    24 Hour clock problem
    25 Posts 5 Posters 13.3k Views 4 Watching
      Rasmus rytter @Nilnik
      Thanks so much @nilnik
      but the calendar dos not show up?
      • N Offline
        Nilnik Project Sponsor
        Here is an example for Swedish namedays:
        • N Offline
          I missed the last curled bracket, sorry.
            thanks @nilnik
            Can u send it as a Text so i can copy it in mine?
            • N Offline
              I don’t know how to,when I paste in the textfile I lose all tabs so you have to put in them
              disabled: false,
              module: ‘calendar’,
              header: ‘Namnsdagar’,
              position: ‘bottom_left’,
              colored: ‘true’,
              timeFormat: ‘absolute’,
              maximumEntries: 5,
              fullDayEventDateFormat: ‘Do MMM’,
              showEnd: false,
              urgency: 1,
              color: ‘#00ff00’,
              symbol:'calendar-check-o ',
              url: ‘http://www.webcal.fi/cal.php?id=99’
              R Mykle1M 3 Replies Last reply Reply Quote 0
                i can try do i have to paste my own google link in insted of urs?
                  Mykle1 Project Sponsor Module Developer @Nilnik
                  @nilnik said in 24 Hour clock problem:
                  https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                  • N Offline
                    Thanks, we learn all the time . Happy New year
                      I think i have done some wrong but cant find it, there is just the clock in the MM now, no calendar.
                        Rasmus rytter
                        Everything has gone except of the clock?
                        • N Offline
                          Try this link: https://github.com/MichMich/MagicMirror/wiki/faq#q-im-having-problems-with-my-configjs-but-cant-find-the-issue-
                            Rasmus rytter
                            I try to do it all over do anyone have a clear starting config i can copy?
                              Mykle1 Project Sponsor Module Developer @Rasmus rytter
                              @rasmus-rytter
                              You don’t have your config.js.sample file?
                              var config = {
                              	port: 8080,
                              	language: "en",
                              	timeFormat: 24,
                              	units: "metric",
                              			module: "alert",
                              			module: "updatenotification",
                              			position: "top_bar"
                              			module: "clock",
                              			position: "top_left"
                              			header: "US Holidays",
                              						symbol: "calendar-check-o ",
                              			module: "compliments",
                              			position: "lower_third"
                              			module: "currentweather",
                              				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                              			module: "weatherforecast",
                              			header: "Weather Forecast",
                              				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                              			module: "newsfeed",
                              			position: "bottom_bar",
                              				feeds: [
                              						title: "New York Times",
                              				showSourceTitle: true,
                              				showPublishDate: true
                                bhepler Module Developer
                                Everyone! Please, use the Markdown features of the forum when posting code.
                                @rasmus-rytter said in 24 Hour clock problem:
                                Looking at your config.js file, you are missing the code to include the clock module entirely. @Mykle1 has it correct: It’s best at this point to copy the config.js.sample file to config.js and just start from a known working baseline.
                                  @rasmus-rytter
                                  Also, for future reference, a value of true should not be in quotes as you have in colored: "true", above.
                                    Rasmus rytter
                                    Thanks, i learn some new everyday :)
                                      As do I, my friend. As do I. :thumbsup:
