg24
                            and I would like to load
                            https://tg24.sky.it/static/images/lv/skytg24_logo_header.png
                            as default icon (also because I notice that ALL the news feeds I set don’t show the icon in the scrolling bar).
                            Last but not least is it normal that it uses almost 50% of the CPU load? :frowning_face_with_open_mouth:
                            I’ve got a Raspberry Pi 3 B+ and a Samsung EVO Plus 32GB micro SD card.
                            Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                              Mykle1 Project Sponsor Module Developer @Cr4z33
                              @cr4z33 said in MMM-NewsFeedTicker:
                              It sure is. The Pi struggles with that type of animation. I’m surprised it’s only 50%. You should monitor your CPU temp, as well.
                              • Cr4z33C Offline
                                Cr4z33 @Mykle1
                                @mykle1 said in MMM-NewsFeedTicker:
                                So it’s not a matter of not so fast SD card then right?
                                I am using a heatsink on it therefore the average temperature so far is between 50° Celsius and 60° Celsius.
                                  Well, it could be, but that’s unlikely. The CPU load issue has been around for some time and animations, especially marquee animations(scrolling) are the #1 culprit, or I miss my mark. Of course, if you used something more robust than a Pi that has a GPU you’d see a world of difference in the way MM performs.
                                    @cr4z33
                                    Apologies, I am working on the issue of using a custom logo if one doesn’t get pulled from the site.
                                    Please stand by… :smiling_face_with_sunglasses:
                                    Jim Hallock - 1995
                                    mumblebajM 1 Reply Last reply Reply Quote 1
                                      some found sports news that work for those interested…
                                      http://www.espn.com/espn/news/story?page=rssinfo for all sports
                                      http://www.espn.com/espn/rss/nfl/news for NFL
                                      https://www.foxsports.com/rss-feeds for list of all sports
                                      https://api.foxsports.com/v1/rss?partnerKey=zBaFxRyGKCfxBagJG9b8pqLyndmvo7UU&tag=nfl for NFL
                                      https://www.cbssports.com/xml/rss for all sports
                                      https://www.cbssports.com/rss/headlines/nfl/ for NFL
                                      https://www.rotowire.com/rss/ for all sports
                                      https://www.rotowire.com/rss/news.htm?sport=nfl for NFL
                                      I also wanted to add that if you place the newsfeeds in the config, it also works better to place them in the js file as well. Not sure why, but I noticed that it does.
                                      So, wanted to pass that on.
                                      I am still working on getting a custom logo to show if one does not get pulled from the rss site.
                                      Jim Hallock - 1995
                                      • Cr4z33C Offline
                                        Cr4z33 @justjim1220
                                        @Mykle1 thanks for clearing things out.
                                        Take your time don’t worry. ;)
                                        In the meantime I am going to try too to put everything into the NewsFeeds js and see how things work.
                                        Update
                                        I saw no improvements by inserting the feeds straight into the JS. :disappointed_face:
                                        • Cr4z33C Offline
                                          Cr4z33
                                          Sorry @justjim1220 I noticed only now that you removed the newsfeed ticker background in your latest screenshots.
                                          I would like to try that out and see if performance improves. :)
                                          How do you do that?
                                            @cr4z33
                                            In the css file, just change background-color: maroon; to background: none;
                                            can be done with the image as well, but that could make the image difficult to see.
                                            Jim Hallock - 1995
                                            • 1 / 5
