    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 151.3k Views 25 Watching
      paviro @James
      @James please dont be that demanding! You can always fix it yourself if you need it now. I don’t currently have a mirror so I can’t run it on a real Pi and therefore test it but I will see what I can do on the weekend.
      – The Doctor
      • K Offline
        KirAsh4 Moderator
        Folks, please keep in mind that all of us have jobs, some of us are still in school, all of us have a life, all of us have other things to do that is not MagicMirror. I know that @paviro has moved recently and is still settling down into a new place. MagicMirror is probably far lower on the list of things to do at the moment for him. I’ve had a bad life event happen recently and have been absent from everything this past month or so and am just now starting to catch up on things. I’m not ready to jump into anything right away. Some days I’m perfectly fine, other days I’m doubled over crying somewhere, unable to do anything, and this is no joke. And @MichMich, I can’t even imagine all the things he does that we don’t know (and I’m not even talking about his harem.)
        Point is, there are several aspects of the code that we are aware of that will need some debugging, fixing, or perhaps simply light on fire and start over. I know that, and I’m sure the other guys know that too. Free time isn’t something that we have in abundance. It comes when it comes, and I try to make use of it when I have it. I can’t speak for the others.
        A little patience will go along way. I am certain @paviro will get to coding again when he’s available to do that. And eventually, I too will do the same. For now though, just try to keep the boat floating and stick your fingers into any leak you see springing up …
        1 Reply Last reply Reply Quote 5
          McSorley
          I made an attempt at fixing it but I struggled to find many JavaScript/Node.js tutorials out there. I have however managed to compile a straight forward script in Python that I have set up to run with pm2. A workaround for those who are in high demand for the motion sensor to work and to give paviro some breathing space.
          Sorry but I don’t know how to add this as code snippets. If a mod could help me out that that would be great.
          Open Python 3. File > New. Paste this code in.
          from gpiozero import MotionSensor
          import os
          pir = MotionSensor(4) #4 is the Pin?
          while True:
              if pir.wait_for_motion(timeout=10*60): #10 * 60 Seconds
                  os.system("/opt/vc/bin/tvservice -p")
              else:
                  os.system("/opt/vc/bin/tvservice -o")
          You can if you want edit
          to
          print("Motion Detected")
          to test if your PIR Sensor is working ok. After changing it, save it and press Ctrl + F5 to run the code. It will then spam up with motion detect or undetected depending on what you’ve changed.
          Moderator’s note: You can use backticks (`) to highlight code. Check out the help at http://commonmark.org/help/ - scroll down to see the various options for using backticks.
            paviro
            Hi there,
            I think I fixed the problems now, feel free to give it a try :)
            Cheers,
            Paul
            – The Doctor
              James @paviro
              @paviro Solved with run npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49 in the MMM-PIR-Sensor folder with the latest release or it still shows “White Screen”.
                paviro @James
                @James sure this is because of my plugin? I used the latest and it worked :/
                – The Doctor
                  James
                  @paviro maybe 99% sure. FYI what I did yesterday as follows:
                  1. Format & rewrite the sd card,
                  2. Boot and run sudo apt-get update & upgrade & reboot,
                  3. Install MagicMirror2 with the bash command,
                  4. git MMM-PIR-Sensor in modules folder and run npm install in MMM-PIR-Sensor folder as well as useradd command,
                  5. Add code in config.js with
                                          module: 'MMM-PIR-Sensor',
                                                 sensorPIN: 4
                  1. After rebooting, run MM with pm2 and shows “White Screen”, I checked the pm2 error log shows something like “Expected 49, got 48” as before,
                  2. Run npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49 in the MMM-PIR-Sensor folder,
                  3. Run pm2 restart mm and it works.
                  I found there is another issue when a rebooting finished and MM runs automaticly with pm2, MMM-PIR-Sensor will not work(screen always on) until the sensor captured a motion.
                    Bangee Module Developer
                    this works for me too. without formatting and reinstallation.
                    I’ve remove the folder node_modules and startet from 4.
                    Thanks a lot.
                    • Z Offline
                      zam
                      Yes itś working …:)
                      “After rebooting, run MM with pm2 and shows “White Screen”, I checked the pm2 error log shows something like “Expected 49, got 48” as before,
                      Run pm2 restart mm and it works.”
                      • Y Offline
                        yawns Moderator
                        very interesting, I will try it this weekend. I’m just wondering why this is not documented on any forum or website, even though you can find several users with version mismatch issues.
                        Great finding, @James
                          samydp
                          hello is not working!
                          i have downgrade the node.js version from v6 to 5v and i dont now why i become a white screen.
                          my pm2 logs
                          [TAILING] Tailing last 10 lines for [all] processes (change the value with --lin        es option)
                          /home/pi/.pm2/pm2.log last 10 lines:
                          PM2        | 2016-09-21 20:18:32: Starting execution sequence in -fork mode- for        app name:mm id:0
                          PM2        | 2016-09-21 20:18:32: App name:mm id:0 online
                          PM2        | 2016-09-21 20:21:28: Stopping app:mm id:0
                          PM2        | 2016-09-21 20:21:28: App [mm] with id [0] and pid [1071], exited wi        th code [0] via signal [SIGINT]
                          PM2        | 2016-09-21 20:21:28: Starting execution sequence in -fork mode- for        app name:mm id:0
                          PM2        | 2016-09-21 20:21:28: App name:mm id:0 online
                          PM2        | 2016-09-21 20:24:05: Stopping app:mm id:0
                          PM2        | 2016-09-21 20:24:06: App [mm] with id [0] and pid [1250], exited wi        th code [0] via signal [SIGINT]
                          PM2        | 2016-09-21 20:24:06: Starting execution sequence in -fork mode- for        app name:mm id:0
                          PM2        | 2016-09-21 20:24:06: App name:mm id:0 online
                          /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
                          0|mm       | No helper found for module: alert.
                          0|mm       | No helper found for module: clock.
                          0|mm       | Initializing new module helper ...
                          0|mm       | No helper found for module: compliments.
                          0|mm       | No helper found for module: currentweather.
                          0|mm       | No helper found for module: weatherforecast.
                          0|mm       | Whoops! There was an uncaught exception...
                          0|mm       | MagicMirror will not quit, but it might be a good idea to check why        this happened. Maybe no internet connection?
                          0|mm       | If you think this really is an issue, please open an issue on GitHu        b: https://github.com/MichMich/MagicMirror/issues
                          0|mm       | Launching application.
                          /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
                          0|mm       |     at Error (native)
                          0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_AS        AR.js:168:20)
                          0|mm       |     at Object.Module._extensions..node (module.js:583:18)
                          0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR        .js:168:20)
                          0|mm       |     at Module.load (module.js:473:32)
                          0|mm       |     at tryModuleLoad (module.js:432:12)
                          0|mm       |     at Function.Module._load (module.js:424:3)
                          0|mm       |     at Module.require (module.js:483:17)
                          0|mm       |     at require (internal/module.js:20:19)
                          0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_m        odules/bindings/bindings.js:76:44)
                            @samydp did you maybe reneamed this folder:
                            modules/MMM-PIR-Sensor/node_m odules <- is there a space in this name??
                            you’ll have to remove this
                              samydp
                              I have the folder node_modules in MMM-Pir folder .
                              should I delete the folder?
                                Can you post a printscrenn from this folder?
                                you can also try to go use these commands:
                                cd ~/MagicMirror/modules/MMM-PIR-Sensor/
                                git pull
                                npm rebuild
                                  samydp
                                    That looks fine.
                                    Did you try to remove your folder MMM-PIR-Sensor an reinstall the modul?
                                      samydp
                                      yes but i dont have the folder node_modules in the PIR Folder :/ i have install WrinPi but nothing works :/
                                        ok so lets go step by step:
                                        now we will remove the PIR folder:
                                        rm -rf MMM-PIR-Sensor
                                        and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
                                        git clone https://github.com/paviro/MMM-PIR-Sensor.git
                                        cd MMM-PIR-Sensor
                                        run the following cmd here:
                                        npm install and wait, this can take a few minutes.
                                        Now you’ll have to add pi to gpio
                                        sudo useradd -g pi gpio
                                        and reboot your Raspi:
                                        sudo reboot
                                        You’ll have to connect your PIR Sensor the right way with your Raspi.
                                        I’ve connected my PIR Sensor on the following Pins:
                                        GPIO
                                        I’ve got a Pi2 and use Pin 2 for power, Pin 6 for Ground and Pin 15 for Data.
                                        – correctin grn pin
                                        PIR Sensor
                                        and dont forget to add the config :-)
                                        D 1 Reply Last reply Reply Quote 3
                                          samydp
                                          you are the best !! i dont become no a with screen !
                                          but the sensor dont work
                                          i have
                                          vcc: Pin 2
                                          Data: Pin 7
                                          Ground: Pin 6
                                          and my config in the config and MMM-PIR-Sensor data is:
                                          			sensorPIN: 7,
                                          			relayPIN: false,
                                          			powerSaving: true,
                                          			relayOnState: 1,
                                          the sensetiv is max and the time is min
                                            If you use pin 7 in your config its nr 4
                                            You have to use the gpio nr.
                                            • 2 / 5
