    MMM-NOAA3
    25 Posts 9 Posters 15.4k Views 9 Watching
    • cowboysdudeC Offline
      • KimzerK Offline
        Kimzer
        Same thing unfortunately. :\
          cyberphox
          Funny I was playing around with one of my setups and wanted to see what it would look like and moved it to the middle region and couldn’t get it to center…opposite issues…LOL
            I would have no idea why it’s doing that… I’m not having the same issue but I can say I don’t use either of those modules… something is conflicting with it and pushing it right…
              cyberphox @cowboysdude
              @cowboysdude it’s all good…not something i’m gonna worry about for now anyways…just a test screen…
              Err…i mean fix it now! LOL
                Mykle1 Project Sponsor Module Developer @cyberphox
                @cyberphox
                Does it center correctly when it’s the only module in “top_center” position?
                  cyberphox @Mykle1
                  @mykle1 it appears to center ok once i disable the Clock module above it
                    Add this to the custom.css and it’ll fix it :) It does that when it has another module over top of it…not sure why as I am NO css guru by far…
                    .MMM-NOAA3 {
                    margin: 0 auto;
                    float: right; //for right side use left for left side
                    width: 195px;
                      cyberphox
                      @cowboysdude that totally fixed it by the way so big thanks AGAIN…i may just leave it at the top though since its so pretty…
                      Am I missing icons maybe - it does this sometimes…rarely i guess…
                        cowboysdude Module Developer @cyberphox
                        @cyberphox great!! Yes it would appear as though you are :) Which service provider are you using?
                          @cowboysdude it was OpenWeather…
                          it’s all good…I’ll tinker with things here…
                            Apathia
                            Can we make requests here?
                            If so, can you add the “feels like” temp?
                              cowboysdude Module Developer @Apathia
                              @apathia What weather provider are you using?
                                costascontis
                                AQI is not working for my area ,can i remove it ?
                                  cowboysdude Module Developer @costascontis
                                  @costascontis I sent you a PM
                                    Binog
                                    Hey,. a little to related to the topic…
                                    Is it possible to enlarge the font?
                                    Is there a way with the css?
                                    Thx
                                    Jimmy
                                      Mykle1 Project Sponsor Module Developer @Binog
                                      @Binog
                                      I pulled these from one of the css files that come with NOAA3. You can put them in your custom.css file and change the values. I’m not sure if this is all of them as I did not test.
                                       .MMM-NOAA3 .font {
                                           font-size: 23px;
                                      .MMM-NOAA3 .fontac {
                                           font-size: 23px;
                                           color:#e4ab5f;
                                      .MMM-NOAA3 .fontss {
                                           font-size: 23px;
                                           color: #e0e29a;
                                      .MMM-NOAA3 .fontauw {
                                           font-size: 23px;
                                           color:#51c7ca;
                                      .MMM-NOAA3 .fontfor {
                                           font-size: 23px;
                                           color: #000;
                                        Binog
                                        Thank You Mykle1
                                        changing these font sizes does not seem to change anything,… going to try more in a couple of days,…
                                          @Binog
                                          I know that module uses several choices of css files. Look inside the css file that you have chosen and identify the fonts being employed. Or, if you are familiar with using the dev console you can identify the fonts there. In either case, you can take that info into your custom.css file and modify the font sizes, etc
                                          EDIT
                                          I just thought of something
                                          I don’t know if the table will expand to accommodate larger fonts even if you manage to make them bigger. Perhaps someone else will chime in here that knows css better than I.
                                          • justjim1220J Offline
                                            justjim1220 Module Developer
                                            @cowboysdude
                                            This came up today:
                                            TypeError: Cannot read property 'pollution' of undefined
                                                at Object.parseAIR (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\providers\ds.js:179:35)
                                                at Request._callback (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\providers\ds.js:171:28)
                                                at Request.self.callback (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:185:22)
                                                at Request.emit (events.js:182:13)
                                                at Request.<anonymous> (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:1157:10)
                                                at IncomingMessage.<anonymous> (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:1079:12)
                                                at Object.onceWrapper (events.js:273:13)
                                                at IncomingMessage.emit (events.js:187:15)
                                                at endReadableNT (_stream_readable.js:1090:12)
                                                at process._tickCallback (internal/process/next_tick.js:63:19)
                                            Any idea what it means?
                                            Any idea how to fix it?
                                            Thanks in advance! ;)
                                            "Life's Too Short To Dance With Ugly People"
                                            Jim Hallock - 1995
