    24 Hour clock problem
    25 Posts 5 Posters 13.0k Views 4 Watching
    • N Offline
      Nilnik Project Sponsor
      Here is an example for Swedish namedays:
      • N Offline
        I missed the last curled bracket, sorry.
          Rasmus rytter @Nilnik
          thanks @nilnik
          Can u send it as a Text so i can copy it in mine?
          • N Offline
            I don’t know how to,when I paste in the textfile I lose all tabs so you have to put in them
            disabled: false,
            module: ‘calendar’,
            header: ‘Namnsdagar’,
            position: ‘bottom_left’,
            colored: ‘true’,
            timeFormat: ‘absolute’,
            maximumEntries: 5,
            fullDayEventDateFormat: ‘Do MMM’,
            showEnd: false,
            urgency: 1,
            color: ‘#00ff00’,
            symbol:'calendar-check-o ',
            url: ‘http://www.webcal.fi/cal.php?id=99’
            R Mykle1M 3 Replies Last reply Reply Quote 0
              i can try do i have to paste my own google link in insted of urs?
                Mykle1 Project Sponsor Module Developer @Nilnik
                @nilnik said in 24 Hour clock problem:
                https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                • N Offline
                  Thanks, we learn all the time . Happy New year
                    I think i have done some wrong but cant find it, there is just the clock in the MM now, no calendar.
                      Rasmus rytter
                      Everything has gone except of the clock?
                      • N Offline
                        Try this link: https://github.com/MichMich/MagicMirror/wiki/faq#q-im-having-problems-with-my-configjs-but-cant-find-the-issue-
                          Rasmus rytter
                          I try to do it all over do anyone have a clear starting config i can copy?
                            Mykle1 Project Sponsor Module Developer @Rasmus rytter
                            @rasmus-rytter
                            You don’t have your config.js.sample file?
                            var config = {
                            	port: 8080,
                            	language: "en",
                            	timeFormat: 24,
                            	units: "metric",
                            			module: "alert",
                            			module: "updatenotification",
                            			position: "top_bar"
                            			module: "clock",
                            			position: "top_left"
                            			header: "US Holidays",
                            						symbol: "calendar-check-o ",
                            			module: "compliments",
                            			position: "lower_third"
                            			module: "currentweather",
                            				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                            			module: "weatherforecast",
                            			header: "Weather Forecast",
                            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                            			module: "newsfeed",
                            			position: "bottom_bar",
                            				feeds: [
                            						title: "New York Times",
                            				showSourceTitle: true,
                            				showPublishDate: true
                              bhepler Module Developer
                              Everyone! Please, use the Markdown features of the forum when posting code.
                              @rasmus-rytter said in 24 Hour clock problem:
                              Looking at your config.js file, you are missing the code to include the clock module entirely. @Mykle1 has it correct: It’s best at this point to copy the config.js.sample file to config.js and just start from a known working baseline.
                                @rasmus-rytter
                                Also, for future reference, a value of true should not be in quotes as you have in colored: "true", above.
                                  Rasmus rytter
                                  Thanks, i learn some new everyday :)
                                    As do I, my friend. As do I. :thumbsup:
