    MMM-MyScoreboard
    277 Posts 60 Posters 623.2k Views 63 Watching
    • H Offline
      hoveeman
      One of the score providers must have changed their api? I believe it uses sportsnet.ca and espn for scores. NCAA Men’s basketball is working fine, but nfl and mls were not working yesterday.
      • BKeyportB Offline
        BKeyport Module Developer
        NHL was stuck for me.
        • H Offline
          hoveeman @hoveeman
          looks like an issue with sportsnet.ca. Looking at the json file, it was documented well that this provider is used for the majority of scores.
          https://github.com/jclarke0000/MMM-MyScoreboard/blob/master/providers/SNET.js
          It grabs the scores from this feed.
          http://www.sportsnet.ca/wp-content/uploads/scoreboard.json
          The feed is still active, so need to do some digging as to what broke it.
          • V Offline
            vinp Module Developer
            I’ve updated my fork to have the code use ESPN for those broken sports. Something is up with the sportsnet.ca json where it does not give the results for some of the sports. https://github.com/vincep5/MMM-MyScoreboard
            N BKeyportB 2 Replies Last reply Reply Quote 1
            • N Offline
              nhl @vinp
              @vinp Awesome! Thanks!
              • BKeyportB Offline
                BKeyport Module Developer @vinp
                @vinp being a linux/magic mirror newbie - how would one switch to your fork?
                V 1 Reply Last reply Reply Quote 1
                • H Offline
                  homerj99
                  Brilliant, replaced necessary files with your updates and it works like a charm. Thank you
                  • V Offline
                    vinp Module Developer @BKeyport
                    @bkeyport ssh into your Pi and then “cd” into where you have MagicMirror/modules then run:
                    rmdir MMM-MyScoreboard
                    while you are still in the /modules folder, do a clone of my repository : git clone https://github.com/vincep5/MMM-MyScoreboard.git
                    Lastly run:
                    cd MMM-MyScoreboard
                    npm install
                    • W Offline
                      Wedee @vinp
                      @vinp
                      I had to use
                      sudo rm -rf MMM-MyScoreboard
                      as the directory was not empty.
                      And had to also throw a
                      npm cache clean
                      prior to npm install
                      to get rid of the install errors regarding “Failed to parse json”
                      When my MagicMirror starts I see the header, then it disappears and it is not populating any of today’s NFL games. Configuration is the same as I was using before the issues started. Aside from the data sources nothing else changed in this fork right?
                      J V 2 Replies Last reply Reply Quote 0
                        j.e.f.f Project Sponsor Module Developer @Wedee
                        @wedee Sportsnet changed their feed. Unfortunately the new one is quite different in format so it’s taking me a bit of time to write a fix. Hopefully I’ll have a release soon.
                        W 1 Reply Last reply Reply Quote 1
                        • W Offline
                          Wedee @j.e.f.f
                          @j-e-f-f
                          Thanks for the reply. Look forward to the update.
                          • H Offline
                            homerj99
                            Just noticed in NHL Scores that Vegas Knights Logo was not appearing, just the abbreviation of VGS appearing, I copied the logo and renamed it VGS, logo now appearing, perhaps due to ESPN labeling? Just thought I would share
                            • V Offline
                              vinp Module Developer @Wedee
                              @wedee thanks for the corrected steps. I will look on Thanksgiving if mine shows NFL. Nothing major should have changed. Rams were updated to to be LAR. Outside that my fork was primairly to add more soccer leagues. I do have NHL and NBA on my setup at home
                              • V Offline
                                vinp Module Developer @homerj99
                                @homerj99 I just realized that the logos for NHL can be taken right from the ESPN feed. I have updated my code to include that change (VGS should show up next time they play) To get latest: do a “git pull” after you CD into the MMM-MyScoreboard directory. thanks!
                                • BKeyportB Offline
                                  hey, @vinp -
                                  I filed this as an issue on the main fork - was wondering if you’d be interested in adding this for me, as I’m just a beginner in javascript and don’t fully understand what’s going on here.
                                  For leagues that are currently “Out of Season” or off for the day, can we get output like “[league name] - No games scheduled” - This would prevent blank screens in my case, where I have MMM-Carousel running to page between sports.
                                  “MLB - No Games Scheduled”
                                  “NBA - No Games Scheduled”
                                  “NCAAF - No Games Scheduled”
                                  etc.
                                  J N 2 Replies Last reply Reply Quote 0
                                  • V Offline
                                    Yeah that’s a good one. I also use the carousel and see this happening. I can take a look maybe this weekend.
                                      Hey all.
                                      The Sportsnet feed has been fixed. This will fix issues with NHL, NFL, CFL, MLS and MLB.
                                      I’ve tested this with NHL and NFL and so far it looks good. Let me know if you run into issues with other sports.
                                      • Jeff
                                        j.e.f.f Project Sponsor Module Developer @BKeyport
                                        @bkeyport said in MMM-MyScoreboard:
                                        hey, @vinp -
                                        etc.
                                        My module is intended to use as little space as possible. When no games are scheduled for your current config, either because the sport is out of season or there are simply no games scheduled for that particular day, the sport is completely hidden to reclaim space.
                                        • BKeyportB Offline
                                          Right, and I’m suggesting an optional change to that, so that I can eliminate the blank screens… I’d love to see a simple one line “NCAAF - No games scheduled” item available if selected by the user.
                                          If I was any good at JS, I’d do it myself, but adulting has kept me away from hobby programming.
                                            cyberphox
                                            • 10
                                            • 13
                                            • 14
                                            • 8 / 14
