    Motion Detector
    213 Posts 38 Posters 584.3k Views 39 Watching
      cpramhofer
      here is what i have done, actually it works - i will watch it a few days.
      switch to /bin/
      cd /
      cd bin
      open nano and create a shell script
      sudo nano monitor_on.sh
      write the “On” Command in it and save with Ctrl+x
      /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chat 7
      open nano and create another shell script
      sudo nano monitor_off.sh
      write the “Off” Command in it and save with Ctrl+x
      /opt/vc/bin/tvservice -o
      make both shell scripts executable
      sudo chmod +x monitor_off.sh
      sudo chmod +x monitor_on.sh
      open the crontab and add the following at the end
      switches the monitor off and on every 15 minutes. this is for experimenting, i will look how it works and will set the
      time up as.
      15 * * * * sudo /bin/monitor_off.sh
      15 * * * * sudo /bin/monitor_on.sh
      @reboot sudo modprobe bcm2835-vl2
      • cowboysdudeC
        Well hey Thanks for making that easy… was JUST working on that LOL I’m putting it on github with instructions and the files…
        • cowboysdudeC
          https://github.com/cowboysdude/Pir-Sensor
          • cowboysdudeC
            Update:
            Monitor was only partially coming back on this should fix that.
              chengstark
              my monitor won’t turn back on
              when I run “npm start dev”, it shows “compare result=Infinity,Infinity;0,0” , seems like it can’t capture any movement
              the camera module works outside MagicMirror
              when I tried “sudo modprobe bcm2835-v4l2”, it says “modprobe: invalid option – ‘4’”
              how can I fix this
                cpramhofer
                Hi @cowboysdude
                thank you for your files and the explanation. what i don´t understand is how this all works together with the “Motion Detector” - i would prefere to use a camera instead of a PIR Sensor but as far as i see i have to install the pir.py file which is calling the on&off files and referring to the PIN with the connected PIR sensor.
                is there a way to use the on&off files with the “Motion Detector” Module?
                greets
                Christoph
                  cpramhofer
                  Hi guys
                  as it looks that it isn´t an MM problem but an Pi Problem…another try:
                  sudo nano /etc/kbd/config
                  change the values to zero
                  BLANK_TIME=0
                  POWERDOWN_TIME=0
                  good luck
                  D 1 Reply Last reply
                  • cowboysdudeC
                    cowboysdude Module Developer @cpramhofer
                    @cpramhofer There is a module for camera control… cannot remember the name of it but look around here I KNOW there’s one here.
                      cpramhofer
                      hi @cowboysdude,
                      i´m sorry - i thought we are all speaking about the camera based motion detection by @alexyak
                      https://github.com/alexyak/motiondetector
                      have a nice sunday!
                      • cowboysdudeC
                        @cpramhofer No that’s ok… I think this thread is getting mixed between PIR sensor and camera… opps
                        • bheplerB
                          bhepler Module Developer
                          Greetings! I’m slowly working my way through this thread and trying to figure out what’s going on here.
                          What works: configurable timeout for the motiondetector seems to work just fine. Turns the screen off. Interestingly, if I’m viewing the mirror via my desktop browser, refreshing the page will turn the monitor on.
                          What doesn’t work: turning the screen on. Even after entering sudo modprobe bcm2835-vl2
                          Additionally, I’m seeing this in the console with the developer tools enabled:
                          getUserMedia() no longer works on insecure origins. To use this feature, you should consider switching your application to a secure origin, such as HTTPS. See https://goo.gl/rStTGz for more details.
                          :8080/modules/motiondetector//webcamcapture.js:78 NavigatorUserMediaError
                          • paphkoP
                            paphko
                            I just tried this module but cpu load made me stop using it. Please tell me, how busy is your Raspberry with and without the motiondetector module? Mine is as follows on a Raspberry Pi 2:
                            • With motiondetector enabled, there is always an electron process with ~100% cpu
                            • With motiondetector disabled, I observed one or two electron processes with up to 15% cpu
                            I used a dedicated motion daemon on my old version of the mirror to switch on the screen on motion and I think I will set it up again. IIRC, it used ~40% cpu on a (single-core) Raspberry Pi 1 B+. What is your opinion?
                            bheplerB 1 Reply Last reply
                            • bheplerB
                              bhepler Module Developer @paphko
                              @paphko I just looked at my Pi 3 and I’m showing 40% usage with the motion detection module running (and failing). I suspect it’s the constant pic-compare-pic-compare loop that runs. It would be trivial to insert a wait in that loop to lower the CPU usage. Even a delay of 750 ms would probably help quite a bit.
                              • A
                                alexyak
                                @bhepler you’re right. putting a delay should help with the CPU usage.
                                • bheplerB
                                  bhepler Module Developer @alexyak
                                  Thanks, @alexyak. Any idea about how to get around the issue with the new security surrounding webcams?
                                    DirkS
                                    Hi, i had some issues with the PIR module where the screen doesn’t switch on anymore. Now with a original PI Camera i tried this module. Same issue, the screen doesn’t switch on but in this case no motion seems to be detected. (the PIR did detect)
                                    with /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7 i can switch on the screen manually.
                                    I followed every tip here in the thread. So i have no idea what is going on :(
                                    mm-0 (out): monitor has been deactivated
                                    mm-0 (out): monitor :state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
                                    mm-0 (out):
                                    That is the only thing i can see in the log.
                                    • bheplerB
                                      Check the console log. I suspect you’ll see a security error preventing the browser from accessing the monitor. Either launch your mirror in dev mode (modify your mm.sh script to read DISPLAY=:0 npm start dev and then restart via pm2 restart 0) or browse to your mirror’s address via a web browser and enter developere mode.
                                        DirkS
                                        i don’t have a mm.sh script. Where should it be located?
                                        • bheplerB
                                          bhepler Module Developer @DirkS
                                          @DirkS Aha. You probably haven’t set it up yet. No worries. You normally start your mirror by going into ~/MagicMirror and entering npm start, right? Just append the dev switch and you should see both the mirror UI and the browser console on your mirror: npm start dev
                                          If you’re starting your mirror via SSH, prepend the command to send the output to the mirror’s display: DISPLAY=:0 npm start dev
                                            DirkS
                                            The mirror is starting at reboot. So maybe there is a script, i installed it a few month ago, i don’t remember :D
                                            If i’m testing new settings i use pm2 restart mm for example. npm i’m just using to install new modules.
                                            • 10
                                            • 11
                                            • 4 / 11
