    MMM-MyScoreboard
    277 Posts 60 Posters 641.8k Views 63 Watching
    • T
      tony1550 @j.e.f.f
      Hi, looks like I am having the same problem about the scoreboard not loading or being stuck on loading…. I followed the instructions and experiencing the same issue. All I see is the header nothing else. Were you able to fix it? let me know I am curious because I have been looking for a module like this for a long time. I am running the latest version of MM and Raspian on a Pi3b+
      • justjim1220J
        justjim1220 Module Developer
        So, I know this result was an accident for @xclsior
        But I would like to do it on purpose so that I can scroll the scores across the screen…
        Any ideas how this can be done?
        Jim Hallock - 1995
        • N
          nhl
          Anyone having issues that the scores don’t display? The matches show up properly but during the games nothing is displayed.
          • justjim1220J
            justjim1220 Module Developer @nhl
            @nhl
            I had that problem last night, first time though.
            Jim Hallock - 1995
            • N
              nhl
              it looks like its just the nhl games having issues
              • justjim1220J
                @nhl
                The problem I had Thursday was with NFL
                Jim Hallock - 1995
                • H
                  hoveeman
                  One of the score providers must have changed their api? I believe it uses sportsnet.ca and espn for scores. NCAA Men’s basketball is working fine, but nfl and mls were not working yesterday.
                  • BKeyportB
                    BKeyport Module Developer
                    NHL was stuck for me.
                    • H
                      hoveeman @hoveeman
                      looks like an issue with sportsnet.ca. Looking at the json file, it was documented well that this provider is used for the majority of scores.
                      https://github.com/jclarke0000/MMM-MyScoreboard/blob/master/providers/SNET.js
                      It grabs the scores from this feed.
                      http://www.sportsnet.ca/wp-content/uploads/scoreboard.json
                      The feed is still active, so need to do some digging as to what broke it.
                      • V
                        vinp Module Developer
                        I’ve updated my fork to have the code use ESPN for those broken sports. Something is up with the sportsnet.ca json where it does not give the results for some of the sports. https://github.com/vincep5/MMM-MyScoreboard
                        N BKeyportB 2 Replies Last reply Reply Quote 1
                        • N
                          nhl @vinp
                          @vinp Awesome! Thanks!
                          • BKeyportB
                            BKeyport Module Developer @vinp
                            @vinp being a linux/magic mirror newbie - how would one switch to your fork?
                            V 1 Reply Last reply Reply Quote 1
                            • H
                              homerj99
                              Brilliant, replaced necessary files with your updates and it works like a charm. Thank you
                              • V
                                vinp Module Developer @BKeyport
                                @bkeyport ssh into your Pi and then “cd” into where you have MagicMirror/modules then run:
                                rmdir MMM-MyScoreboard
                                while you are still in the /modules folder, do a clone of my repository : git clone https://github.com/vincep5/MMM-MyScoreboard.git
                                Lastly run:
                                cd MMM-MyScoreboard
                                npm install
                                • W
                                  Wedee @vinp
                                  @vinp
                                  I had to use
                                  sudo rm -rf MMM-MyScoreboard
                                  as the directory was not empty.
                                  And had to also throw a
                                  npm cache clean
                                  prior to npm install
                                  to get rid of the install errors regarding “Failed to parse json”
                                  When my MagicMirror starts I see the header, then it disappears and it is not populating any of today’s NFL games. Configuration is the same as I was using before the issues started. Aside from the data sources nothing else changed in this fork right?
                                  J V 2 Replies Last reply Reply Quote 0
                                    j.e.f.f Project Sponsor Module Developer @Wedee
                                    @wedee Sportsnet changed their feed. Unfortunately the new one is quite different in format so it’s taking me a bit of time to write a fix. Hopefully I’ll have a release soon.
                                    W 1 Reply Last reply Reply Quote 1
                                    • W
                                      Wedee @j.e.f.f
                                      @j-e-f-f
                                      Thanks for the reply. Look forward to the update.
                                      • H
                                        homerj99
                                        Just noticed in NHL Scores that Vegas Knights Logo was not appearing, just the abbreviation of VGS appearing, I copied the logo and renamed it VGS, logo now appearing, perhaps due to ESPN labeling? Just thought I would share
                                        • V
                                          vinp Module Developer @Wedee
                                          @wedee thanks for the corrected steps. I will look on Thanksgiving if mine shows NFL. Nothing major should have changed. Rams were updated to to be LAR. Outside that my fork was primairly to add more soccer leagues. I do have NHL and NBA on my setup at home
                                          • V
                                            vinp Module Developer @homerj99
                                            @homerj99 I just realized that the logos for NHL can be taken right from the ESPN feed. I have updated my code to include that change (VGS should show up next time they play) To get latest: do a “git pull” after you CD into the MMM-MyScoreboard directory. thanks!
                                            • 10
                                            • 13
                                            • 14
                                            • 8 / 14
