    Motion Detector
    213 Posts 38 Posters 584.3k Views 39 Watching
    • cowboysdudeC
      cowboysdude Module Developer @trividar
      @trividar said in Motion Detector:
      Hi guys,
      I have a problem. My MM do not turn on the display in the morning. I is possible that my pi camera is in a kind of sleepmode or standby? I have to restart with pm2 stop mm and start again an than it works fine.
      I have encountered that MANY times… don’t exactly know why myself… It’s not just this module it happens with most of them… I believe once it sleeps long enough the PI doesn’t want to wake up LOL
        cpramhofer
        Hi Guys,
        had exactly the same problem with mit Raspi NOIR Cam V2.1.
        the sudo modprobe bcm2835-v4l2 command solved my problem.
        maybe you should add this Tipp in your Readme as many people out there have the same problem.
        greets
        Christoph
        • T
          trividar
          Hi Christoph
          Unfortunately it didn’t work for me;o( Today my screen did not turn on. My Pi works and I can connect over ssh but I have to stop and start my MM and thank works again fine. I just think that my camera stop working if there is no motion a long time (during night).
          I got some errors during the night:
          • A
            alihallo
            First of all, I also had the problem which could be solved by adding
            @reboot sudo modprobe bcm2835-v4l2
            at the last line of the crontab. Thank you very much!
            It works fine for some hours, but suddenly the monitor does not show up again.
            I cannot see error messages, but the following commands does not get an answer anymore…
            /opt/vc/bin/tvservice -s
            There is no return value anymore, it is just loading forever.
            In the log it looks like this:
            mm-0 monitor :state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
            mm-0 monitor has been activated
            mm-0 monitor :state 0x120002 [TV is off]
            mm-0 monitor has been deactivated
            mm-0 monitor :
            mm-0 monitor :
            mm-0 monitor :
            As soon as the problem occures, the command
            /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
            also does not switch the monitor on again.
            It seems that the tvservice command just got a problem after some hours… Any idea how to solve this?
            I need to restart the pi to get the monitor on again, after that everything works fine for some hours…
            Best regards,
            alihallo
              cpramhofer
              Hi alihallo,
              i have exact the same problem. i also added the @reboot sudo modprobe bcm2835-v4l2 command into my cronetab.
              but once the screen is off for some hours it will not switch on again.
              for me it seems that the RPi 3 is going into some kind of sleepmode if the monitor is switched off for too long.
              kind regards
              Christoph
              • cowboysdudeC
                cowboysdude Module Developer @cpramhofer
                • paphkoP
                  paphko
                  Just as a side note, I have the same issue that my RasPi screen does not switch on again after a random time. But I am running v1 of the mirror (so not this motion detector module) and I use motion for motion detection. My guess is that this is an issue with the RasPi firmware because it was working fine several months ago (and I was frequently updating RasPi firmware)…
                  • cowboysdudeC
                    I just run a straight cron job with a file called pir.py that runs two other files…
                    monitor_on.sh
                    monitor_off.sh
                    It’s not incorporated into the mirror it runs the entire pi and I’ve had great luck with it! :)
                      cpramhofer @cowboysdude
                      hi @cowboysdude ,
                      could you please give me (and maybe others) the detailed instruction how these files look in detail and where those are located?
                      thanks a lot in advance,
                      Christoph
                        cpramhofer
                        here is what i have done, actually it works - i will watch it a few days.
                        switch to /bin/
                        cd /
                        cd bin
                        open nano and create a shell script
                        sudo nano monitor_on.sh
                        write the “On” Command in it and save with Ctrl+x
                        /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chat 7
                        open nano and create another shell script
                        sudo nano monitor_off.sh
                        write the “Off” Command in it and save with Ctrl+x
                        /opt/vc/bin/tvservice -o
                        make both shell scripts executable
                        sudo chmod +x monitor_off.sh
                        sudo chmod +x monitor_on.sh
                        open the crontab and add the following at the end
                        switches the monitor off and on every 15 minutes. this is for experimenting, i will look how it works and will set the
                        time up as.
                        15 * * * * sudo /bin/monitor_off.sh
                        15 * * * * sudo /bin/monitor_on.sh
                        @reboot sudo modprobe bcm2835-vl2
                        • cowboysdudeC
                          Well hey Thanks for making that easy… was JUST working on that LOL I’m putting it on github with instructions and the files…
                          • cowboysdudeC
                            https://github.com/cowboysdude/Pir-Sensor
                            • cowboysdudeC
                              Update:
                              Monitor was only partially coming back on this should fix that.
                                chengstark
                                my monitor won’t turn back on
                                when I run “npm start dev”, it shows “compare result=Infinity,Infinity;0,0” , seems like it can’t capture any movement
                                the camera module works outside MagicMirror
                                when I tried “sudo modprobe bcm2835-v4l2”, it says “modprobe: invalid option – ‘4’”
                                how can I fix this
                                  cpramhofer
                                  Hi @cowboysdude
                                  thank you for your files and the explanation. what i don´t understand is how this all works together with the “Motion Detector” - i would prefere to use a camera instead of a PIR Sensor but as far as i see i have to install the pir.py file which is calling the on&off files and referring to the PIN with the connected PIR sensor.
                                  is there a way to use the on&off files with the “Motion Detector” Module?
                                  greets
                                  Christoph
                                    cpramhofer
                                    Hi guys
                                    as it looks that it isn´t an MM problem but an Pi Problem…another try:
                                    sudo nano /etc/kbd/config
                                    change the values to zero
                                    BLANK_TIME=0
                                    POWERDOWN_TIME=0
                                    good luck
                                    D 1 Reply Last reply
                                    • cowboysdudeC
                                      @cpramhofer There is a module for camera control… cannot remember the name of it but look around here I KNOW there’s one here.
                                        cpramhofer
                                        hi @cowboysdude,
                                        i´m sorry - i thought we are all speaking about the camera based motion detection by @alexyak
                                        https://github.com/alexyak/motiondetector
                                        have a nice sunday!
                                        • cowboysdudeC
                                          @cpramhofer No that’s ok… I think this thread is getting mixed between PIR sensor and camera… opps
                                          • bheplerB
                                            bhepler Module Developer
                                            Greetings! I’m slowly working my way through this thread and trying to figure out what’s going on here.
                                            What works: configurable timeout for the motiondetector seems to work just fine. Turns the screen off. Interestingly, if I’m viewing the mirror via my desktop browser, refreshing the page will turn the monitor on.
                                            What doesn’t work: turning the screen on. Even after entering sudo modprobe bcm2835-vl2
                                            Additionally, I’m seeing this in the console with the developer tools enabled:
                                            getUserMedia() no longer works on insecure origins. To use this feature, you should consider switching your application to a secure origin, such as HTTPS. See https://goo.gl/rStTGz for more details.
                                            :8080/modules/motiondetector//webcamcapture.js:78 NavigatorUserMediaError
                                            • 10
                                            • 11
                                            • 4 / 11
