Clocks have two different times?
7 Posts 3 Posters 1.8k Views 3 Watching
  • T Offline
    tbs86
    When I first got my MagicMirror up and running I wanted to change the clock to 12 hour format
    I was able to get the top left clock to 12 hours and right clock with the weather as well. Unfortunately the clock with the weather is about 30 minutes different from each other. How do I go about fixing that? Also I changed the weather to fahrenheit but the up coming weather is still in celcius. How do I fix these?
    Thanks for the help
    • T Offline
      tbs86
      actually the clock above current weather is stuck on the same time and does not change.
      Y 1 Reply Last reply Nov 28, 2018, 8:48 AM Reply Quote 0
      • Y Offline
        yawns Moderator @tbs86
        @tbs86 said in Clocks have two different times?:
        Current weather shows sunrise / sunset time, not current time ;)
        T 1 Reply Last reply Nov 28, 2018, 4:07 PM Reply Quote 0
        • T Offline
          tbs86 @yawns
          @yawns haha wow i feel like a idiot. Is there a way to fix the weather forecast to fahrenheit?
          M 1 Reply Last reply Nov 29, 2018, 1:45 AM Reply Quote 0
            Mykle1 Project Sponsor Module Developer @tbs86
            in your config.js, near the top:
            units: "imperial", should do it.
            T 1 Reply Last reply Nov 29, 2018, 1:56 AM Reply Quote 1
            • T Offline
              tbs86 @Mykle1
              @mykle1 Thank you!
              M 1 Reply Last reply Nov 29, 2018, 1:57 AM Reply Quote 1
                @tbs86
                You’re welcome, mate. :-)
