    24 Hour clock problem
    25 Posts 5 Posters 13.1k Views 4 Watching
    • N Offline
      Nilnik Project Sponsor
      I missed the last curled bracket, sorry.
        Rasmus rytter @Nilnik
        thanks @nilnik
        Can u send it as a Text so i can copy it in mine?
        • N Offline
          I don’t know how to,when I paste in the textfile I lose all tabs so you have to put in them
          disabled: false,
          module: ‘calendar’,
          header: ‘Namnsdagar’,
          position: ‘bottom_left’,
          colored: ‘true’,
          timeFormat: ‘absolute’,
          maximumEntries: 5,
          fullDayEventDateFormat: ‘Do MMM’,
          showEnd: false,
          urgency: 1,
          color: ‘#00ff00’,
          symbol:'calendar-check-o ',
          url: ‘http://www.webcal.fi/cal.php?id=99’
          R Mykle1M 3 Replies Last reply Reply Quote 0
            i can try do i have to paste my own google link in insted of urs?
              Mykle1 Project Sponsor Module Developer @Nilnik
              @nilnik said in 24 Hour clock problem:
              https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
              • N Offline
                Thanks, we learn all the time . Happy New year
                  I think i have done some wrong but cant find it, there is just the clock in the MM now, no calendar.
                    Rasmus rytter
                    Everything has gone except of the clock?
                    • N Offline
                      Try this link: https://github.com/MichMich/MagicMirror/wiki/faq#q-im-having-problems-with-my-configjs-but-cant-find-the-issue-
                        Rasmus rytter
                        I try to do it all over do anyone have a clear starting config i can copy?
                          Mykle1 Project Sponsor Module Developer @Rasmus rytter
                          @rasmus-rytter
                          You don’t have your config.js.sample file?
                          var config = {
                          	port: 8080,
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                          			header: "US Holidays",
                          						symbol: "calendar-check-o ",
                          			module: "compliments",
                          			position: "lower_third"
                          			module: "currentweather",
                          				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                          			module: "weatherforecast",
                          			header: "Weather Forecast",
                          				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          				feeds: [
                          						title: "New York Times",
                          				showSourceTitle: true,
                          				showPublishDate: true
                            bhepler Module Developer
                            Everyone! Please, use the Markdown features of the forum when posting code.
                            @rasmus-rytter said in 24 Hour clock problem:
                            Looking at your config.js file, you are missing the code to include the clock module entirely. @Mykle1 has it correct: It’s best at this point to copy the config.js.sample file to config.js and just start from a known working baseline.
                              @rasmus-rytter
                              Also, for future reference, a value of true should not be in quotes as you have in colored: "true", above.
                                Rasmus rytter
                                Thanks, i learn some new everyday :)
                                  As do I, my friend. As do I. :thumbsup:
