    Syntax Errorn in Config.js
    11 Posts 6 Posters 5.7k Views 6 Watching
    • justjim1220J
      justjim1220 Module Developer @sollekram
      @sollekram said in Syntax Errorn in Config.js:
      module: “currentweather”,
      position: “top_right”,
      locationID: “”, //ID from http://www.openweathermap.org/help/city_list.txt
      appid: “YOUR_OPENWEATHER_API_KEY”
      module: “weatherforecast”,
      header: “Weather Forecast”,
      locationID: “5128581”, //ID from http://www.openweathermap.org/help/city_list.txt
      one thing I see is a blank spot…
      			module: "currentweather",
      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      locationID: "", can’t be left blank
      use the same code for weatherforecast: locationID: "5128581",
      Jim Hallock - 1995
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @sollekram
        @sollekram mmm-assistant has missing commas in the lines of the hotwords
          sollekram @strawberry 3.141
          @strawberry-3-141 pfff that commas…how I always stuck in such of errors…
          Anyway thank you guys for the answers , I will check the commas and the location tommorow , and I will update.
            robiv8
            hotwords: “MIRROR” missing comma ,
            hotwords: “ASSISTANT” missing comma ,
            • lavolp3L
              lavolp3 Module Developer @sollekram
              @sollekram Next time, it’s advisable to run
              npm run config:check
              This will tell you the errors.
              You can then e.g.
              sudo nano -c config.js
              to have the line numbers in nano and look up the lines.
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              CyruS1337C 1 Reply Last reply Reply Quote 0
              • CyruS1337C
                CyruS1337 Project Sponsor @lavolp3
                @lavolp3 Is not there somewhere a list of all the commands that are recommended for the MagicMirror.
                Also how to drive down the Raspberry PI Properly. I found a lot of different species on the internet. I now use the following shutdown command:
                sudo shutdown -h now
                  sollekram
                  I finally fixed it!!
                  Thank you guys !!!
                  • lavolp3L
                    lavolp3 Module Developer @CyruS1337
                    @cyrus1337 I think this command is also included in the README of MM.
                    But it may be worth setting up a list. Don’t know. Maybe I’ll try :-)
                    Your shutdown command is the one I would use as well.
                    There are different commands giving the same result. The one you mentioned is the one mostly recommended.
                    • CyruS1337C
                      @lavolp3 Ok, then I’m glad I’m using the right command. Partially, the PI is not averse, for whatever reason. Then I just pull the plug.
                      The list would really be a great idea. Because I’m really a newbi in this area. I can probably do various things on the PC, but the whole programming language are hieroglyphs for me, if you have mine. Because I have no background in this field. Maybe I can help you in another area 😉
                      • lavolp3L
                        @cyrus1337 If you’re really into the magicmirror stuff, it might be worth the time to do a little javascript training. There are courses all around the net, I’m currently doing some courses that have been offered for free on udemy.
                        https://www.udemy.com/javascriptfundamentals/
                        It may help a lot with not too much effort.
