    MMM-NOAA3
    25 Posts 9 Posters 16.4k Views 9 Watching
      cyberphox
      Funny I was playing around with one of my setups and wanted to see what it would look like and moved it to the middle region and couldn’t get it to center…opposite issues…LOL
      • cowboysdudeC Offline
        I would have no idea why it’s doing that… I’m not having the same issue but I can say I don’t use either of those modules… something is conflicting with it and pushing it right…
          cyberphox @cowboysdude
          @cowboysdude it’s all good…not something i’m gonna worry about for now anyways…just a test screen…
          Err…i mean fix it now! LOL
            Mykle1 Project Sponsor Module Developer @cyberphox
            @cyberphox
            Does it center correctly when it’s the only module in “top_center” position?
              cyberphox @Mykle1
              @mykle1 it appears to center ok once i disable the Clock module above it
                Add this to the custom.css and it’ll fix it :) It does that when it has another module over top of it…not sure why as I am NO css guru by far…
                .MMM-NOAA3 {
                margin: 0 auto;
                float: right; //for right side use left for left side
                width: 195px;
                  cyberphox
                  @cowboysdude that totally fixed it by the way so big thanks AGAIN…i may just leave it at the top though since its so pretty…
                  Am I missing icons maybe - it does this sometimes…rarely i guess…
                    cowboysdude Module Developer @cyberphox
                    @cyberphox great!! Yes it would appear as though you are :) Which service provider are you using?
                      @cowboysdude it was OpenWeather…
                      it’s all good…I’ll tinker with things here…
                        Apathia
                        Can we make requests here?
                        If so, can you add the “feels like” temp?
                          cowboysdude Module Developer @Apathia
                          @apathia What weather provider are you using?
                            costascontis
                            AQI is not working for my area ,can i remove it ?
                              cowboysdude Module Developer @costascontis
                              @costascontis I sent you a PM
                                Binog
                                Hey,. a little to related to the topic…
                                Is it possible to enlarge the font?
                                Is there a way with the css?
                                Thx
                                Jimmy
                                  Mykle1 Project Sponsor Module Developer @Binog
                                  @Binog
                                  I pulled these from one of the css files that come with NOAA3. You can put them in your custom.css file and change the values. I’m not sure if this is all of them as I did not test.
                                   .MMM-NOAA3 .font {
                                       font-size: 23px;
                                  .MMM-NOAA3 .fontac {
                                       font-size: 23px;
                                       color:#e4ab5f;
                                  .MMM-NOAA3 .fontss {
                                       font-size: 23px;
                                       color: #e0e29a;
                                  .MMM-NOAA3 .fontauw {
                                       font-size: 23px;
                                       color:#51c7ca;
                                  .MMM-NOAA3 .fontfor {
                                       font-size: 23px;
                                       color: #000;
                                    Binog
                                    Thank You Mykle1
                                    changing these font sizes does not seem to change anything,… going to try more in a couple of days,…
                                      @Binog
                                      I know that module uses several choices of css files. Look inside the css file that you have chosen and identify the fonts being employed. Or, if you are familiar with using the dev console you can identify the fonts there. In either case, you can take that info into your custom.css file and modify the font sizes, etc
                                      EDIT
                                      I just thought of something
                                      I don’t know if the table will expand to accommodate larger fonts even if you manage to make them bigger. Perhaps someone else will chime in here that knows css better than I.
                                      • justjim1220J Offline
                                        justjim1220 Module Developer
                                        @cowboysdude
                                        This came up today:
                                        TypeError: Cannot read property 'pollution' of undefined
                                            at Object.parseAIR (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\providers\ds.js:179:35)
                                            at Request._callback (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\providers\ds.js:171:28)
                                            at Request.self.callback (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:185:22)
                                            at Request.emit (events.js:182:13)
                                            at Request.<anonymous> (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:1157:10)
                                            at IncomingMessage.<anonymous> (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:1079:12)
                                            at Object.onceWrapper (events.js:273:13)
                                            at IncomingMessage.emit (events.js:187:15)
                                            at endReadableNT (_stream_readable.js:1090:12)
                                            at process._tickCallback (internal/process/next_tick.js:63:19)
                                        Any idea what it means?
                                        Any idea how to fix it?
                                        Thanks in advance! ;)
                                        Jim Hallock - 1995
                                          sdetweil @justjim1220
                                          @justjim1220 said in MMM-NOAA3:
                                          appears the api did not return the expected data
                                          data.pollution failed as data does not have a value
