    Start or not...?
    44 Posts 4 Posters 36.9k Views 4 Watching
      A Former User @Egnos
      @egnos
      Most of your question could be found here;
      https://github.com/MichMich/MagicMirror/wiki/3rd-Party-Modules
      1- possible. What is the name of the module that manages this function?
      If you mean embeded Google Assistant, a few modules exist. Check above link. Not only GA, various kinds of voice commander there.
      2- obvious. What do you mean exactly? I would like to put cameras for video surveillance in the garden and see them in real time on the MM (to check the children…) .
      Check also link. I think MMM-RTSPStream would be one of them.
      3- Maybe or not. Only REAL Google Assistant(Google Home) has an unlimited accessibility for YouTube Music. Exists another way to listen the music?
      From your local SD card? there are also several local or internet music related modules.
      5- Why do you need Google Assistant to regulate your home temperature? Of course, RPI itself can do. Because it is more comfortable to set the thermostat by voice
      As I wrote above, Not only GA but several modules for voice command exist.
      But some module exists doesn’t mean that could be perfect to your purpose. You should read documents of each module carefully, and should confirm what could be able or not. Some task would be very easy, but some tasks wouldn’t be so easy to work nicely as your expectation. I wish you a good luck.
      • E Offline
        Egnos @Guest
        @sean said in Start or not...?:
        I would prefer on the internet
        Another question:
        is it possible to assign a specific action to a voice command ?.
        Have you watched the video I posted to you?
        Thank you for all the advice and if you can think of anything else do not hesitate to write …:winking_face:
          @egnos
          In video, he used GassistPi(https://github.com/shivasiddharth/GassistPi), not MM module. It is a separate program and runs out of MM environment independently. So it might not be combined chemically. (but physically, anyway its ok.)
          I think if you have a plan to use that program, ask your question and request related with GA to its developer.
          • E Offline
            Egnos @Guest
            What do you mean?
            This module work in the background without connecting to MM?
            Example: I ask something to GA that executes the command but I will not see the result on MM. Correct?
            Thanks.
              @egnos
              As I know, you’re right.
              Maybe there could be some bridge method, but gassistpi is standalone program by default. It is not made for MM.
                A Former User
                Anyway, there are many modules for google assistant or alexa or others including offline local detector beside GAssistPi in MM Scenes.
                Some might be a simple implementation of standalone, but some might be deeply combined with MM. see the list and find for your purpose.
                • E Offline
                  Egnos @Guest
                  @sean thank you for your help!
                  I’ll have to buy a new Raspberry (the first one is already busy …), plus the other components (usb microphone, HDMI/VGA adaptor, etc…).
                  Can you recommend a site at a good price where to buy all the components including Raspberry?
                    j.e.f.f Project Sponsor Module Developer @Egnos
                    @egnos having experimented with voice on my mirror in the past (I my case, Amazon Alexa) I can say with relative confidence that most, if not all, of what you want to do IS possible, but likely not out of the box. Most of the services you suggest would actually have nothing to do with MagicMirror, but can run along side on the same Pi. Be prepared to write some of your own integration to make things work in the way you want.
                    I would suggest though that you not use the pi for voice recognition and instead use a real Google Home device. Since it’s responding to voice it doesn’t need to be on the mirror… just in the same room. If budget is a concern, maybe start a project to build your own using a second Raspberry Pi, although once you add up the cost of all the parts you need it may add to about the same cost.
                    Take a look at some of the modules others have suggested above. For example, it’s possible to display a video stream on the mirror using the module suggested above. You would just need to figure out how to notify the MagicMirror to do so in response to your voice command.
                    Similarly, an integration using Google Home to control you lights likely already exists. So maybe all you need to do to extend this to the mirror is to write a module that monitors and displays the status of the lights. Take a look at my module MMM-MyWink which monitors a wink hub for the status of door locks. While it was possible to also have the mirror accept a command to lock or unlock the doors, using Siri on my phone already did this. There was no need to duplicate this effort on the Pi. And now having a few Echo Dots around the house I can say that the responsiveness to voice on my mirror was never as good as the real thing, especially when my wife or kids tried to use it… for some reason it had a hard time responding to higher pitches voices.
                    I have not used Google assistant so I don’t know what it’s programming API is like, but this was all possible using Amozon’s. I have to believe that Google’s API is equally as capable.
                    Try not to make your mirror a do-it-all device. The Pi is simply not up to that task. Also it’s a single point of failure when something goes wrong. Instead explore ways to make all of your single purpose devices work together through the various API’s that are freely available.
                    I hope this helps! Happy hacking
                    E 1 Reply Last reply Reply Quote 1
                      Peter
                      @Egnos: I think I made something like you want.
                      I started with the original Google AIY (https://aiyprojects.withgoogle.com/) and made it working (I have the V1 kit).
                      After that I installed MM on the same SD card.
                      GA and MM are working seperately.
                      So I cannot hide modules with GA, but I can ask a lot of questions and GA answers me in my own language.
                      I can set timers, ask for appointments in my agenda, turn on the gardenlights and the fountain in my garden pond.
                      I think it would be possible to set the temperature in the house if I had a smart thermostate (maybe next buy).
                      Playing songs on youtube or spotify: I did not get it working (I think you need the “real” Google home for that.
                      I am really fond of my Magic Mirror: it turns on and of by a Pir, shows me a lot of personal information and if I say: “Hey Google, goodmorning” it answers: Good morning, Peter, the time is …, the temperature is … it is going to be a cold day, it is not busy on the road to your work, it will take you … minutes, have a nice day … (all in Dutch = my own language).
                      Finally I build the RPI, AIY with the original speaker and microphone at the back of an old monitor.
                      I did not use a mirrorglass because my mirror shows thousands of holidaypictures and behind a mirrorglass they were to hard to see clearly in my vision.
                      So I mounted a plate of clear glass in front of the monitor.
                      If you need more information, you can mail me.
                      I hope this will help you with your project!
                      Peter
                      • E Offline
                        Egnos @j.e.f.f
                        @j-e-f-f Thank you so much for your advice.
                        I have seen several modules that integrate into MM and could be right for me, for example:
                        • Command the light in the house: mmm-openhabfloorplan.
                        • View the cameras positioned at home: MMM-RTSPStream
                        • Regulate the home temperature: MMM-Toon
                        I do not know how to connect Google Assistant to these modules.
                        Is it possible to set a sentence to execute a command?
                        For example: “Hey Google, set the temperature to 21 C °.” and the thermostat set the temperature at 21 C ° …
                        Excellent module!
                        What kind of sensors did you use to install on the doors? Wireless (WiFI, …) or wired?
                        How did you display the open / closed door information on the MM? Do you have an example image?
                        I’m looking for a device that does everything, an “all-in-one”.
                        In this way I would not have several devices scattered around the house…
                        Surely I will encounter difficulties, but I want to try … !!:winking_face:
                        @Peter Thanks also to you for your testimony!
                        To turn on the lights in the garden did you use a module for the MM?
                        If so, how did you manage to connect the GA commands with the module?
                        @peter said in Start or not...?:
                        Are you obliged to purchase the “Voice Kit (V1)” to use Google Assistant?
                        Thank you all!!!:winking_face:
                        • 1 / 5
