    [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io)
    81 Posts 13 Posters 81.1k Views 16 Watching
      shbatm Module Developer @richland007
      @richland007 said in [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io):
      It only show that 1 one port 0.0.0.0:21900
      It would be in pm2 logs mm or ~/.pm2/logs folder. I’ll check when I get a chance why it’s not opening more than 1 port.
      richland007R 1 Reply Last reply
      • richland007R
        richland007 @shbatm
        @shbatm I don not see anything out of the ordinary in my logs when i do pm2 logs mm definitely not 36 ports open in addition to 29100 when i go to location ~/.pm2/logs the log files are there in the directory but empty.
          So I was looking at the Fauxmojs project–what this module uses to handle the “devices”–and it looks like there are some issues with Gen 2 Echos not discovering the devices–but for most, the alexa.amazon.com website was working. I’ll keep an eye on that project–but at the moment, I don’t have anything else I can do from my end.
          If you want to see some more detailed logs–start the MM manually with the following:
          export DEBUG=sstp-server,deviceEndpoints,discoveryService
          npm start
          @richland007 - I just tested my installation with 3 devices and, while it wasn’t showing all of the ports on the log line due to a bug, it was opening the ports (visible with netstat -tulpn | grep electron – see below). Just in case anyone is wondering–port 1900 is the discovery port.
          tcp        0      0 0.0.0.0:21900           0.0.0.0:*               LISTEN      15738/electron.js
          tcp        0      0 0.0.0.0:21901           0.0.0.0:*               LISTEN      15738/electron.js
          tcp        0      0 0.0.0.0:21902           0.0.0.0:*               LISTEN      15738/electron.js
          tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      15738/electron.js
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           15738/electron.js
          richland007R D 2 Replies Last reply
          • richland007R
            richland007 @shbatm
            @shbatm How do i read more log lines not only tailing the last 15 from pm2 logs mm ??
            This works so nicely with the only one device that it is starting (turn on and turn off the whole mirror) it is awesome… i am so hurt that i am unable to have the rest of the “devices/modules” working.
            If you want to have a look at my long a%$ :) config.js entry for the MMM-AlexaOnOff module here it is ;
                module: 'MMM-AlexaOnOff',
                    //netInterface: 'wlan0',
                    //startPort: 15000,
                    devices: [{
                          on: {
                            notification: "REMOTE_ACTION",
                            payload: { action: "SHOW", module: "module_4_clock" }
                          off: {
                            payload: { action: "HIDE", module: "modules_4_clock" }
                          on: {
                            payload: { action: "SHOW", module: "module_5_calendar" }
                          off: {
                            payload: { action: "HIDE", module: "module_5_calendar" }
                                      name: "Denis Calendar",
                          on: {
                            payload: { action: "SHOW", module: "module_6_calendar" }
                          off: {
                            payload: { action: "HIDE", module: "module_6_calendar" }
                          on: {
                            payload: { action: "SHOW", module: "module_7_compliments" }
                          off: {
                            payload: { action: "HIDE", module: "module_7_compliments" }
            			  name: "Gas Prices Module",
                          on: {
                            payload: { action: "SHOW", module: "module_8_MMM-Gas" }
                          off: {
                            payload: { action: "HIDE", module: "module_8_MMM-Gas" }
                          on: {
                            payload: { action: "SHOW", module: "module_9_MMM-Instagram" }
                          off: {
                            payload: { action: "HIDE", module: "module_9_MMM-Instagram" }
            			  name: "Page Indicator Module",
                          on: {
                            payload: { action: "SHOW", module: "module_11_MMM-page-indicator" }
                          off: {
                            payload: { action: "HIDE", module: "module_11_MMM-page-indicator" }
                          on: {
                            payload: { action: "SHOW", module: "module_12_MMM-DHT-Sensor" }
                          off: {
                            payload: { action: "HIDE", module: "module_12_MMM-DHT-Sensor" }
                          on: {
                            payload: { action: "SHOW", module: "module_13_MMM-NOAA3" }
                          off: {
                            payload: { action: "HIDE", module: "module_13_MMM-NOAA3" }
            			  name: "System Stats Module",
                          on: {
                            payload: { action: "SHOW", module: "module_14_MMM-SystemStats" }
                          off: {
                            payload: { action: "HIDE", module: "module_14_MMM-SystemStats" }
            			  name: "Movie Listings Module",
                          on: {
                            payload: { action: "SHOW", module: "module_15_MMM-MovieListings" }
                          off: {
                            payload: { action: "HIDE", module: "module_15_MMM-MovieListings" }
                          on: {
                            payload: { action: "SHOW", module: "module_16_MMM-Ecobee" }
                          off: {
                            payload: { action: "HIDE", module: "module_16_MMM-Ecobee" }
                          on: {
                            payload: { action: "SHOW", module: "module_17_MMM-AlexaPi" }
                          off: {
                            payload: { action: "HIDE", module: "module_17_MMM-AlexaPi" }
            			  name: "Exchange Rate Module",
                          on: {
                            payload: { action: "SHOW", module: "module_20_MMM-LICE" }
                          off: {
                            payload: { action: "HIDE", module: "module_20_MMM-LICE" }
                          on: {
                            payload: { action: "SHOW", module: "module_21_stocks" }
                          off: {
                            payload: { action: "HIDE", module: "module_21_stocks" }
                          on: {
                            payload: { action: "SHOW", module: "module_22_MMM-GoogleMapsTraffic" }
                          off: {
                            payload: { action: "HIDE", module: "module_22_MMM-GoogleMapsTraffic" }
            			  name: "My Commute Module",
                          on: {
                            payload: { action: "SHOW", module: "module_23_MMM-MyCommute" }
                          off: {
                            payload: { action: "HIDE", module: "module_23_MMM-MyCommute" }
                          on: {
                            payload: { action: "SHOW", module: "module_24_MMM-iFrame" }
                          off: {
                            payload: { action: "HIDE", module: "module_24_MMM-iFrame" }
                          on: {
                            payload: { action: "SHOW", module: "module_25_MMM-RSS-FEED" }
                          off: {
                            payload: { action: "HIDE", module: "module_25_MMM-RSS-FEED" }
                          on: {
                            payload: { action: "SHOW", module: "module_26_MMM-fitbit" }
                          off: {
                            payload: { action: "HIDE", module: "module_26_MMM-fitbit" }
            			  name: "Google Fit Module",
                          on: {
                            payload: { action: "SHOW", module: "module_27_MMM-GoogleFit" }
                          off: {
                            payload: { action: "HIDE", module: "module_27_MMM-GoogleFit" }
                          on: {
                            payload: { action: "SHOW", module: "module_28_MMM-horoscope" }
                          off: {
                            payload: { action: "HIDE", module: "module_28_MMM-horoscope" }
            			  name: "Phone Notification Module",
                          on: {
                            payload: { action: "SHOW", module: "module_29_phone_notification" }
                          off: {
                            payload: { action: "HIDE", module: "module_29_phone_notification" }
            			  name: "TV Stream Module",
                          on: {
                            payload: { action: "SHOW", module: "module_30_MMM-RTSPStream" }
                          off: {
                            payload: { action: "HIDE", module: "module_30_MMM-RTSPStream" }
                          on: {
                            payload: { action: "SHOW", module: "module_31_iFrame" }
                          off: {
                            payload: { action: "HIDE", module: "module_31_iFrame" }
                          on: {
                            payload: { action: "SHOW", module: "module_32_MMM-NowPlayingOnSpotify" }
                          off: {
                            payload: { action: "HIDE", module: "module_32_MMM-NowPlayingOnSpotify" }
                          on: {
                            payload: { action: "SHOW", module: "module_33_MMM-Events" }
                          off: {
                            payload: { action: "HIDE", module: "module_33_MMM-Events" }
                          on: {
                            payload: { action: "SHOW", module: "module_34_MMM-NASA" }
                          off: {
                            payload: { action: "HIDE", module: "module_34_MMM-NASA" }
                          on: {
                            payload: { action: "SHOW", module: "module_35_MMM-SimpleLogo" }
                          off: {
                            payload: { action: "HIDE", module: "module_35_MMM-SimpleLogo" }
            			  name: "Random Quotes Module",
                          on: {
                            payload: { action: "SHOW", module: "module_36_random_quotes" }
                          off: {
                            payload: { action: "HIDE", module: "module_36_random_quotes" }
            			  name: "Bible Verse Module",
                          on: {
                            payload: { action: "SHOW", module: "module_37_MMM-DailyBibleVerse" }
                          off: {
                            payload: { action: "HIDE", module: "module_37_MMM-DailyBibleVerse" }
                          on: {
                            payload: { action: "SHOW", module: "module_39_MMM-DropboxWallpaper" }
                          off: {
                            payload: { action: "HIDE", module: "module_39_MMM-DropboxWallpaper" }
            			  name: "Weather Background Module",
                          on: {
                            payload: { action: "SHOW", module: "module_40_MMM-Dummy" }
                          off: {
                            payload: { action: "HIDE", module: "module_40_MMM-Dummy" }
                          on: {
                            payload: { action: "SHOW", module: "module_43_MMM-Jnews" }
                          off: {
                            payload: { action: "HIDE", module: "module_43_MMM-Jnews" }
            	      name: "Eva's Modules",
                          on: [
                          off: [
            	      name: "Denis Modules",
                          on: [
                          off: [
                            payload: { action: "Show", module: "module_9_MMM-Instagram" }
                          on: {
                            payload: { action: "MONITORON"}
                          off: {
                            payload: { action: "MONITOROFF"}
            It is only loading the last “device” named Mirror for (an all on/off feature) on port 21900.
            I tried changing the port start number to something else to no avail, i tried commenting out all but the last 2 of the devices still no luck…it only starts 1.
            Edit: I spoke too early on singing it praises if you give a command ( in my case all i have is one that makes the monitor go off and than on after you ask Alexa to turn Mirror On) after 2-3 minutes everything freezes and you absolutely can not interact with the mirror completely neither from putty /ssh or vnc (ctrl/alt/del) or keyboard input only a hard power reset is the solution it has happened twice. I did try it one last time before posting this, and right after “Alexa turn Mirror On” i hit ctrl+Q to quit MM and see what the CPU values were and they were right around 70% but they went immediately down to 1% and nothing happened no more freezing of the Rpi…weird!!! I really need to get you some more detailed logs
            Please help me solve this so i can turn my modules on and off
            Thank you for your prompt replies and patience
            Denis
              djsunrise19 @shbatm
              @shbatm Thanks. I’m using an echo dot 3rd generation. Sadly, I have to wait. There seems to be no problems with your module / the mirror / network.
              Good work!
                They should be in ~/.pm2/logs by default. You can also stop the pm2 version and run the mirror manually using the instructions above.
                I’ll let you know if I can replecate the CPU issue, but that’s very strange. I haven’t seen that.
                Make sure you update to the latest version of the module to see the correct line, but other than that I don’t know why its not working for more than one device. At this point it sounds like a fauxmojs issue… You can always open an issue on their GitHub repo.
                  shbatm Module Developer @djsunrise19
                  @djsunrise19 said in [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io):
                  I’d suggest posting a comment on the fauxmojs issue–maybe it will prompt them that more people are waiting for a fix. It looks like the python version has been fixed, so I’m sure it’s just a matter of them getting around to it.
                    @richland007 – So I just noticed something interesting: I tried adding multiple devices, and running “Discover my devices” from my echo. Alexa said she didn’t find any new devices, but when I looked in the device list on alexa.amazon.com, she had already found the other devices. Maybe try deleting all of the Wemo devices on your Alexa app and then retrying discovery?
                    richland007R 2 Replies Last reply
                    • richland007R
                      richland007 @shbatm
                      @shbatm i will try it again but i think i did it once or twice deleting all my devices and had her discover them back up to no avail
                      D
                      • richland007R
                        richland007 @shbatm
                        @shbatm I was wondering, however i am sure that i am wrong and just wishful thinking, but maybe changing the minimum version of MM for MMM-AlexaOnOff to 2.4.1 (which is the version i am at) only works for one instance, meaning initiating one device and not for all of them???
                        D
                        S MoreLinuxM 2 Replies Last reply
                          wishful thinking
                          • MoreLinuxM
                            MoreLinux @richland007
                            @richland007 Solution: Why not just update your mirror to 2.6.0? On my 2.6.0 mirror this add-on is working great, Alexa is finding all it’s 15 devices in one run.
                            StoffbeuteluweS 1 Reply Last reply
                            • E
                              eddgeywing
                              Does anyone have instructions on how to connect this to Google Home? I’ve been searching for days with no luck.
                              • StoffbeuteluweS
                                Stoffbeuteluwe Project Sponsor @MoreLinux
                                @MoreLinux hi, have a MAC and the module is not working and I don’t know why?
                                MoreLinuxM 1 Reply Last reply
                                  sbrundage85
                                  I have latest Magic Mirror version with Alexa Dot 3rd gen. I am unable to discover device after installation. Anyone experience this issue and solve it? Running netstat -tulpn | grep electron I get LISTENing on port 21900. When I ask Alexa to discover devices, I get nothing. Both Alexa & Rasp Pi are connected to the same wifi. Only thing in my logs when running Magic Mirror is
                                  /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                  0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                  Any help is appreciated
                                  StoffbeuteluweS NiggichN 2 Replies Last reply
                                  • MoreLinuxM
                                    MoreLinux @Stoffbeuteluwe
                                    @Stoffbeuteluwe I also don’t know why it’s not working for you. I haven’t written the module, just installed and it worked.
                                    I have an Amazon Echo Dot 2. generation.
                                    StoffbeuteluweS 3 Replies Last reply
                                    • StoffbeuteluweS
                                      @MoreLinux on Mac??
                                      • StoffbeuteluweS
                                        Stoffbeuteluwe Project Sponsor @sbrundage85
                                        @sbrundage85 you can try echo dot 2 …I think the 3.generation is not working.
                                          sbrundage85 @Stoffbeuteluwe
                                          @Stoffbeuteluwe Any word on the possibility of getting things working with the Echo Dot 3rd gen? Any references of things to try? Any help is appreciated, really want to get my mirror up and running and this is a huge module I want to implement
                                          • StoffbeuteluweS
                                            @MoreLinux can you post your config. of MMM-AlexaOnOff Module so i can try?
                                            • 3 / 5
