    Motion Detector
    213 Posts 38 Posters 584.3k Views 39 Watching
    • cowboysdudeC
      I just typed in the sudo modprobe bcm2835-v4l2 and it returned nothing so I’m guessing that’s a good thing LOL
      • cowboysdudeC
        So this is what I’ve done and it solved it…
        I took your sudo modprobe bcm2835-v4l2 and entered before I started the mirror and no more error so I started the mirror in dev and it was registering movement…Great!
        So I closed the mirror and restarted… same error, driver not loaded…
        so I did this in case of a power out,e tc…in a terminal window:
        sudo crontab -e
        Enter this on the last line:
        @reboot sudo modprobe bcm2835-v4l2
        Saved and exited.
        Reboot
        Restart mirror in dev mode
        NO error and tracks movement
        close mirror and restart in dev
        NO error and tracks movement.
        PROBLEM SOLVED!! Thank you guys for being patient!! It’s working.
        Reply Quote 3
        • T
          trividar
          Thank you guys! you are amazing!
            sero
            Same here, works like a charm!
            Thanks guys :)
            • A
              alexyak
              Huge thank you to @strawberry-3-141 for helping to troubleshoot this issue and suggesting the solution! While I know all kinds of dev languages and tools, I am pretty new RPI and Linux.
              • T
                trividar
                Hi guys,
                I have a problem. My MM do not turn on the display in the morning. I is possible that my pi camera is in a kind of sleepmode or standby? I have to restart with pm2 stop mm and start again an than it works fine.
                • cowboysdudeC
                  cowboysdude Module Developer @trividar
                  @trividar said in Motion Detector:
                  Hi guys,
                  I have encountered that MANY times… don’t exactly know why myself… It’s not just this module it happens with most of them… I believe once it sleeps long enough the PI doesn’t want to wake up LOL
                    cpramhofer
                    Hi Guys,
                    had exactly the same problem with mit Raspi NOIR Cam V2.1.
                    the sudo modprobe bcm2835-v4l2 command solved my problem.
                    maybe you should add this Tipp in your Readme as many people out there have the same problem.
                    greets
                    Christoph
                    • T
                      trividar
                      Hi Christoph
                      Unfortunately it didn’t work for me;o( Today my screen did not turn on. My Pi works and I can connect over ssh but I have to stop and start my MM and thank works again fine. I just think that my camera stop working if there is no motion a long time (during night).
                      I got some errors during the night:
                      • A
                        alihallo
                        First of all, I also had the problem which could be solved by adding
                        at the last line of the crontab. Thank you very much!
                        It works fine for some hours, but suddenly the monitor does not show up again.
                        I cannot see error messages, but the following commands does not get an answer anymore…
                        /opt/vc/bin/tvservice -s
                        There is no return value anymore, it is just loading forever.
                        In the log it looks like this:
                        mm-0 monitor :state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
                        mm-0 monitor has been activated
                        mm-0 monitor :state 0x120002 [TV is off]
                        mm-0 monitor has been deactivated
                        mm-0 monitor :
                        mm-0 monitor :
                        mm-0 monitor :
                        As soon as the problem occures, the command
                        /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
                        also does not switch the monitor on again.
                        It seems that the tvservice command just got a problem after some hours… Any idea how to solve this?
                        I need to restart the pi to get the monitor on again, after that everything works fine for some hours…
                        Best regards,
                        alihallo
                          cpramhofer
                          Hi alihallo,
                          i have exact the same problem. i also added the @reboot sudo modprobe bcm2835-v4l2 command into my cronetab.
                          but once the screen is off for some hours it will not switch on again.
                          for me it seems that the RPi 3 is going into some kind of sleepmode if the monitor is switched off for too long.
                          kind regards
                          Christoph
                          • cowboysdudeC
                            cowboysdude Module Developer @cpramhofer
                            • paphkoP
                              paphko
                              Just as a side note, I have the same issue that my RasPi screen does not switch on again after a random time. But I am running v1 of the mirror (so not this motion detector module) and I use motion for motion detection. My guess is that this is an issue with the RasPi firmware because it was working fine several months ago (and I was frequently updating RasPi firmware)…
                              • cowboysdudeC
                                I just run a straight cron job with a file called pir.py that runs two other files…
                                monitor_on.sh
                                monitor_off.sh
                                It’s not incorporated into the mirror it runs the entire pi and I’ve had great luck with it! :)
                                  cpramhofer @cowboysdude
                                  hi @cowboysdude ,
                                  could you please give me (and maybe others) the detailed instruction how these files look in detail and where those are located?
                                  thanks a lot in advance,
                                  Christoph
                                    cpramhofer
                                    here is what i have done, actually it works - i will watch it a few days.
                                    switch to /bin/
                                    cd /
                                    cd bin
                                    open nano and create a shell script
                                    sudo nano monitor_on.sh
                                    write the “On” Command in it and save with Ctrl+x
                                    /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chat 7
                                    open nano and create another shell script
                                    sudo nano monitor_off.sh
                                    write the “Off” Command in it and save with Ctrl+x
                                    /opt/vc/bin/tvservice -o
                                    make both shell scripts executable
                                    sudo chmod +x monitor_off.sh
                                    sudo chmod +x monitor_on.sh
                                    open the crontab and add the following at the end
                                    switches the monitor off and on every 15 minutes. this is for experimenting, i will look how it works and will set the
                                    time up as.
                                    15 * * * * sudo /bin/monitor_off.sh
                                    15 * * * * sudo /bin/monitor_on.sh
                                    @reboot sudo modprobe bcm2835-vl2
                                    • cowboysdudeC
                                      Well hey Thanks for making that easy… was JUST working on that LOL I’m putting it on github with instructions and the files…
                                      • cowboysdudeC
                                        https://github.com/cowboysdude/Pir-Sensor
                                        • cowboysdudeC
                                          Update:
                                          Monitor was only partially coming back on this should fix that.
                                            chengstark
                                            my monitor won’t turn back on
                                            when I run “npm start dev”, it shows “compare result=Infinity,Infinity;0,0” , seems like it can’t capture any movement
                                            the camera module works outside MagicMirror
                                            when I tried “sudo modprobe bcm2835-v4l2”, it says “modprobe: invalid option – ‘4’”
                                            how can I fix this
                                            • 10
                                            • 11
                                            • 4 / 11
