    HMDI (from Pi 3) to DVI? Will it work?
    11 Posts 9 Posters 13.6k Views 8 Watching
    • nbrennN
      nbrenn
      Will the HANNspree HF225DPB monitor work for the Magic Mirror application?
      It doesn’t have an HDMI input, but could I just use an HDMI to DVI cable to connect the Pi 3 to the monitor?
      Thanks!
      zamZ 1 Reply Last reply
      • MichMichM
        MichMich
        Yes, I do the same on my development monitor.
        • zamZ
          zam @nbrenn
          @nbrenn it’s working for me … i used a monitor which don’t have HDMI port so i connected with a HDMI to DVI converter only issue is the sound wont output trough HDMI you need to use something else :) Good Luck
          • loribeeincaL
            loribeeinca
            that’s what I am doing. I was using an adapter for initial testing, then I bought a HDMI to DVD cable from amazon for the final build. Works just fine
              McSorley
              I have a DVI right angle adapter with a DVI to HDMI Cable.
              • indigomejorI
                indigomejor
                Hi, will work VGA cable with HDMI adapter? Thank you very much!
                  McSorley
                  Dont get a straight VGA to HDMI cable because it wouldnt work. You would need convertor which is a bit larger than you would expect and often need to be powered.
                  • yawnsY
                    yawns Moderator
                    Right, you need an active HDMI-VGA converter.
                    You could go for this: https://thepihut.com/products/raspberry-pi-hdmi-to-vga-convertor
                    However the “chain” looks a bit ugly (second image) and I could imagine it is a bit unsteady.
                    Or you go for this: https://www.pi-supply.com/product/gert-vga-666-hardware-vga-raspberry-pi/
                    However this blocks almost all GPIO ports and you need to solder it on your own, as it is a kit
                    indigomejorI 1 Reply Last reply
                    • indigomejorI
                      indigomejor @yawns
                      @McSorley @yawns thank you guys! The blue one looks exactly like something I discovered in my local shop, so it’s solved, thank you!
                        bibi
                        in the same idea an adaptor display port > hdmi would also work no? anyone has tried this ?
                        D 1 Reply Last reply
                          dbahn25 @bibi
                          @bibi display port to hdmi works definitely. it’s both digital, so the adapter should be pretty simple and cheap (I use one for ~12€ from miniDP to HDMI on my laptop)
