    602 Posts 67 Posters 2.3m Views 68 Watching
    • Cr4z33C Offline
      Cr4z33
      @shbatm I am trying to get this module working with MMM-AssistantMk2 from @Sean so that I can switch TV channel streams (Dreambox) by voice command.
      The issue is that instead of switching from a stream to another ALL of them start playing at the same time! :man_facepalming_medium_skin_tone: :rolling_on_the_floor_laughing:
      So far I’ve tried setting in the MMM-RTSPStream module both rotateStreams: false and rotateStreams: true, but it still happens.
      I’ve also tried setting autoStart: false, but as soon as I give the voice command the nightmare starts on! :face_with_tears_of_joy:
      This is my MMM-RTSPStream config:
      			module: "MMM-RTSPStream",
      			position: "bottom_right",
      			disabled: false,
      				autoStart: false,
      				rotateStreams: false,
      				rotateStreamTimeout: 10,
      				moduleWidth: 440,
      				moduleHeight: 247,
      				moduleOffset: {
      						left: -330,
      						top: -180
      				localPlayer: 'omxplayer',
      				remotePlayer: 'none',
      				showSnapWhenPaused: false,
      				remoteSnaps: false,
      				stream1: {
      						url: 'http://***/1:0:1:5:7918:217C:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						frameRate: 'undefined',
      						width: 440,
      						height: 247
      				stream2: {
      						name: 'RAI 3 TGR Puglia',
      						url: 'http://***/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream3: {
      						name: 'RAI 3 HD',
      						url: 'http://***/1:0:1:2191:5:13E:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream4: {
      						name: 'Deejay TV HD',
      						url: 'http://***/1:0:1:29:7918:217C:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream5: {
      						url: 'http://***/1:0:2:9:204:1D:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream6: {
      						name: 'Radio Capital',
      						url: 'http://***/1:0:2:A:204:1D:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream7: {
      						url: 'http://***/1:0:2:1FA7:32A:110:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      And this is the section of MMM-AssistantMk2 where I set the voice commands.
      They match both your instructions and @Sean 's ones:
      					transcriptionHook: {
      								"CHANNEL_1": {
      										pattern: "Sky TG24",
      										command: "CHANGE_CHANNEL_1"
      								"CHANNEL_2": {
      										pattern: "Puglia",
      										command: "CHANGE_CHANNEL_2"
      								"CHANNEL_3": {
      										pattern: "Rai3",
      										command: "CHANGE_CHANNEL_3"
      								"CHANNEL_4": {
      										pattern: "Deejay TV",
      										command: "CHANGE_CHANNEL_4"
      								"CHANNEL_5": {
      										pattern: "Radio Deejay",
      										command: "CHANGE_CHANNEL_5"
      								"CHANNEL_6": {
      										pattern: "Radio Capital",
      										command: "CHANGE_CHANNEL_6"
      								"CHANNEL_7": {
      										pattern: "Radio cento cinque",
      										command: "CHANGE_CHANNEL_7"
      								"PROFILE1": {
      										pattern: "Famiglia",
      										command: "CHANGE_PROFILE_1"
      								"PROFILE2": {
      										pattern: "Mio",
      										command: "CHANGE_PROFILE_2"
      					command: {
      							"CHANGE_CHANNEL_1": {
      										notificationExec: {
      													notification: "RTSP-PLAY",
      													payload: "stream1"
      							"CHANGE_CHANNEL_2": {
      										notificationExec: {
      													payload: "stream2"
      							"CHANGE_CHANNEL_3": {
      										notificationExec: {
      													payload: "stream3"
      							"CHANGE_CHANNEL_4": {
      										notificationExec: {
      													payload: "stream4"
      							"CHANGE_CHANNEL_5": {
      										notificationExec: {
      													payload: "stream5"
      							"CHANGE_CHANNEL_6": {
      										notificationExec: {
      													payload: "stream6"
      							"CHANGE_CHANNEL_7": {
      										notificationExec: {
      													payload: "stream7"
        barnosch
        the two streams work great again now, after pulling the older version.
        Great. Thank you very much.
        Also your new VLC based module sounds great.
        But i guess, you maybe should create a whole new module for it?
          shbatm Module Developer @barnosch
          @barnosch said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          The plan right now was to just leave it as another option for the localPlayer. OMXPlayer will still be an option for now as well. I don’t know if I’ll have time to split it out completely, but that would be much cleaner.
            shbatm Module Developer @Cr4z33
            @cr4z33
            You’ll want the following settings which should give you 1 blank video box that does not show anything until you press play.
            autoStart: false,
            rotateStreamTimeout: 0,
            remoteSnaps: false,
            I’m assuming you’re seeing the same glitch that is plaguing the last OMXPlayer version of this module. I’m working on it today to try and find what I broke. In the meantime, try reverting back and seeing if that fixes the issue. I just tested the following notification on the VLC version and it worked as expected, so it’s got to be something with omxplayer.
            payload: "stream3"
            Cr4z33C 3 Replies Last reply Reply Quote 0
            • Cr4z33C Offline
              Cr4z33 @shbatm
              @shbatm although I am not a developer I agree with you.
              Whenever I tried something different from normal module usage involving omxplayer it always ended up with a mess lol! :grinning_face_with_smiling_eyes:
              Going to try what you are suggesting here.
              Can’t wait to see the VLC implementation (it just works as intended). :smiling_face_with_heart-eyes:
              • Cr4z33C Offline
                Cr4z33 @shbatm
                @shbatm nope the simultaneous streams have now dropped from 7 to 2, but still not what I want (aka a single stream). :smiling_face_with_open_mouth_cold_sweat:
                Gonna try the develop branch and see how it is doing right now.
                  @cr4z33 Still looking into it, but I just thought of something… it doesn’t look like you’re calling RTSP-STOP on the old stream anywhere when changing channels so right now it’s going to keep starting streams every time–there’s no “1 at a time” method when controlling it from notifications… yet.
                  • Cr4z33C Offline
                    Cr4z33 @shbatm
                      shbatm Module Developer @shbatm
                      @djuscha I’ve reverted the changes that I think broke the master channel. Please try updating your module to the current master branch and test.
                        @cr4z33 Added something that might help. Please use the develop branch and update your change channel commands to :
                        notification: “RTSP-PLAY”,
                        payload: { stream:“stream1”, stopOthers: true }
                        EDIT: Nevermind, don’t do that. I fixed the glitch on the develop channel that was starting more than one stream when rotateStreams: true was set. Please try that and see if it works now.
                          anthony6608 @shbatm
                          @shbatm Hey, I updated issue #33 with the errors I am seeing when you have a chance. Also, should I run this update although I am using the VLCplayer method? Let me know what you think. Thanks again for all your help!
                          • BKeyportB Offline
                            BKeyport Module Developer
                            I’m unable to get this module to load and run with FFMPeg anymore - as of 3PM 1/4/19 (Pacific Time (Seattle))
                            Update was applied as of that time.
                            I don’t know how to retrieve logs.
                            – Bug filed on github - https://github.com/shbatm/MMM-RTSPStream/issues/34
                              @djuscha, @Cr4z33 @barnosch @anthony6608 @bhepler @evroom, and anyone else using this module:
                              I just pushed a bunch of bug fixes for OMX Player to the develop branch. Please test and let me know if you are still seeing the same issues.
                              Fixes include:
                              • App closing now spawns a new process to actually kill the OMX streams, it was getting cut off in the middle of closing everything due to it being an async process and leaving streams open.
                              • Wait for DOM to be shown before calling to start the streams–this was causing the Fullscreen on Resume problems.
                              • Only start one stream at a time if we’re in RotateStreams mode
                              • Can jump to a specific stream in RotateStreams mode using notifications
                              • Fixed and cleaned up all notifications and control from other modules
                              • Fixed broken key bindings after MMM-KeyBindings upgrade
                              • Fixed issue where module was trying to connect to PM2 while it was already connected (e.g. stop stream 1 and start stream 2 back to back).
                              To switch branches:
                              cd ~/MagicMirror/modules/MMM-RTSPStream
                              sudo rm -R node_modules/
                              git fetch --al
                              git checkout develop
                              git pull
                              npm install
                              Cr4z33C D 2 Replies Last reply Reply Quote 0
                              • evroomE Offline
                                evroom
                                @shbatm
                                I installed the new changes according your procedure.
                                I am using omxplayer for a RTSP stream of a IP cam.
                                I do not use rotation or any other fancy stuff.
                                I see the same issue as before: omx_stream1 has status stopped and when I click on the play button it also will not start.
                                I stopped and started mm 2 times and even did a complete reboot
                                It only can be started using
                                $ pm2 start omx_stream1
                                Another restart of mm shows that the omx_stream1 is being stopped, but never restarted.
                                After ever mm restart I will need to perform:
                                MagicMirror version: 2.37.0
                                • evroomE Offline
                                  evroom
                                  I noticed this in pm2 logs (do not see this after every mm restart):
                                  0|mm  | Connecting socket for: MMM-RTSPStream
                                  0|mm  | PM2: Stopping all OMXPlayer Streams...
                                  0|mm  | Sockets connected & modules started ...
                                  0|mm  | Launching application.
                                  0|mm  | PM2: Checking if omx_stream1 is running...
                                  0|mm  | PM2: Stopping omx_stream1...
                                  PM2      | Stopping app:omx_stream1 id:1
                                  1|omx_stream1  | Video codec omx-h264 width 640 height 360 profile 77 fps 30.000000
                                  1|omx_stream1  | Subtitle count: 0, state: off, index: 1, delay: 0
                                  1|omx_stream1  | V:PortSettingsChanged: 640x360@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                  1|omx_stream1  | have a nice day ;)
                                  PM2            | App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                  PM2            | pid=2104 msg=process killed
                                  In this case it was tried to start the stream, but it exited.
                                  Starting it by hand makes it work again.
                                  • Cr4z33C Offline
                                    Cr4z33 @shbatm
                                    @shbatm I ran the develop update.
                                    With omxplayer (and autoStart: false) I see stream labels changing when giving a voice command, but then no stream is starting.
                                    With vlc nothing happens, not a single stream starting by voice command.
                                      djuscha @shbatm
                                      @shbatm
                                      have made yesterday update without develoop only
                                      git pull
                                      npm install
                                      everything runs :)
                                       Name        │ id │ mode │ status │ ↺      │ cpu │ memory │
                                      │ mm          │ 0  │ N/A  │ fork   │ online │ 0   │ 0%     │ 2.5 MB   │
                                      │ omx_stream1 │ 1  │ N/A  │ fork   │ online │ 17  │ 0%     │ 2.8 MB   │
                                      │ omx_stream2 │ 2  │ N/A  │ fork   │ online │ 6   │ 0%     │ 2.8 MB
                                      Many Thanks .
                                        shbatm Module Developer @evroom
                                        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                        There was a problem with the steams not stopping on a restart, so the module sends a stop command first whenever it starts, do you have autoStart: true in your config?
                                          @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          OK. I’ll check this later today, the notification RTSP-PLAY should switch and start the stream so that’s an issue.
                                            @Cr4z33 try inserting this.playing = true; at Line 574 as the first line in the if statement and see if that works. I’ll test later today.
                                            EDIT: Just pushed an update. Please try the latest release in develop
                                            • 10
                                            • 11
                                            • 12
                                            • 30
                                            • 31
                                            • 10 / 31
