    HMDI (from Pi 3) to DVI? Will it work?
    11 Posts 9 Posters 12.6k Views 8 Watching
    • zamZ Offline
      zam @nbrenn
      @nbrenn it’s working for me … i used a monitor which don’t have HDMI port so i connected with a HDMI to DVI converter only issue is the sound wont output trough HDMI you need to use something else :) Good Luck
      • loribeeincaL Offline
        loribeeinca
        that’s what I am doing. I was using an adapter for initial testing, then I bought a HDMI to DVD cable from amazon for the final build. Works just fine
          McSorley
          I have a DVI right angle adapter with a DVI to HDMI Cable.
          • indigomejorI Offline
            indigomejor
            Hi, will work VGA cable with HDMI adapter? Thank you very much!
              McSorley
              Dont get a straight VGA to HDMI cable because it wouldnt work. You would need convertor which is a bit larger than you would expect and often need to be powered.
              • yawnsY Offline
                yawns Moderator
                Right, you need an active HDMI-VGA converter.
                You could go for this: https://thepihut.com/products/raspberry-pi-hdmi-to-vga-convertor
                However the “chain” looks a bit ugly (second image) and I could imagine it is a bit unsteady.
                Or you go for this: https://www.pi-supply.com/product/gert-vga-666-hardware-vga-raspberry-pi/
                However this blocks almost all GPIO ports and you need to solder it on your own, as it is a kit
                indigomejorI 1 Reply Last reply Reply Quote 0
                  indigomejor @yawns
                  @McSorley @yawns thank you guys! The blue one looks exactly like something I discovered in my local shop, so it’s solved, thank you!
                    bibi
                    in the same idea an adaptor display port > hdmi would also work no? anyone has tried this ?
                      dbahn25 @bibi
                      @bibi display port to hdmi works definitely. it’s both digital, so the adapter should be pretty simple and cheap (I use one for ~12€ from miniDP to HDMI on my laptop)
