    602 Posts 67 Posters 2.4m Views 68 Watching
      shbatm Module Developer @Cr4z33
      @cr4z33
      You’ll want the following settings which should give you 1 blank video box that does not show anything until you press play.
      autoStart: false,
      rotateStreams: true,
      rotateStreamTimeout: 0,
      localPlayer: 'omxplayer',
      remotePlayer: 'none',
      showSnapWhenPaused: false,
      remoteSnaps: false,
      I’m assuming you’re seeing the same glitch that is plaguing the last OMXPlayer version of this module. I’m working on it today to try and find what I broke. In the meantime, try reverting back and seeing if that fixes the issue. I just tested the following notification on the VLC version and it worked as expected, so it’s got to be something with omxplayer.
      notification: "RTSP-PLAY",
      payload: "stream3"
      Cr4z33C 3 Replies Last reply
      • Cr4z33C
        Cr4z33 @shbatm
        @shbatm although I am not a developer I agree with you.
        Whenever I tried something different from normal module usage involving omxplayer it always ended up with a mess lol! :grinning_face_with_smiling_eyes:
        Going to try what you are suggesting here.
        Can’t wait to see the VLC implementation (it just works as intended). :smiling_face_with_heart-eyes:
        • Cr4z33C
          Cr4z33 @shbatm
          @shbatm nope the simultaneous streams have now dropped from 7 to 2, but still not what I want (aka a single stream). :smiling_face_with_open_mouth_cold_sweat:
          Gonna try the develop branch and see how it is doing right now.
          S 2 Replies Last reply
            @cr4z33 Still looking into it, but I just thought of something… it doesn’t look like you’re calling RTSP-STOP on the old stream anywhere when changing channels so right now it’s going to keep starting streams every time–there’s no “1 at a time” method when controlling it from notifications… yet.
            • Cr4z33C
              Cr4z33 @shbatm
                shbatm Module Developer @shbatm
                @djuscha I’ve reverted the changes that I think broke the master channel. Please try updating your module to the current master branch and test.
                A 1 Reply Last reply
                  @cr4z33 Added something that might help. Please use the develop branch and update your change channel commands to :
                  notification: “RTSP-PLAY”,
                  payload: { stream:“stream1”, stopOthers: true }
                  EDIT: Nevermind, don’t do that. I fixed the glitch on the develop channel that was starting more than one stream when rotateStreams: true was set. Please try that and see if it works now.
                  • A
                    anthony6608 @shbatm
                    @shbatm Hey, I updated issue #33 with the errors I am seeing when you have a chance. Also, should I run this update although I am using the VLCplayer method? Let me know what you think. Thanks again for all your help!
                    • BKeyportB
                      BKeyport Module Developer
                      I’m unable to get this module to load and run with FFMPeg anymore - as of 3PM 1/4/19 (Pacific Time (Seattle))
                      Update was applied as of that time.
                      I don’t know how to retrieve logs.
                      – Bug filed on github - https://github.com/shbatm/MMM-RTSPStream/issues/34
                        @djuscha, @Cr4z33 @barnosch @anthony6608 @bhepler @evroom, and anyone else using this module:
                        I just pushed a bunch of bug fixes for OMX Player to the develop branch. Please test and let me know if you are still seeing the same issues.
                        Fixes include:
                        • App closing now spawns a new process to actually kill the OMX streams, it was getting cut off in the middle of closing everything due to it being an async process and leaving streams open.
                        • Wait for DOM to be shown before calling to start the streams–this was causing the Fullscreen on Resume problems.
                        • Only start one stream at a time if we’re in RotateStreams mode
                        • Can jump to a specific stream in RotateStreams mode using notifications
                        • Fixed and cleaned up all notifications and control from other modules
                        • Fixed broken key bindings after MMM-KeyBindings upgrade
                        • Fixed issue where module was trying to connect to PM2 while it was already connected (e.g. stop stream 1 and start stream 2 back to back).
                        To switch branches:
                        cd ~/MagicMirror/modules/MMM-RTSPStream
                        sudo rm -R node_modules/
                        git fetch --al
                        git checkout develop
                        git pull
                        npm install
                        Cr4z33C D 2 Replies Last reply
                        • evroomE
                          evroom
                          @shbatm
                          I installed the new changes according your procedure.
                          I am using omxplayer for a RTSP stream of a IP cam.
                          I do not use rotation or any other fancy stuff.
                          I see the same issue as before: omx_stream1 has status stopped and when I click on the play button it also will not start.
                          I stopped and started mm 2 times and even did a complete reboot
                          It only can be started using
                          $ pm2 start omx_stream1
                          Another restart of mm shows that the omx_stream1 is being stopped, but never restarted.
                          After ever mm restart I will need to perform:
                          MagicMirror version: 2.37.0
                          • evroomE
                            evroom
                            I noticed this in pm2 logs (do not see this after every mm restart):
                            0|mm  | Connecting socket for: MMM-RTSPStream
                            0|mm  | PM2: Stopping all OMXPlayer Streams...
                            0|mm  | Sockets connected & modules started ...
                            0|mm  | Launching application.
                            0|mm  | PM2: Checking if omx_stream1 is running...
                            0|mm  | PM2: Stopping omx_stream1...
                            PM2      | Stopping app:omx_stream1 id:1
                            1|omx_stream1  | Video codec omx-h264 width 640 height 360 profile 77 fps 30.000000
                            1|omx_stream1  | Subtitle count: 0, state: off, index: 1, delay: 0
                            1|omx_stream1  | V:PortSettingsChanged: 640x360@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                            1|omx_stream1  | have a nice day ;)
                            PM2            | App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2            | pid=2104 msg=process killed
                            In this case it was tried to start the stream, but it exited.
                            Starting it by hand makes it work again.
                            • Cr4z33C
                              Cr4z33 @shbatm
                              @shbatm I ran the develop update.
                              With omxplayer (and autoStart: false) I see stream labels changing when giving a voice command, but then no stream is starting.
                              With vlc nothing happens, not a single stream starting by voice command.
                                djuscha @shbatm
                                @shbatm
                                have made yesterday update without develoop only
                                git pull
                                npm install
                                everything runs :)
                                 Name        │ id │ mode │ status │ ↺      │ cpu │ memory │
                                │ mm          │ 0  │ N/A  │ fork   │ online │ 0   │ 0%     │ 2.5 MB   │
                                │ omx_stream1 │ 1  │ N/A  │ fork   │ online │ 17  │ 0%     │ 2.8 MB   │
                                │ omx_stream2 │ 2  │ N/A  │ fork   │ online │ 6   │ 0%     │ 2.8 MB
                                Many Thanks .
                                  shbatm Module Developer @evroom
                                  @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                  There was a problem with the steams not stopping on a restart, so the module sends a stop command first whenever it starts, do you have autoStart: true in your config?
                                  evroomE 1 Reply Last reply
                                    @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                    OK. I’ll check this later today, the notification RTSP-PLAY should switch and start the stream so that’s an issue.
                                      @Cr4z33 try inserting this.playing = true; at Line 574 as the first line in the if statement and see if that works. I’ll test later today.
                                      EDIT: Just pushed an update. Please try the latest release in develop
                                      Cr4z33C 1 Reply Last reply
                                      • evroomE
                                        evroom @shbatm
                                        @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                        Yes, I have.
                                        Just to understand, when you start fresh, there is no omx_stream1 under pm2 list.
                                        When you start your first stream, it is first visible under pm2 list, right?
                                        Till now I was able to start the stream with pm2 start, but after removing the stream (pm2 remove omx_stream1), I cannot get it to work anymore.
                                        MM restart, reboot, nothing helps.
                                        And pm2 start now says:
                                        pi@MagicPi:~ $ pm2 start omx_stream1
                                        [PM2][ERROR] script not found : /home/pi/omx_stream1
                                        │ App name │ id │ version │ mode │ pid │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
                                        │ mm       │ 0  │ 2.5.0   │ fork │ 811 │ online │ 0       │ 4m     │ 0%  │ 2.5 MB   │ pi   │ disabled │
                                        Which makes sort of sense.
                                        After MM restart, pm2 logs shows:
                                        Will revert back to the master branch and try again.
                                          Yes, the omx_stream1 is created the first time you play a stream with the module.
                                          Please use the develop branch with omxplayer. It was working on my machine the last time I started.
                                          • Cr4z33C
                                            Cr4z33 @shbatm
                                            @shbatm things are doing waaaay better now! :grinning_face_with_smiling_eyes:
                                            With omxplayer stream switching is almost OK if it wasn’t that it doesn’t select the wanted stream.
                                            Ie. I want stream3 therefore I give the voice command, but then it starts playing the wrong stream (and always random).
                                            Voice recognition is 100% correct as I always have a textual confirmation of command on screen.
                                            With vlc it’s a mess as multiple streams ALWAYS start at the same time after a voice command.
                                            At this point I don’t care who will be the chosen player as long as we get everything working so omxplayer would be fair enough if running properly. :smiling_face_with_open_mouth_smiling_eyes: :smiling_face_with_open_mouth_cold_sweat:
                                            • 10
                                            • 11
                                            • 12
                                            • 30
                                            • 31
                                            • 10 / 31
