    Syntax Errorn in Config.js
    11 Posts 6 Posters 5.1k Views 6 Watching
      sollekram
      syntax error while strarting mm, am i forgeting something?
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Hot News",
      						url: "http://www.ert.gr/feed/"
      				showSourceTitle: true,
      				showPublishDate: true
      		    module: 'MMM-Assistant',
      		    position: 'bottom_left',
      		        assistant: {
      		            auth: {
      		                keyFilePath:     "assets/google-client-secret.json", // REQUIRED (Google Assistant API) -- OAuth2 x509 cert
      		                savedTokensPath: "assets/google-access-tokens.json"  // REQUIRED (Google Assitant API) -- accesss_token & refresh_token
      		            conversation: {
      		                lang: 'en-US',
      		                audio: {
      		                    encodingIn: "LINEAR16",  // Default. No need to change.
      		                    sampleRateOut: 16000     // Default. No need to change.
      		        snowboy: {
      		            models: [
      		                    hotwords : "MIRROR"                           // Default model: "MIRROR". (This is not the wake word!)
      		                    file: "resources/smart_mirror.umdl", // This file define your MM wake word. (See doc notes.)
      		                    sensitivity: 0.5,                             // 0.5
      		                    hotwords : "ASSISTANT"                        // Default model: "ASSISTANT". (This is not the wake word!)
      		                    file: "resources/snowboy.umdl",      // This file define your GA wake word. (See doc notes.)
      		        record: {
      		            threshold: 0,                 // Default. No need to change.
      		            verbose: false,               // Default: true  -- for checking recording status.
      		            recordProgram: 'rec',         // You can also use 'arecord' or 'sox', but we recommend 'rec'
      		            silence: 2.0                  // Default. No need to change.
      		}, // END
      UPDATE:Solved
      justjim1220J strawberry 3.141S 2 Replies Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @sollekram
        @sollekram said in Syntax Errorn in Config.js:
        module: “currentweather”,
        position: “top_right”,
        locationID: “”, //ID from http://www.openweathermap.org/help/city_list.txt
        appid: “YOUR_OPENWEATHER_API_KEY”
        module: “weatherforecast”,
        header: “Weather Forecast”,
        locationID: “5128581”, //ID from http://www.openweathermap.org/help/city_list.txt
        one thing I see is a blank spot…
        locationID: "", can’t be left blank
        use the same code for weatherforecast: locationID: "5128581",
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @sollekram
          @sollekram mmm-assistant has missing commas in the lines of the hotwords
            sollekram @strawberry 3.141
            @strawberry-3-141 pfff that commas…how I always stuck in such of errors…
            Anyway thank you guys for the answers , I will check the commas and the location tommorow , and I will update.
              robiv8
              hotwords: “MIRROR” missing comma ,
              hotwords: “ASSISTANT” missing comma ,
              • lavolp3L Offline
                lavolp3 Module Developer @sollekram
                @sollekram Next time, it’s advisable to run
                npm run config:check
                This will tell you the errors.
                You can then e.g.
                sudo nano -c config.js
                to have the line numbers in nano and look up the lines.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                CyruS1337C 1 Reply Last reply Reply Quote 0
                • CyruS1337C Offline
                  CyruS1337 Project Sponsor @lavolp3
                  @lavolp3 Is not there somewhere a list of all the commands that are recommended for the MagicMirror.
                  Also how to drive down the Raspberry PI Properly. I found a lot of different species on the internet. I now use the following shutdown command:
                  sudo shutdown -h now
                    sollekram
                    I finally fixed it!!
                    Thank you guys !!!
                    • lavolp3L Offline
                      lavolp3 Module Developer @CyruS1337
                      @cyrus1337 I think this command is also included in the README of MM.
                      But it may be worth setting up a list. Don’t know. Maybe I’ll try :-)
                      Your shutdown command is the one I would use as well.
                      There are different commands giving the same result. The one you mentioned is the one mostly recommended.
                        @lavolp3 Ok, then I’m glad I’m using the right command. Partially, the PI is not averse, for whatever reason. Then I just pull the plug.
                        The list would really be a great idea. Because I’m really a newbi in this area. I can probably do various things on the PC, but the whole programming language are hieroglyphs for me, if you have mine. Because I have no background in this field. Maybe I can help you in another area 😉
                        • lavolp3L Offline
                          @cyrus1337 If you’re really into the magicmirror stuff, it might be worth the time to do a little javascript training. There are courses all around the net, I’m currently doing some courses that have been offered for free on udemy.
                          https://www.udemy.com/javascriptfundamentals/
                          It may help a lot with not too much effort.
